Cranks too long won’t turn on
Discussion in '1st Gen. Tacomas (1995-2004)' started by YotaLivin670, Oct 26, 2019.
  1. Oct 26, 2019 at 3:38 PM
    YotaLivin670
    YotaLivin670 [OP] Member
    Junior
    1998 Tacoma 2.4l
    I recently purchased a 1998 2.4l Tacoma, from a dude on the marketplace. My drive back home was 3 hours and the car had no problems. One day I took it to work and did a couple of pulls and my battery shifted its position stripping my ground to my battery. Had a friend pull the taco home and did the whole terminals again, car started but died immediately. Tried again but it just kept cranking too long, tried to jumpstart it but that didn’t work either. Any help or information would be greatly appreciated.!
  2. Oct 26, 2019 at 3:41 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    Check above post this was a real fix for me! It’s a random thing that I’ve heard of and also had a problem with on my 90 pre-taco pickups except on the older ones it was the relay under the drivers side dash. My Tacoma V-6 would randomly do this for years and got really bad the other day. It’s fixed now, mine was the efi relay under the hood in the fuse box next to the fuses, just swap both of the same style relay and make sure they have the same part # to be safe, works a treat!
  3. Oct 26, 2019 at 9:59 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Check your electronic fuel injection (EFI) fuses. Those will go out usually when there is a mass voltage anomaly like a short.
    YotaLivin670[OP] likes this.
  4. Oct 27, 2019 at 3:45 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Honda Accords of the '90s were known to just have the main relay dry out and short in high heat areas of the country, weird stuff happens.
    Since you had trouble around the battery of course start there but a fuel pump goes out quick lots of times also.
