Crap... put 6 quarts of oil in. Could that damage it?
Discussion in '1st Gen. Tacomas (1995-2004)' started by x2468, Dec 28, 2010.
  1. Dec 28, 2010 at 8:28 PM
    x2468
    x2468 [OP] Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Ug, my stupid self poured all 6 quarts of mobil 1 into my truck just now when I know it should only be 5.5. I thought i was on my 2nd to last quart when in fact i was on the last. Will that extra pint damage any of the oil delivery equipment? I know that will motorcycles it can be bad to over fill the oil because it can damage the oil pump, oil valves and put pressure on the bottom of the pistons etc.
    I really don't feel like draining all the oil out and putting 5.5 quarts back in. If it really is a problem, is there an easy way to drain that half a quart?
  2. Dec 28, 2010 at 8:33 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you may be able to take the filter off and either dump whats in it...or install a mobil1 m1-209 filter.......i think its same size as normal, but a bit longer...and will be able to handle the other half a quart.
  3. Dec 28, 2010 at 8:34 PM
    x2468
    i always remove the filter after draining the oil out of the drain bolt. if i remove the filer while the engine is full of oil, won't all the oil just gush out?
  4. Dec 28, 2010 at 8:36 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no............it only cycles thru the filter. the rest is in the sump.
  5. Dec 28, 2010 at 8:36 PM
    PWhite13
    PWhite13 Well-Known Member
    Prescott
    Southern California
    06 Silverado Crew Cab 5.3
    Couldn't you just put a quart sized container under the drain bolt and loosen the bolt slightly to where it leaks out, and fill the container?
    Edit: A half-quart sized container:eek:
  6. Dec 28, 2010 at 8:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Honestly, I dont think a half quart would cause any damage, however, when I catch myself doing the same thing, I drain out the .5 quart thru the drain plug.
  7. Dec 28, 2010 at 8:47 PM
    x2468
    well, maybe others will have better luck, but i just found out the hard way that my drain plug does not leak at all until the bolt is completely out. This left me laughably feeling for the hole in a panic as I made a mess of myself..... which has never happened to me with cars before...
  8. Dec 28, 2010 at 8:55 PM
    PWhite13
    Prescott
    Southern California
    :eek:
    :eek: Sorry
  9. Dec 28, 2010 at 9:01 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yep, sounds like the easiest fix for this dilema.....;)
  10. Dec 28, 2010 at 9:03 PM
    x2468
    ya, i took out a little over a quart and put 700ml back in. a little more than half a quart to make up for what got all over the skid plate, floor and my arms.
  11. Dec 28, 2010 at 9:13 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  12. Dec 28, 2010 at 9:19 PM
    x2468
    damn.... i wanted a magnetic drain plug like the one i have for my bike do detect and metal fragments in the oil..... but i might get that instead
  13. Dec 28, 2010 at 10:02 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Ha well that blows. Oh well you live and learn... ;)
  14. Dec 29, 2010 at 12:44 AM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    If you would have looked at the dipstick you would have noticed the oil level just below full. 6 quarts is fine.
  15. Dec 29, 2010 at 9:22 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Drain 1/2 out, lesson learned, they don't tell you to not overfill just to waste ink and paper there is a reason for this!
  16. Dec 29, 2010 at 11:45 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    hehe ive been always putting in 6 qts
  17. Dec 29, 2010 at 12:11 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    1/2 quart too much isnt going to be a problem anyway. I would just leave it and remember for next time.
  18. Dec 29, 2010 at 12:28 PM
    BoostingMS6
    BoostingMS6 Well-Known Member
    Alex
    El Paso, TX
    1995.5 Tacoma Xtra Cab V6
    Put your dipstick in, wipe it off. Put your dipstick in, wipe it off. Keep doing for the whole half quart ;)
    No but really the Fumoto cap may be a good investment. Or the Oil Change Wonder. I'm ordering one for my next oil change :)
  19. Dec 29, 2010 at 5:13 PM
    redneck
    redneck Active Member
    middletown DE
    04 TRD extra cab 4x4
    K&N and a Gibson cat back
    been running 6 qts in mine since new with no problems
  20. Jan 6, 2011 at 2:55 PM
    nOLd
    nOLd Well-Known Member
    nold
    Dallas
    :rofl::rofl::rofl:
