Crankshaft pilot bearing counterbore
Discussion in '1st Gen. Tacomas (1995-2004)' started by pofarm, Mar 20, 2016.
  1. Mar 20, 2016 at 1:52 AM
    pofarm
    pofarm [OP] Well-Known Member
    Greg
    SW MO
    1996 Taco
    Does anyone know if the 3.4 crankshaft is counterbored for a clutch pilot bearing if it came from the factory with an automatic transmission? I have a chance to pick up a low mileage motor for cheap, but the truck is auto trans and mine is 5sp.
  2. Mar 20, 2016 at 2:31 AM
    Mach428
    Mach428 Well-Known Member
    Tom
    Ocala, Florida
    2016 Tacoma Sport Barcelona Red DCSB
    I'm not sure what you're asking here. There should be no difference in the crankshaft pilot bearing between manual and automatic. Otherwise, the manufacturer would have two different motors, and that wouldn't make sense.
  3. Mar 20, 2016 at 5:19 AM
    johnny3
    johnny3 Well-Known Member
    01 Tacoma TRD
    Automatics don't require a pilot bearing, manuals do. He's wanting to install a engine from a automatic truck into his manual truck.
  4. Mar 20, 2016 at 6:13 AM
    Mach428
    Tom
    Ocala, Florida
    Yep understood. My point is that there should be no difference in the end of the crank regardless of tranny.
  5. Mar 20, 2016 at 6:47 AM
    pofarm
    Greg
    SW MO
    1996 Taco
    That's what I wanted to know. I have seen cranks from motors with automatic transmissions that weren't counterbored. Can't remember for sure what brand, but i think it was a Chrysler product.
  6. Mar 20, 2016 at 6:51 AM
    pofarm
    Greg
    SW MO
    1996 Taco
    I found a 99 4runner with 97k that I can get the motor out of for $750.
  7. Mar 20, 2016 at 8:47 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    The cranks are the same, 1 part # for "Crankshaft, 3.4, all models".
    pofarm[QUOTED][OP] likes this.
  8. Mar 20, 2016 at 1:01 PM
    johnny3
    01 Tacoma TRD
    Good question tho, I would want to know too if I was buying a replacement engine.I know from experience Chevy v8s in mid 50's & 60's were not bored for the pilot bushings if they came from the factory with the power glide transmission.
