crappy ride after new wheels and tires
Discussion in 'Wheels & Tires' started by bajamoon, Mar 10, 2009.
  1. Mar 10, 2009 at 2:31 PM
    bajamoon
    bajamoon [OP] Well-Known Member
    STEVE
    Whittier
    had the 5100's put on two weeks ago and had a better ride than stock, put new wheels and tires on saturday with bfg at and what a shitty ride. was it going from 16's to 17's, would tc ucs with the uniball help along with camburg coilovers. i want those anyways but just can't let go of that much money. i have had bfg at before and the ride was not this bad.
  2. Mar 10, 2009 at 2:32 PM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    bad alignment? bad balance?
  3. Mar 10, 2009 at 2:32 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    What is the air pressure set at?
  4. Mar 10, 2009 at 2:32 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    x1
    did you get ur truck aligned after the lift?
  5. Mar 10, 2009 at 2:33 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    probably a combination of tire size, the fact that they are bfg at's, and where the shocks are set at. the higher you have the shock set, and with that heavy of a tire(those bfg's are pretty heavy) can make for a pretty stiff ride.
  6. Mar 10, 2009 at 2:39 PM
    bajamoon
    STEVE
    Whittier
    balance is good, no vibration, at least not below 85. stiff ride when hitting pot holes and such, i will get it aligned again. had it aligned after the billys were put in and it was sweet. tire pressure is set at 35#, that was the first thing i checked and 4wheelparts had them set at 40#. are you guys trying to talk me out of buying new coilovers and uca's. i love you guys and thanks for the info.
  7. Mar 10, 2009 at 2:40 PM
    bajamoon
    STEVE
    Whittier
    the shocks are set at 1.75, want to go higher but did not want to deal with any vibs, i might if i get the coild overs.
  8. Mar 10, 2009 at 2:54 PM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    If it's a stiff ride that you are referring to? Then try lowering the tire pressure.
    But if it's poor handling? Then you need a set of UCA's.
  9. Mar 10, 2009 at 2:56 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    what load range tire did u get.that makes a big diff.
  10. Mar 10, 2009 at 3:16 PM
    bajamoon
    STEVE
    Whittier
    i lowered the pressure to 35# and is about the same, the load range is 'c', 2480 lbs.
  11. Mar 10, 2009 at 3:50 PM
    DNahas
    DNahas Well-Known Member
    Dallas
    09 DC 4x4 OR
    Care to elaborate?
  12. Mar 10, 2009 at 4:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    BFG's have a 3 ply sidwall. Much more stiff on the road, as the sidewall has less flex to absorb the bumps.
  13. Mar 10, 2009 at 4:27 PM
    bajamoon
    STEVE
    Whittier
    now you tell me :D. chris do you think the uca's will help the ride.
  14. Mar 10, 2009 at 4:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They will get your alignment back in spec, and may help a little.
  15. Mar 10, 2009 at 9:09 PM
    Good351
    Good351 Well-Known Member
    Ames, IA
    03 4Runner V8
    What is the tire size? What is the rim size?
  16. Mar 10, 2009 at 9:57 PM
    bajamoon
    STEVE
    Whittier
    17's, tires are 265/70/17
