crap....mixed syn gear lube with dino gear lube
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SalC, Nov 5, 2018.
  1. Nov 5, 2018 at 3:25 PM
    SalC
    SalC [OP] New Member
    decided to change my fluids, since they never have been changed. Just did the rear diff today. Called for 3 quarts of 75-90. I had purchased fluids for the tranny and transfer case. I accidently used a quart of the Syn I had bought for the tranny. Will there be any harm in the rear mixing them together. Or should I drain it and start over? Will do the front diff tomorrow if I can break loose the drain plug. I must have spent 4-5 hrs on the rear. Plugs are really hard to get off after 75K miles!!! 2010 Taco TRD 6 sp manual (very hard to find)
  2. Nov 5, 2018 at 3:34 PM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    You'll be fine. Gear oil is gear oil - no adverse reaction can occur.
    In fact - you may have done yourself a favor. The gear oil you bought is probably GL-5. The 6MT really prefers GL-4. Lots of people, myself included, like the Redline MT-90 for the transmission.
    Lester Lugnut likes this.
  3. Nov 5, 2018 at 5:17 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    You just used a synthetic blend is all ;-) I dont think you will have any issue.
    For the plugs I found if you spray on PB blaster on prior and let it sit a good 20 min then use a little heat from a small propane torch they come out like a champ!
  4. Nov 5, 2018 at 5:19 PM
    medic2230
    Murph
    Bama! Roll Tide
    Shit gonna blow up.
    You'll be fine brother.
  5. Nov 5, 2018 at 5:45 PM
    SalC
    thanks for all the positive thoughts. Getting some PB blaster tomorrow
  6. Nov 5, 2018 at 5:47 PM
    stinger86
    stinger86 Well-Known Member
    San Diego, CA
    2016 Double Cab Limited
    Part out!
  7. Nov 5, 2018 at 6:58 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I always use Telfon tape on my drain and fill plugs. I've never had trouble getting them out. I think it works better than anti seize.
    And, you don't have to torque the crap out of them. The tape adds a little more friction so they won't vibrate out if they're not blue torque tight. Your mileage may vary.....
  8. Nov 5, 2018 at 7:08 PM
    kidthatsirish
    Probably not a bad idea...I used a dab of blue TV sealant on the threads then tightened them....I imagine yours has a similar effect, but you dont have to scrub the threads with a brass brush when you do your changes!
  9. Nov 5, 2018 at 7:16 PM
    ljma90
    ljma90 Well-Known Member
    Jordan
    2007 Toyota Tacoma v6 4x4
    2.5 inch suspension lift front with rancho 9000 quick lift struts, rear rancho shock absorbers with 2.5 inch sky jackers add a leaf springs in rear. extra 2 inch long braided front brake lines with radiator flush, transmission flush, brand new front brake rotors, calipers, and shoes all done myself. more to come
    gonna spontaneity combust now
