crankshaft position sensor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nates05tacoma, Dec 10, 2023.
  1. Dec 10, 2023 at 7:46 PM
    nates05tacoma
    nates05tacoma [OP] New Member
    Nate
    2005 Tacoma WT 4cyl
    Hi all, My 05 Tacoma needs to have its Crankshaft position sensor (CKP). I found the location but I'm having issues removing the air conditioner compressor mounting bracket. The a/c condensor was a breeze to remove but that mounting bracket is a tough one. Should I remove the drivers side tire to access those 5 bolts? I worry that I may have to disconnect the high and low pressure lines to fully access the mounting bracket. Any advice will help help a ton!
  2. Dec 10, 2023 at 8:59 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes, removing the left front tire is the “easiest” way to to get to them.
    And it still isn’t too easy or fun.
