Cranks but won’t fire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ole one pice, Sep 9, 2020.
  1. Sep 9, 2020 at 5:02 AM
    Ole one pice
    Ole one pice [OP] Ky Cook
    Sheldon
    Kentucky
    2nd gen tacoma
    Custom front bumper Custom spare tire mount Custom skid plate Custom roof rack Custom spare tire an jerry can mount
    I just put a new head gasket on and timing chain both or verified correct I’ve got 55 psi on the fuel rail before the regulator I’ve got spark I’ve got compression all my injectors are pumping but it will not fire just cranks if I spray starting fluid in the intake it fires right up and will run for a second any suggestions also it’s not pulling any codes
  2. Sep 9, 2020 at 5:51 AM
    gearcruncher
    Canadain bumper technician
    If you cleaned the throttle body , you may want to do an idle re-learn if you havnt done this yet . Pop your battery cables off for a couple minutes and then re-connect , then try starting the truck .
    Its common when servicing the intake system .
    wilcam47 likes this.
  3. Sep 9, 2020 at 6:05 AM
    Ole one pice
    Sheldon
    Kentucky
    2nd gen tacoma
    I tried that with no success I feel like it’s got to be something simple like that though because everything is working as it should
  4. Sep 9, 2020 at 7:05 AM
    gearcruncher
    Does your scanner have the ability of watching parameters when you crank the engine over ?
    Go over all the values of your sensors to verify they are all working
    Do you have a value for your crank position sensor when the engine is cranking ?
    If a value is stuck on 1 number or blank , you may not be getting a value . All sensors plugged in ?
    I believe the truck may have to run for a couple minutes to get some codes .
    Ole one pice[OP] likes this.
  5. Sep 9, 2020 at 10:09 AM
    Ole one pice
    Sheldon
    Kentucky
    2nd gen tacoma
    I will have to see about that it’s not the greatest scanner and yeah I just triple checked connections and sensors
  6. Sep 9, 2020 at 10:13 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Sounds like a fuel issue. Crank it for a bit and pull a plug. It it’s dry, you gots fuel issues. Since you’ve got pressure at the regulator, you have a fairly limited area to look. Injectors?
    SR-71A and Ole one pice[OP] like this.
  7. Sep 9, 2020 at 10:26 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If it runs for a second on starting fluid and you've got fuel pressure you can pretty much rule out compression and spark
    What do you mean by "the injectors are pumping"? Did you get a noid light on one of them?
    Could an alarm issue prevent injectors from firing?
    RedWings44 and TnShooter like this.
  8. Sep 9, 2020 at 1:58 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If it runs on starting fluid but not when cranking and it has pressure at the rail, the injectors are not being pulsed.
    Possibly the crank position sensor.
  9. Sep 9, 2020 at 8:04 PM
    Ole one pice
    Sheldon
    Kentucky
    2nd gen tacoma
    I did t not have a mood light but I used a stethoscope and had someone crank while I listened to them take each one of them was pumping supposedly and I put a new crank position sensor and cam position sensor in thought they were Faulty so I exchanged them and but another set in I did a pressure test and it was running almost 60 psi before the regulator I’ve got a new one coming in the morning figured it may be clogged somehow
  10. Sep 9, 2020 at 8:05 PM
    Ole one pice
    Sheldon
    Kentucky
    2nd gen tacoma
    Also has all new plugs but I pulled them they were not soaked but had been fired on from using starter fluid
  11. Sep 9, 2020 at 8:06 PM
    Bishop84
    Bishop84 Well-Known Member
    Check grounds on the back of the head, on the p/s pump, under the battery etc.
    TnShooter and b_r_o like this.
  12. Sep 9, 2020 at 8:24 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Sounds like you were dead heading the pump at 60 psig. It should only read about 41 psig. Where did you tap into the fuel line?
    Measure the fuel pressure.
    Standard:
    281 to 287 kPa (2.87 to 2.93 kgf/cm2, 40.8 to 41.7 psi)
    • If the fuel pressure is greater than the standard value, replace the fuel pump.
    • If the fuel pressure is less than the standard value, check the connection between the fuel hose and fuel pump.
    Turn off Fuel Pump.
    (p) Check that the fuel pressure does not change for 5 minutes.
    Standard:
    147 kPa (1.5 kgf/cm2, 21 psi)
    If the result is not as specified, check the fuel pump and fuel injectors.
    SR-71A and po35042 like this.
  13. Sep 10, 2020 at 5:58 PM
    Ole one pice
    Sheldon
    Kentucky
    2nd gen tacoma
    I just tested All the injectors with a Noyd light and they are all firing I did the fuel pressure test where the if you’re in line meets the metal hose that goes to the regulator I’ve got a new crank and cam position sensor I have double checked the connection of the grounds on the back of the head and still nothingI just bought a new fuel pressure regulator from Toyota if I install it I can’t return it and it was 100 bucks think that could be the issue?
  14. Sep 10, 2020 at 6:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If the injectors are for sure firing, and it runs on starting fluid, then I’m going to suspect some type of timing issue?
    You can have fuel, air, spark, and compression, but if it’s not timed right. It won’t do much.
    I know you say that you have fuel and spark.
    Is there a check engine light?
    I’d look at the crank / cam correlation?
    I’d be 100% certain, before I start throwing more parts at it.
    SR-71A, maxtherat and po35042 like this.
  15. Sep 10, 2020 at 6:46 PM
    Bishop84
    Agree, its not a parts failure, its a reassembly issue.
    Timing is the big suspect.
  16. Sep 10, 2020 at 7:20 PM
    Ole one pice
    Sheldon
    Kentucky
    2nd gen tacoma
    I pulled the valve cover back off chat top dead center did another full revolution and it was The exact opposite I put my cans back in the same way they came out wind up my marks on the timing chain and had it set at top dead center when I reinstalled it I was so careful this is the first time I’ve ever been this far in an engine I was very thorough not to say I couldn’t of fucked something upBut I really don’t think it’s the timing
  17. Sep 10, 2020 at 7:22 PM
    Ole one pice
    Sheldon
    Kentucky
    2nd gen tacoma
    I pulled my plugs and they have gas on them
  18. Sep 10, 2020 at 7:25 PM
    Ole one pice
    Sheldon
    Kentucky
    2nd gen tacoma
    I made it run for about 30 seconds just now by spraying starter fluid in and it sounded pretty good
  19. Sep 10, 2020 at 7:29 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Doesn't that scream 'not getting fuel'? But the plugs are wet. :notsure:
  20. Sep 10, 2020 at 7:30 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    If it starts with starting fluid it has spark and compression. That being said it should start with gasoline. Just saying.
    You do realize that the fuel regulator is at the end of the fuel rail and if you have fuel pressure which should be ~ 41PSIG if teed into the fuel line as per the service manual above.
    The biggest question I have is the gasoline supply? The starting fluid confirms the spark.
    Does it even attempt to fire when starting without starting fluid?
    RedWings44 and Ole one pice[OP] like this.
