Cranks but no start
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wtfish, Oct 8, 2013.
  1. Oct 8, 2013 at 7:53 PM
    Wtfish
    Wtfish [OP] New Member
    Miami
    99 prerunner v6
    Hey there, long time reader deciding to post for the first time hoping for a little help. I have a 99 prerunner V6 auto that generally runs great. A few days back I stopped at a store to pick up something and when I came back my truck wouldn't start. Cranks fine but just keeps turning. After a few tries it finally turned over and I made it home. The next day I had the same issue and was able to do a few tests to find I had no spark and a link error from the obd port. After a few cycles of the switch it will start fine and computer gives no codes. Fuses are all good, I have power to the igniter and coils, and checked all the grounds. Changed the crank sensor and igniter after some reading but still no luck. I'm out of ideas an getting pretty frustrated so I'd appreciate any advice I can get.
    Sorry for the long post, I'm trying to be as detailed as possible. Thanks for actually reading the whole rant if you've gotten this far.
  2. Oct 8, 2013 at 7:58 PM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    Have you checked the charge on the battery? I would take it to Advanced auto or Auto zone and have them run a charging system test just to be sure. may just be a bad ground or something small. but may be an old alternator going bad or a battery that is low or simply has dirty terminals. I can feel on start up when my battery terminals are starting to need cleaning....happens every 6 months or so. Good luck!
  3. Oct 8, 2013 at 8:39 PM
    MRBOND101
    MRBOND101 TTE
    Dylan
    Frisco, Texas
    16 TRD-OR AC
    ^x2 id just get your battery checked sounds like its time for a new one. I recently just replaced mine a couple months ago and before it would crank perfectly fine 9 times out of ten my battery was just out of charge. Hope you get it fix good luck man!
  4. Oct 8, 2013 at 8:49 PM
    maytagworker
    maytagworker Well-Known Member
    i had the same issue with my dads truck after i got done doing the 3.4L swap, no spark while cranking but runs perfectly fine when it does start, ended up being the ignitor, small little ign module should be bolted on the fender, being that you changed that should check for signal out of ECU, if im not mistaken you got power and ground to ignitor then goes ignitor to ECU then goes to coils, of course need to check that when it wont start
  5. Oct 9, 2013 at 11:51 AM
    Wtfish
    Miami
    99 prerunner v6
    Battery's perfect so that's another dead end unfortunately
  6. Oct 9, 2013 at 11:54 AM
    Wtfish
    Miami
    99 prerunner v6
    Swapping the igniter didn't change anything so it's starting to point toward ecu I think. Thanks for the tip though
