Crashnburn80's 1st Gen TRD Double Cab Build
Discussion in '1st Gen. Builds (1995-2004)' started by crashnburn80, Apr 16, 2022.
  1. Jan 2, 2023 at 10:32 AM
    #261
    MGMDesertTaco
    I'm curious to see what suspension system or components you're pondering for this build. :popcorn:
    ExplorHer and crashnburn80[OP] like this.
  2. Jan 2, 2023 at 3:25 PM
    #262
    gpdx
    gpdx Well-Known Member
    Portland
    13 DCSB TRD Offroad
    5100/887, topper, rack, 265/75/16
    This thread makes me miss my 97 ext cab.
    Edit to add photo. It's up in the Seattle area now. Had 275,000 on it and still going strong when I sold it.
  3. Jan 2, 2023 at 4:19 PM
    #263
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Likely Bilstein 6112s and 5160s, which are used as the platform for the OEM Baja/Pro lifts on 2nd Gen. I really liked the Baja kit on my 2nd Gen. The 6112/5160s are a good middle ground that performs well without being unreasonably expensive and substantially better than the typical 5100s. Bilstein also seems appropriate for the era of the truck. Might opt for the SPC UCAs, it would be the right thing to do, but TBD since it isn't a daily driver. There are a few different rear leaf options I've looked at, but haven't narrowed it down to anything yet. I like a firm controlled but not harsh ride, and want zero float on rebound. I realize this truck isn't a sports car, but I still like crisp responsive suspension and handling. The basic goal will be to emulate the successes I've had in my 2nd Gen build.
  4. Jan 12, 2023 at 5:49 AM
    #264
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    BatteredTaco and Madjik_Man like this.
  5. Jan 12, 2023 at 6:20 AM
    #265
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    I've been wanting to try this. I saw someone on TW here also swapped IS 300 stalks into their Tacoma with plans to wire up the fog light switch, but never completed the wiring.
    I've got a junkyard stalk in my parts bin. I think it's from a Celica. Maybe a Camry. I forget. I haven't actually tried it for fit yet... fingers crossed that it works.
    Keep an eye on the angle of the stalk you buy. Some are straight and some have a slight bend to them. You might need to swap both your light and wiper controls to keep a consistent look on both sides of your steering wheel.
    For wiring, Diode Dynamics has some harness kits that look perfect... they'll give factory-like controls (on with low-beams, off with high-beams) for aftermarket lights. https://www.diodedynamics.com/accessories/wiring-and-install.html
  6. Jan 12, 2023 at 1:15 PM
    #266
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yeah, if you follow the thread post all the way down they note the different angles and what to use to match the angle on the opposing side. The ones used in that post are angled up slightly more than the Tacoma using the 4runner units, but lists part numbers to match the angle up on the other side with another Toyota stalk.
    On the DD wiring kit, the 1st Gen factory wiring is ground switched instead of the more common power switched like 2nd Gen+. It will depend on how the wiring is setup to make it work. If taping a circuit to see if the headlights have power for example to enable the on functionality, the headlights are always powered, but they are not always grounded. So if you use a battery negative or factory ground the lights will always be on.
    Looking at the wiring diagram, the activation input wire will always be powered on 1st Gen and the harness has one ground. If you tap both power and the headlight ground wire on the headlight circuit, rather than the factory ground or negative battery, I think it should work. I'm less sure on how the high beam power works to switch between high and low without testing it or looking at a wiring diagram. The high beam would need to switch power from the low beam to the high beam circuit to allow functional use of the deactivation wire. I might give that a try. Current thought is to run 4 SSC1 Max fogs in the lower valence. Wish DD would make a SSC2 Max fog. Admittedly the Morimoto 2banger HXB is tempting for the purpose with the better packaging.
    DD fog harness:
  7. Jan 12, 2023 at 1:49 PM
    #267
    6P4
    Colorado Springs
    I thought 1st gen headlights could be either ground switched or power switched depending on whether they were equipped with daytime running lights? That was the impression I got from reading around on the forum here, but I wouldn't be surprised if I was reading bad info or misinterpreting things.
    Regardless, mine is ground-switched--I had to confirm that when I bought my Headlight Services upgrade harness.
    I hadn't looked at the Morimoto pods. The design is more aesthetically fitting for a 1st gen. Looks like they only come in cool white or yellow, though? I like the 4000k white from Diode Dynamics.
    I don't see an SSC1 Max on DD's website... just Sport and Pro. What am I missing?
  8. Jan 12, 2023 at 4:42 PM
    #268
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Correct, they could possibly be power switched if having DRLs. Ground/power switch test procedure (for others as you obviously checked) is specified in the 2nd Gen headlight thread. Same procedure for 1st and 2nd Gen.
    My thought it to mount the fog here, ideally in 1 1x2 pod.
    For the SSC1 Max, DD just refers to it as the SSC1 SAE Fog. It is the Max architecture and uses the HXB LED.
    https://www.diodedynamics.com/stage-series-c1-yellow-sae-dot-fog-standard-led-pod-pair.html
    I reviewed them in the SAE thread in post #6468, determining that I'll need 2 sets of them to get the output I'd like.
    I wouldn't call the 1x2 Morimoto pods much better looking than Diodes when the'll be recessed in the lower valence where you'll just see the face.
    Vs Morimoto 2banger
    Yes, the banger pods are only available in 6000k white or selective yellow. For fogs, selective yellow is a better performing option in cold weather and the lenses run hotter. I'd want yellow for fog so lack of 4000k is a non-issue. The DD 4000k is quite nice, I'd definitely use it for a driving light color. As covered in the Morimoto 4banger HXB review, the Morimoto's pattern isn't nearly as wide as the Diode Dynamics fogs.
    What I do like about the 2bangers is they are available with the powerful HXB boost LEDs in the 1x2 format, whereas currently in the SSC2 only come in Sport or Pro in 1x2 and the Pros have a lot more light spill than the Max which isn't ideal.
  9. Jan 12, 2023 at 7:25 PM
    #269
    6P4
    Colorado Springs
    Have you considered using a pair of 6" DD SAE Fog light bars tucked into that same spot in the valance? Is that too much of a deviation from OEM-look for you?
  10. Jan 12, 2023 at 9:26 PM
    #270
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Larger than I'd like. The original stage series bars are getting a bit dated. The fog bars are an amber fog rather than selective yellow which is really not ideal and will incur heavier output losses while also providing reduced visibility contrast vs selective yellow. 2 SSC1 Max pods outperform the 6" LED bar while providing the more ideal color. Being that the 1x6 emitter bar is rated at 26 watts, and the 1x1 SSC1 is rated at 20w, I'd doubt the 6" bar runs hot enough to melt snow.
    If looking at 6" fogs, the Rigid selective yellow fogs put down better intensity specs than Diode Dynamics, though narrower pattern:
    DD: https://www.diodedynamics.com/stage-series-6-sae-amber-light-bar-one.html
    Rigid: https://www.rigidindustries.com/sr-...lective-yellow-surface-mount-pair-906704.html
    6P4[QUOTED] likes this.
  11. Jan 13, 2023 at 10:23 AM
    #271
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I put one in mine, even wired it with a trigger wire, but still haven't connected it to anything. I was going to try to put some SAE fogs in the turn signal spots (98-00) and use that switch. I measured and the standard square ones would fit if I made a way to mount them with a trim piece to cover gaps.
  12. Jan 13, 2023 at 5:25 PM
    #272
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You'd obviously need to come up with something else for signals in the front. The lower valence sounds easier.
  13. Jan 13, 2023 at 6:22 PM
    #273
    nzbrock
    Noah
    San Marcos, TX
    Could always do the corner lights, but I was thinking about just doing some square led rings on the fronts of the fogs. Already have halos and mirrors that flash with the signals as well.
  14. Jan 13, 2023 at 6:36 PM
    #274
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    On my T100 I rewired my marker lights to be the turn signals so I could do this. I never did bother with filler plates.
    nzbrock[QUOTED] likes this.
  15. Feb 2, 2023 at 4:30 PM
    #275
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Drove across the cascade passes last night. Best winter pass crossing I’ve had in recent memory, well below freezing but otherwise dry conditions, clear roads and low traffic. The headlight upgrade was great in remote areas, though not up to par with the 2nd Gen assemblies. But so help me those running their LED high beams full time, or that F150 with LED high beams plus quad light bars into oncoming traffic on super dark remote highways obliterating everyone’s night vision. As typical I’m disappointed in the general population intelligence. Sigh. Great to be back in this beautiful scenery though.
  16. Feb 2, 2023 at 9:05 PM
    #276
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    :boink: I've got a set of never used 5165s in my garage right now if you are looking for some. I installed one of them and thought it was too short for the All-Pro leafs and went with 5125's
  17. Feb 5, 2023 at 9:52 AM
    #277
    Madjik_Man
    Colorado Front Range
    This size is what I was considering putting in that lower valence because I will eventually run a hidden winch behind there too.
    Thank you for posting these links and info.
  18. Feb 5, 2023 at 9:56 AM
    #278
    Madjik_Man
    Truck looks great. Perfect stance.
    I live in Colorado and there are "those guys" driving around town at night with scattered LED headlights, LED pods and light bars on also... friggen brutal.
    It's why one of the first "de-bro'ing of the previous owner" things I did on my 04 DC was to get rid of the HIDs in a non HID assembly/reflector because I could tell I was killing oncoming traffic.
    Just need to get OEM assemblies now (or research what your non OEM alternative suggestion is), install the headlight upgrade harness and get better bulbs.
  19. Feb 5, 2023 at 10:58 AM
    #279
    6P4
    Colorado Springs
    I got the harness and bulbs Headlight Services https://www.headlightservices.com/. It was an easy-peasy install. Supports a Colorado business, too.
    Aws123, crashnburn80[OP] and Norton like this.
  20. Feb 5, 2023 at 11:01 AM
    #280
    Madjik_Man
    Jason gave sold me his out of his 1st gen after he bought @crashnburn80 's 2nd gen.
    Don't know the manufacturer.
    crashnburn80[OP] and 6P4[QUOTED] like this.
