Crap... put 6 quarts of oil in. Could that damage it?
Discussion in '1st Gen. Tacomas (1995-2004)' started by x2468, Dec 28, 2010.
  1. Jan 6, 2011 at 2:57 PM
    nOLd
    nOLd Well-Known Member
    nold
    Dallas
    so what is the correct capacity 5 quarts or 6 quarts for the 2.7 second gen? Manual says 6.1 quarts
  2. Jan 6, 2011 at 3:05 PM
    Rufus
    Rufus Well-Known Member
    SoCal
    2010 TRD PreRunner Sport
    OEM Truck Bed Extender, Window Tint, Tailgate Security Mod, OEM Spare Tire Lock, Cam Locks (storage compartments), OEM Bed Mat, OEM Skid Plate, Stant 11504 Locking Gas Cap, TW Edrin55 OEM Running Boards, Pop & Lock w/Back-Up Cam, Black WeatherTechs, Red Line Quick Lift Plus Hood Struts, Wet Okole Front Seat Covers-black/charcoal with red & white TRD graphic & back seat pockets, DIY Satoshi Grillcraft & Old School Toyota Badge, TW ZonKs Black UWS Low Pro Truck Box, Rear Suspension TSB, 3M Scotch Guard Paint & Headlight Protection Film 8mm Urethane, Flyzeye V2 Wired Amber/White/Amber Interior LED Lights w/Silver Case, Sleek Looking Black LED Tail Lights from K2 Motors (Identical to OEM, but black).
  3. Jan 6, 2011 at 3:40 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    I always put 6 quarts in. Doesn't even register above the top line anyway.
  4. Jan 6, 2011 at 3:45 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
  5. Jan 6, 2011 at 7:27 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Mine says 4.5... I've always put in 5 and its still within range
  6. Jan 7, 2011 at 12:47 AM
    pittim
    Pennsyltucky
    Boujee Prius
    hey guys aiahow do i raind oil
  7. Jan 7, 2011 at 1:32 AM
    Manwithoutaplan
    ID
    you are fine!!!
  8. Jan 7, 2011 at 7:51 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    What he ^^^ said till you blow a front or rear main seal.
  9. Jan 7, 2011 at 8:07 AM
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    I think you will be fine. right after startup and the oil pressure immediately builds, that extra 1/2+ quart is circulated and the pan level drops. Once you hammer on the throttle, even more is pulled out of the pan and circulated, thus the level drops again, and you would be suprised at just how low it does drop.
    It looks like a Mixmaster set on high inside there once stuff starts rotating.
    The only problem would be right at startup and the crankshaft is banging the oil pool in the pan and splashing extra up on the cylinder walls,,but I don't know if that would even happen, just depends on the pan design and how low the crank sits in the block in relation to the proper oil level.
    FWIW, the 99 3RZ's take exactly 5 quarts for a perfect mark on the stick.
  10. Mar 16, 2014 at 11:54 AM
    Flugelhornjazz
    Flugelhornjazz '06 4.0L 4x4 6-sp MT Access
    New England
    06' 4.0L 4x4 6sp MT Access
    AFE CAI, all synth fluids, 2.5" exhaust w/ FlowMaster, Optima Deep Cycle battery, Fog mod, SnugTop cap, HID headlights, silicone hoses
    I'm with Tacomaman06. Replace the oil filter with a tall version. The Amsoil part number is 034 (e034, something like that). I run my '06 a little more than the top of the dipstick. I have never seen froth on the dipstick (crank journals stirring the oil, etc.) I cannot get away with that in my wife's 2001 Passat however. I smell oil burning any time I fill the oil to the top mark of the dipstick. :cool:
  11. Mar 16, 2014 at 11:59 AM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    Holy thread revival
  12. Mar 16, 2014 at 2:16 PM
    Tinmann
    Tinmann Well-Known Member
    NorCal
  13. Mar 16, 2014 at 3:57 PM
    trdtoy
    trdtoy Well-Known Member
    North Carolina
    02 sr5 4x4 auto v6 turbo (sold)
    Turbo with supporting mods and tranny to hold power.
    I always ran 6qt in mine with tall filter and ensure complete drain each time. Never had an issue. Now one time I had a shop change my oil and they changed filter, added 5.5qt, did not check oil level, and did not drain old oil. It ran rough a short time before I figured out the cause. Long story short it did not cause any serious damage in the short term when this happend and I changed my own oil ever since or watch while someone else does it.
  14. Mar 16, 2014 at 5:50 PM
    jdkilroy
    jdkilroy Well-Known Member
    Jon
    Southern NH
    '02 4x4 SR5 Access Cab
    Never had an issue with overfilling by 1/2 quart (pint). The engine allows for that variation in volume. That volume puts the oil level at the top of the dipstick full mark in our trucks. (after the engine has been run with a new oil filter installed with oil change)
    And to eliminate any question of quality: use an OEM oil filter
  15. Mar 16, 2014 at 11:35 PM
    #35
    40950
    CR, WA
    stock
    3 years?,,time to change oil again.
  16. Mar 17, 2014 at 5:02 AM
    #36
    budget76
    budget76 Active Member
    New Jersey
    98 xt-cab 4x4 4cl/2.7 stock man
    soon want dual lockers Picture was my 85 dual arb great
    don't waste it. it is good oil. great for topping off when you start to go low. or use it in your lawn mower. just because it ran for a few hunderd miles doesn;t mean it is bad.
