Crate V3112 30W tube guitar amp for sale
Discussion in 'Buy / Sell / Trade - Other' started by ikillterrorists, Nov 30, 2012.
  1. Nov 30, 2012 at 9:41 AM
    ikillterrorists
    ikillterrorists [OP] Well-Known Member
    Andrew
    New Paltz, NY
    Sold my tacoma, got a Dodge Ram
    TRD Cold air intake Aries Grille Guard Flowmaster American Thunder Dual Exhaust Pro comp 3" suspension lift KMC XD Hoss, BFG KM2 285/75/16 Hypertech Speedometer Calibrator N-Fab Side Steps Access Roll-Up Cover TRD Quick Shifter SafeHitch
    I've used this amp only a few times. Had the tubes replaced recently. The reverb doesn't work (although this is an easy issue to fix). Otherwise it is in beautiful, crisp shape.
    Crate discontinued this model, I believe the one I have was one of the very last ones out of the factory.
    $400 OBO
    Product info:
    The V-Series -- creating a unique blend of great tone with revolutionary features for the worlds most discriminating players. Lush all-tube tone with revolutionary features for the most discriminating players.
The V3112 is an enhanced single-channel amp that operates in Class A configuration, and generates 30 watts RMS through a single 12 in. 70/80 Celestion speaker. The Class A circuit essentially runs the Groove Tubes(TM) EL84's at full output at all times. For the tone and feel fanatic, this provides instant response, dramatic wolf tones and harmonics which are the hallmark of these classic circuit designs. The V3112 has an internal spring reverb unit to produce a huge, wet sound, and quite possibly may be the best sounding 30-watt class A tube amp on the market. Players around the world are flocking to the V-Series. Made in USA.
    Technical Specifications:
    Output Power Rating: 30 watts @ 6% THD, 8-ohm load, 120VAC
    Signal to Noise Ratio: 71dB typical
    Gain: Clean 56dB, Overdrive 101dB
    Treble: 12dB range @ 6kHz
    Mid: +10dB range @ 900Hz
    Bass: 8dB range @ 150Hz
    Presence: +8dB @ 10kHz
    Speaker Specs: 12 in., 80 watts, 8 ohms, 1.75 in. voice coil diameter, 30 oz. Magnet, Celestion Seventy 80 Speaker
    Preamp Tubes: (3) 12AX7A
    Power Amp Tubes: (4) EL84
    Power Requirements: 120VAC, 60Hz, 70VA
    Size: 21 in. W x 17.5 in. H x 10 in. D
    Weight: 44 lbs.
  2. Dec 2, 2012 at 3:43 PM
    ikillterrorists
    Andrew
    New Paltz, NY
    pics added
