Crappy workmanship
Discussion in 'Off-Topic Discussion' started by SamS, Dec 30, 2022.
  1. Dec 30, 2022 at 12:37 PM
    SamS
    SamS [OP] Well-Known Member
    Vancouver Island, BC, Canada
    06 Access cab 4x4
    How do you deal with a company you hire, but the work is done sub-standardly?
    I called a company to replace all the connectors that join the downpipes to the roof gutters. Well, they did that with cheapo plastic inserts, but failed to apply caulking properly. Some were dripping before they left and some I could see the sky looking up through the cracks. Got em to go back up. They reapplied caulk. Now some still leak. Haven’t paid yet. What would you do? I don’t really want another half assed application of caulking. The contract didnt have much in it. Just basically replace inserts. But the invoice has a line added about caulking not guaranteed because of dirt.
  2. Dec 30, 2022 at 12:40 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Where was this company in the price range compared to others? Cheap? Expensive? Down the middle?
  3. Dec 30, 2022 at 12:41 PM
    SamS
    06 Access cab 4x4
    One and only. I thought it was inexpensive, and i wanted it done fast.i didn’t tell them i wanted it fast. I just went with them.
  4. Dec 30, 2022 at 12:42 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    May have been inexpensive for a reason. Hard to tell without getting some comparable quotes
    23Skidoo likes this.
  5. Dec 30, 2022 at 12:45 PM
    ColdTaco49
    ColdTaco49 Has a well-used member
    Fairbanks, Alaska
    2022 TRD Off Road DCLB Lunar Rock
    Don’t pay. I ran into this with my roofing company. I didn’t give them the remaining $7500 until they came out and finished the work correctly. I told them for $15000 everything should look at a minimum the same as before they started, not worse.
    4x4spiegel and PzTank like this.
  6. Dec 30, 2022 at 12:59 PM
    SamS
    06 Access cab 4x4
    So don’t pay until they come out and do another minimal caulking coverup?
    I’d guess they’d have no problem coming out again if i raise a stink. But i have no confidence in the fix lasting very long. How to protect myself from getying ripped off if it leaks in a couple weeks after I pay?
  7. Dec 30, 2022 at 1:09 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    You can post a negative review somewhere.
  8. Dec 30, 2022 at 1:16 PM
    Beaner Taco
    Beaner Taco Well-Known Member
    WV
    '17 SR5
    A technique (take it or leave it) is to pay them a little but retain more than what it will take get someone else to make it right. Then agree to a timeline for them to fix it and if they don’t then use the balance to have it fixed. Just don’t pay the full amount until you’re satisfied that they met what they agreed to contractually.
    It could be a good owner/manager and crappy employees since they returned to fix it once. Seems to be more common now. Others will say not to pay them a thing but they do have costs and it’s a good faith thing. But make sure the balance will cover the repairs.
  9. Dec 30, 2022 at 1:17 PM
    Big Foot
    Big Foot Well-Known Member
    Washington
    2014 DCLB
    Why the added line about no guarantee because of dirt? Didn’t they clean them first? Or they were dirty again by the time they came back out?
  10. Dec 30, 2022 at 1:36 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Being your in Canada Things could be very different.
    It might come down to just how the first work order was written.
    If it said just replace inserts no mention of quality . Nor the fact they needed to be 100% leak free.
    Then did you need to sign the invoice that stated things were to dirty to caulk properly ?
    Good luck!!
  11. Dec 30, 2022 at 1:37 PM
    SamS
    06 Access cab 4x4
    The first guy to come out and give an estimate I assume would factor in that the gutters are not clean and dry. I suspect the workers maybe pushed some muck aside with their gloves based on how much dirt they left from handling the downpipes. That’s probably why the caulking is failed if they applied on unclean wet surfaces. They realized they did a crappy job and add that line to the invoice so if i ever come back to complain they will just point to the invoice and say “See, not covered.”
  12. Dec 30, 2022 at 1:39 PM
    SamS
    06 Access cab 4x4
    Nothing was ever signed. Verbal over the phone.
  13. Dec 30, 2022 at 1:40 PM
    SamS
    06 Access cab 4x4
    In Canada small jobs are “gentlemen’s agreements”. Good faith etc
  14. Dec 30, 2022 at 1:50 PM
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    I’m a contractor/carpenter. I just had gutters put on my house. My cheap guy will install “ok”, but usually with some issues. My mid price guy does a decent job, but doesn’t design the system very well. My most expensive guy does it all perfectly. I went with my expensive guy, less headache, better final product. They don’t expect to get the final payment until I’m satisfied.
    Always get multiple bids, ask for referrals.
    Wadar and b_r_o like this.
  15. Dec 30, 2022 at 2:02 PM
    SamS
    06 Access cab 4x4
    But when it’s so basic with only two steps. In my opinion, the cheap guy might use plastic parts. The expensive guy will use metal and will sweep up. But i expect all would do the minimum so it doesnt leak.
    HondaGM likes this.
  16. Dec 30, 2022 at 2:53 PM
    23Skidoo
    Paul
    meme
    The cheap guy/gal might use cheap painters caulk because he’s just a handyman. The expensive guy/gal would use gutter sealant… might also tell you that your gutters are undersized and aren’t draining the water fast enough. That’s where several opinions/bids come into play.
  17. Dec 30, 2022 at 3:36 PM
    SamS
    06 Access cab 4x4
    Agreed, but i’ll say it again, there is an expectation of a minimum requirement. The consumer shouldn’t be blamed or forced to accept a failed job for going with the cheapest. I can live with the fact the parts are plastic and wont last long. But I can’t handle that things are leaking from the get go.
  18. Dec 30, 2022 at 4:33 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    But that's the entire point of getting a few estimates.
    Let's say you need a timing belt replaced on your vehicle. If you call 4 shops, 3 of them are around $1,000 and 1 of them is only $400, are you going to expect the cheap shop to do a good job? How are they getting it done for only $400? Most likely with cheap parts and cheap labor and cutting corners.
    Calling a few more gutter outfits and asking about sealant, technique and warranties would give you more perspective about what to expect.
  19. Dec 30, 2022 at 5:12 PM
    SamS
    06 Access cab 4x4
    The whole point of my OP was to ask what to do about the current predicament. I will stand by that even by choosing the cheapest option one should get a reasonable conclusion not one that requires a while new repair. The job wasn’t complex.
  20. Dec 30, 2022 at 5:18 PM
    SamS
    06 Access cab 4x4
    Lesson learned. I will ask all these questions, signed in a contract in front of witnesses and a lawyer.
    Dear company #2, will you actually apply caulking so the gutter wont leak at the seam where the downpipe and gutter leak. Oh and will you fasten everything with metal screws torqued to standard. Will you use certified safety gear. Will you not scratch my house with your ladder. Will you work between 8-4. Will you not take a sh*t on my lawn.
    Anything else?
