Crankshaft pulley bolt
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaDan, Oct 9, 2009.
  1. Oct 9, 2009 at 8:01 PM
    TacomaDan
    TacomaDan [OP] Don't go off ninjin
    Daniel
    Woodland, CA
    1996 Toyota Tacoma Fully Not Loaded
    Love, Cobra 29 LTD BT CB w/ A2000 Highgear antenna, FOX/Fabtech Coilovers, Magnaflow
    This may be dumb but which way do you turn the crankshaft pulley bolt looking at the engine? im an idiot. haha
  2. Oct 9, 2009 at 8:02 PM
    Cossi
    Cossi TacoTacoTaco
    I have no clue.
    Well, it depends. Are you looking at the engine from the front or the rear?:D
  3. Oct 9, 2009 at 8:03 PM
    Cossi
    Cossi TacoTacoTaco
    I have no clue.
    Okay, seriously righty tighty, lefty loosey.
  4. Oct 9, 2009 at 8:03 PM
    TacomaDan
    Daniel
    Woodland, CA
    standing in front of the truck looking at the front of the engine
  5. Oct 9, 2009 at 8:04 PM
    TacomaDan
    Daniel
    Woodland, CA
    I thought it was different for the crankshaft bolt?
  6. Oct 9, 2009 at 8:04 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    x2
    unless its a left hand bolt
  7. Oct 9, 2009 at 8:05 PM
    Cossi
    Cossi TacoTacoTaco
    I have no clue.
    Every single one I have ever turned (i.e. thousands literally) has been a normal thread.
  8. Oct 9, 2009 at 8:06 PM
    TacomaDan
    Daniel
    Woodland, CA
    okey dokey. thanks for your help
  9. Oct 9, 2009 at 8:06 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    so lefty loosiy righty tighty?
  10. Oct 9, 2009 at 8:07 PM
    Cossi
    Cossi TacoTacoTaco
    I have no clue.
    yup
  11. Oct 9, 2009 at 8:37 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Like the other poster said "righty tighty, lefty loosey' BUT That fucking bolt is torqued to about 200 & some-odd foot pounds & can be a absolute bastard to get off the conventional way, so either get a good impact gun with the hardened socket & rattle it off or get a breaker bar (big one) with a deep socket, wedge it against a pipe or uni-strut or make sure the breaker bar is long enough to be wedged against the ground, correctly fit the head of the bolt & hold it steady from underneath & have a competent buddy hit the starter at your command & it'll break loose correctly with a solid "snap" if you will. I know it sounds a little sketchy, but I've done this about 8- 10 times & works everytime, the only other bolt I've seen torqued so hard is the glan nut on a VW 268-270 Ft. Lbs.(holds the flywheel to the end of the crank. So If your not comfortable enough with your mechanical knowledge, don't sweat it Bro' cause like I said this particular nut was/is/ & always will be a bastard.... good luck....:cool:
    P.S. If I knew where you lived I'd come over & pop it for ya so you could see how its done
    Chinle likes this.
  12. Oct 9, 2009 at 10:22 PM
    TacomaDan
    Daniel
    Woodland, CA
    So everything is back together again and i have a question. look at these pics. so should the timing belt markings line up with the markings on the pulleys or should just the pulley markings line up with the markings on the block? Here are my pics. All the markings on the pulleys line up with the markings on the block including the crankshaft.
    Edit yo: disregard the white markings on the pulleys
  13. Oct 9, 2009 at 10:47 PM
    TacomaDan
    Daniel
    Woodland, CA
    Anyone?
  14. Oct 9, 2009 at 11:06 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Are we talking 4 cyl or 6 cyl ?
  15. Oct 9, 2009 at 11:07 PM
    TacomaDan
    Daniel
    Woodland, CA
    three point four liter monster!!!!!!!
  16. Oct 9, 2009 at 11:40 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    WOW , & I thought a stubborn nut was the prob. forgive me for being stoned & stupid but was it a front seal change out or timing belt, I haven't had to do the 3.4 yet but from what I can tell from B.S. manual God help you if any crank or cam rotation has taken place without the timing belt/chains in there factory settings, if you know that theres been no movement in either the cam/valve train or crank position then I'd say you are probably ok but think about it, 24 Goddamned valves, 4 cams. From what I can gather there's a real chance of putting a valve into the top of piston if these alignments aren't right when ya fire it up. But then again all you wanted to know was which direction the crank bolt tightened up... What the hell am I trippin' on. If you listen to me you'll have your motor yanked & torn down in your living room....:confused:
    P.S. just say no !
  17. Oct 9, 2009 at 11:42 PM
    TacomaDan
    Daniel
    Woodland, CA
    umm ya... i already got past the crankshaft bolt. i forgot to mention that tho. my bad.
  18. Aug 27, 2017 at 6:43 PM
    Mike65
    Mike65 New Member
    97 Tocoma 4x4
    K&N inductor
    Tried all those still Will Not budge!!
  19. Aug 28, 2017 at 7:22 PM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    If you installed the timing belt with the marks aligned and then rotated the whole thing by turning the crank shaft pulley, the timing marks on the timing belt go out of wack. They are only useful for installing the belt. After you turn the crankshaft use the marks on the cranks shaft pulley and the cam pulleys to make sure the timing belt is correctly installed. Set the crankshaft pulley on tdc and then make sure the cam pulleys are on their marks.
    PapaBear likes this.
  20. Aug 28, 2017 at 7:27 PM
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    Please explain to me how you people have the time to find and resurrect these deep dark threads? :notsure:
    Dalandser likes this.
