Crankshaft Timing Pulley Removal help
Discussion in '1st Gen. Tacomas (1995-2004)' started by StAndrew, Feb 20, 2016.
  1. Feb 20, 2016 at 1:09 PM
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Need to remove the crankshaft timing pulley to get the oil pump off. In the manuals, it requires the Toyota Puller set 09950-50012 which goes for $500ish.
    Anyone know a cheaper puller or better way to get this off? I don't want to use jaw pullers that might put burs on the pulley and f-up the timing belt.
    Timing Pulley:
  2. Feb 20, 2016 at 1:13 PM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    So this pic is of your motor?
    I had trouble with the fan belt pulley.
    But if ur just talking about the splined timing belt pulley shown mine came off really easy just try using a pry bar behind it.
  3. Feb 20, 2016 at 1:18 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Would rather not use the pry bar just yet, or at all... If I knew what the treading was for the two puller holes, I could probably make a ghetto puller.
  4. Feb 20, 2016 at 1:28 PM
    Catcrazed
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    I'm sure it just M6 or m8. But it should come off easy.
  5. Feb 20, 2016 at 1:29 PM
    Catcrazed
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    What puller did u use for the damper?
  6. Feb 20, 2016 at 1:37 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Its pretty stuck :notsure:
    They belt pulley was stuck good too.
    I used a pry bar and damaged the damper. So I just heated it and hit it with a hammer until it got loose and slid it off.
  7. Feb 20, 2016 at 1:42 PM
    Clearwater Bill
    Billy
    Largo Florida
    Have you tried removing that key? If you could get that out, the gear may come off easier. You could at least wrap the old belt on it and get some leverage to try and break it free.
    Try any PB blaster, etc.? Plastic or hard rubber hammer will preclude gear damage if it needs a few whacks.
  8. Feb 20, 2016 at 1:44 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    What key?
  9. Feb 20, 2016 at 1:57 PM
    Clearwater Bill
    Billy
    Largo Florida
    In the pic it looks like there is a key just to the left of the centerline. No?
    There has to be something that 'lock's the gear to the crank to retain position.
    If there is no key there, my apologies........... but I'd be curious to know what serves to hold the gear from rotating on the crank?
  10. Feb 20, 2016 at 2:03 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    No, I think the 4 cylinders have a "key" but its like a half circle (???). The 5VZ doesn't. Nothing is locking it in place, I just think it was pressed on. Its probably not on too tight but there's no way for me to get a grip on it and the damn thing is so far back, there is no way to get a pry behind it.
    I did find the threading. I used an old 10mm bolt from one of the brackets secured to the body and it threaded right in (M8 or M10?). Also found two "universal" puller kits:
    http://www.ebay.com/itm/BOLT-PULLER...8970&clkid=3461627769454313219&_qi=RTM2247626
    http://www.ebay.com/itm/Crankshaft-...8970&clkid=3461628140326866010&_qi=RTM2247625
    But they don't specify the thread size.
  11. Feb 20, 2016 at 2:06 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  12. Feb 20, 2016 at 2:10 PM
    matt 157
    matt 157 Well-Known Member
    California
    2003 Black Xtra Cab 4WD SR5 TRD
    Pioneer DEH 8400 head unit/deck, Crunch 1100 watt amp, 12" Kenwood subwoofer, Kicker mids & tweeters, AllPro front tube bumper, Smittybuilt tow hooks, (welded pipe for muffle) straight-pipe, 4 orange "Raptor" lights in grill, Duratrac tires, American Eagle rims, ProComp 2" front leveling kit, Plasi-Dipped black on chrome trim, PIAA fog lights w/ in-cab switch, Unidin CB/Firestik II/8 ohm PA speaker, TRD leather 5-speed shifter knob
    This took me hours with my dad to figure out. We made a crank puller/breaker bar thing and even tried a chain rental one, but we ended up combining me pulling clockwise with the crank puller and him loosening the bolt (counter clockwise) with the air wrench (simultaneously) at like 170psi, just took rediculous force but we go it lmao good luck. And yeah use plenty of PB Blaster it's a godsend
  13. Feb 20, 2016 at 2:14 PM
    Clearwater Bill
    Billy
    Largo Florida
    So that's not a positioning key?
  14. Feb 20, 2016 at 2:27 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    It looks casted into the crank?? Ill take a look at it but I don't think it comes out.
    Damn, don't tell me that. Tell me it'll be easy and shit.
  15. Feb 20, 2016 at 4:09 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    That is in fact a key, it locates the crank pulley, t-belt pulley and the crank sensor wheel behind it. I have removed at least a dozen and about half slid off after very light persuasion with a pry bar. The rest slid right off after breaking loose with a 2 bolt puller as shown below. I would not call the pulley an interference (press) fit. If it is, it's a "sliding" or "running" interference fit and "new", in the absence of any corrosion it should come off by hand. It should be simple enough to fab something up.
    It's going to take a bit of "finesse" to pull the pump without dropping the oil pan.
    StAndrew[OP] likes this.
  16. Feb 20, 2016 at 4:43 PM
    Clearwater Bill
    Billy
    Largo Florida
    Well, that makes me feel better. At least I'm not blind :thumbsup:
  17. Feb 20, 2016 at 5:57 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Oil pan was dropped today, thanks for the input. You know exactly what thread bolt it took by any chance?
  18. Feb 21, 2016 at 9:21 AM
    skeezix
    skeezix Ol' Geezer
    Western Slope of Colorado
    1998 Limited
    Go to OReilly's or Autozone (or whatever's local for you) and ask to borrow a pulley puller. Use your credit card or a $50 bill for a deposit that will be refunded when you return the tool. That's what I did. Took 45 minutes from when I pulled out of the driveway to when I pulled back in again after returning the tool. After a little "pop", the pulley came right off.
    Or just buy one.
  19. Feb 21, 2016 at 9:31 AM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    I used a puller with bolts threaded into those holes, and then I still had to lightly heat the gear with a torch before it came off. It is definitely keyed in place so it won't turn on the shaft.
  20. Feb 21, 2016 at 4:47 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Ill check it out.
    Next question; how do you get it back on? And how does the "key work? As I replace the oil pan, are there any necessary steps to take to make sure timing doesn't get messed up?
