Crankshaft position sensor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Eddy650, Jan 12, 2024.
  1. Jan 12, 2024 at 5:16 PM
    Eddy650
    Eddy650 [OP] Active Member
    2015 tacoma trd off road
    Im having trouble finding the crankshaft position sensor . Do i have to remove the ac compresor to get to it ? Tia
  2. Jan 12, 2024 at 5:17 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Yes it is behind the A/C compressor, why are you wanting to replace it?
  3. Jan 12, 2024 at 5:36 PM
    Eddy650
    Shoot thanks . So i hace to remove ac compresser to get to it ? I got code
    Р0335
    Crankshaft Position Sensor A Circuit
  4. Jan 12, 2024 at 5:38 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Is the truck running fine otherwise?
    Any other codes?
    Eddy650[QUOTED][OP] likes this.
  5. Jan 12, 2024 at 5:42 PM
    Eddy650
    Ots been sitting for a while . It use to run great . Now motor feels like it stalls. I also have p2241 i have bad o2 sensor i need to replace
  6. Jan 12, 2024 at 5:46 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    That code really needs a scope to diagnose it correctly.
    All you can do without a scope is a resistance check.
    Eddy650[OP] likes this.
  7. Jan 12, 2024 at 5:49 PM
    545 Well-Known Member
    2015 Access Cab
    If it’s been sitting, wire damage from mice?
    Try and trace the wire you can see first
  8. Jan 12, 2024 at 5:49 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Have you verified wiring is good and there is no rodent damage.
    Don't see Toyota crank sensors fail very often.
    If you do end up replacing it use OEM not an Amazon/Ebay special.
  9. Jan 12, 2024 at 5:51 PM
    Eddy650
    Shoot thanks ! Not really familiar with scope
  10. Jan 12, 2024 at 5:53 PM
    TnShooter
    Deogee
    STOCK
    Check wire integrity at the PCM. Dm93 provided the wiring diagrams above.
    If that passes, I'd feel ok throwing a CKP Sensor in it.
    Scopes are expensive, do all you can before slinging parts.
    In your case, all you can do is wire checks.
    Dm93 and Eddy650[QUOTED][OP] like this.
  11. Jan 12, 2024 at 5:54 PM
    Eddy650
    thank you appreciate it will be checking wiriring tomorrow
    Dm93[QUOTED] and TnShooter like this.
  12. Jan 12, 2024 at 5:55 PM
    Eddy650
    Thanks ! Will do that
    TnShooter[QUOTED] likes this.
  13. Jan 12, 2024 at 6:04 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Just don't shove the meter leads (or anything else larger than the male terminal) into the terminals, the pins at the PCM are very small.
    You can use a small needle, T-Pin, or backprobe to backbrobe them.
