Crap center console USB port?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RWTaco, Nov 28, 2020.
  1. Nov 28, 2020 at 5:10 PM
    RWTaco
    RWTaco [OP] Well-Known Member
    Red Wing MN
    2020 SR5
    Does anyone have a problem with the center console USB port charging their phone? Mine charges for 20 sec, then stops for about 2 sec, then starts again for 20 sec... It is super annoying at night to have my phone screen light up constantly. I've looked around but haven't seen any threads about this.
  2. Nov 28, 2020 at 5:12 PM
    philth
    philth .
    Your cable is probably shot.
    AjaxTaco likes this.
  3. Nov 28, 2020 at 5:14 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    HU can only provide small amps the that USB socket, it’s designed for playing not charging modern phones. If you want to charge, replace the cig lighter with USB ports, if you want to charge and play, you can snip the power wires and run your own charger, or add up a few cables for a “plug n play” solution.
    edit think it’s limited to 500ma, so only enough to trickle charge older phones, or phones that can charge on original USB spec.
    RWTaco[OP] and jmneill like this.
  4. Nov 28, 2020 at 5:42 PM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    i don't use it for charging because it has my usb drive in it for music but i never have a problem with that fwiw. any time i have an issue like you're describing, it's usually the cable
  5. Nov 28, 2020 at 5:44 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    X2
    SJBrown likes this.
  6. Nov 28, 2020 at 5:46 PM
    CocaineAndCreatine
    CocaineAndCreatine Strong in arm and weak in head
    Portland, Oregon
    2018 Beige DCSB OR
    SCS F5s
    Check your phones charging port also. Mine collects pocket dust like nobody’s business. I have to set the plug in at a certain angle for it to begin charging and the vibrations while driving mess with it.
  7. Nov 28, 2020 at 5:50 PM
    Matt Sierra
    Matt Sierra Well-Known Member
    NorCal
    2020 TRD Pro MT
    Maggy SC, C4 Overland front bumper
    I haven't had an issue with either the center console or head unit USB ports on my 3rd gen.
  8. Nov 28, 2020 at 5:51 PM
    tonykarter
    tonykarter Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    Yes, agreed its not for charging: My I-phone was like 6% the other day and i plugged it into that port. It died shortly after that. Took same charging cable and connected to plug in dash. Starts charging.
    RWTaco[OP] likes this.
  9. Nov 28, 2020 at 5:58 PM
    Hafaday
    Hafaday Well-Known Member
    Bill
    Richmond, VA.
    19, DCSB, Off Road. 23 KLX300, 14JKU
    No issue at all charging up the phone with either USB port in the center console cubby. The one in the dash below the radio is for music from a USB flash drive or the like.
  10. Nov 28, 2020 at 6:03 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Media port (under head unit) charged my phone (Samsung Note 10) from 6% to 85% in just under 1.5 hours.
    Haven't tried the center console plugs yet.
  11. Nov 28, 2020 at 6:04 PM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Are you talking the one in the dash or the one in the armrest? My ipod is always in the dash usb, so I don't know about that one. The armrest charges my phone just fine. I also swapped the cigarette lighter spot for a double USB for charging and it works great.
  12. Nov 28, 2020 at 6:05 PM
    jmneill
    SE
  13. Nov 28, 2020 at 6:33 PM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    No issues with either ports with my OnePlus 7 pro or the work issues iphone 7.
    Sure it's not warp charge and it goes off with the ignition switch but both work. You might have a bad cable. The contracts on my iphone cable were a bit dirty and it would not charge a few weeks ago. An Alcohol wipe fixed it.
