crankshaft bolt
Discussion in '1st Gen. Tacomas (1995-2004)' started by tlh178, Jan 28, 2012.
  1. Jan 28, 2012 at 12:18 PM
    tlh178
    tlh178 [OP] Well-Known Member
    terry
    mich
    2012 4WD reg cab/ 02 SR5 Prerunner/07 FJC 4WD
    is it possible to use a impact wrench on this bolt. my air compressor goes to 180 psi. or will i have to make the special tool. getting ready to do timing belt. i just ordered the snap on tensioner tool, so that should make things alittle easier. in the past, i tried to replace the thermostat and two of the blot head were alittle stripped. i'm thinking a 12pt socket and some heat? anyone else have a better idea. this is on a 3.4 02/prerunner. thanks for any tips!
  2. Jan 28, 2012 at 5:29 PM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    You can use an impact on the crank bolt but you will still probably need the special tool to keep the crank from turning. There is a sticky in this section that shows how to make the tool.
  3. Jan 28, 2012 at 5:36 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    to get an impact in there u gotta pull the radiator.. when i do them i dont pull the radiator, i use a huge ratchet and chain wrench
  4. Feb 9, 2012 at 4:41 PM
    Jenkinstall
    Jenkinstall Active Member
    Jennings
    Colimbia, sc
    00 SC 4Runner Sport Edition 4wd
    Suspension/Drivetrain: 4wd swapped, E locker in rear with 4.30 gears, tundra 5100 adj. bilstein shocks, Trd coils, ome 891 springs with tundra shocks in back. Addicted offroad front tube bumper with BashFab hoops and stingaaaa, BashFab rear tube bumper, 285/75/16 BFG K02, tacoma wheels, savage offroad trans and t case skids and homemade gas tank skid. Engine: 2nd gen TRD SC, URD 7th, 2.2, TRD T-stat, IK-22 Plugs, TRD boost gauge, AEM wideband, ISR mod, and more to come. Interior: Kenwood marine stereo with Bluetooth
    u can use the impact but you have to pull out radiator i just did my t-belt last night and did that because i didn't have the special tool and it came clean off with the impact gun
  5. Feb 9, 2012 at 4:47 PM
    redneck
    redneck Active Member
    middletown DE
    04 TRD extra cab 4x4
    K&N and a Gibson cat back
  6. Feb 9, 2012 at 6:11 PM
    dorkmagus
    dorkmagus Well-Known Member
    Shane
    Bentonville, AR
    2012 Double Cab Tacoma TRD OR
    Same here, chain wrench and a large breaker bar. Then I just use a small triangle file to clean up any burrs left by the chain wrench.
  7. Feb 9, 2012 at 6:19 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    6 point socket not 12.
  8. Feb 9, 2012 at 6:27 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Breaker bar and socket......brace against frame....bump starter over. Works every time.
  9. Feb 9, 2012 at 8:24 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    This is THE single best way to do it, & its not a whackjob shortcut, it is used by mechanics all over.. Didn't we cover this last year Will ? (although it started a bit of a shit storm)
  10. Feb 9, 2012 at 8:25 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    then there's the whole tightening the bolt back down after changing the belt...:D
  11. Feb 9, 2012 at 9:13 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    no worries there steve, i've always been able to run it back down & torque to specs, gotta remember that those crank bolts have heated up & cooled off a 1000 times (expansion/contraction) plus time itself really gets a grip on threads, after its loosened you wont have the same issue, it'll torque as per usual ..I haven't had to use any thing to hold pulley while
    re torquing...;)
  12. Feb 9, 2012 at 9:17 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    You know what that makes sense.
    I just got an idea, why cant you just put the truck in gear and have the parking brake on while busting that bolt loose? Of course this would only work with a manual but still, seems like it would work.
  13. Feb 9, 2012 at 9:25 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    I tried this on my '83 solid axle, thought it might do it but still wound up using the "starter" method, it might work on some tho'
  14. Feb 10, 2012 at 2:10 AM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    +1
