crawford performance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dvst8r1K, Apr 18, 2017.
  1. Apr 18, 2017 at 9:13 AM
    Dvst8r1K
    Dvst8r1K [OP] Night-Taco
    Greg
    2nd gen Black Tacoma SS 4.0l 4-dr 4x4
    1" Toytec body-lift, K&N filter, coolant by-pass, mesh cotton screen delete, TTBS, WeatherTech in channel visors, 2.5" Rancho full suspension kit, Oil Catch Can, Toyo 285/70 A/T-2's, 21.5" light bar in grill, blacked-out grill, de-badged entire truck; and again, more to come.....
    So I installed the Crawford Performance spacer. It made sense because lights cost way more than this small part, and since the claims were positive, I bought it. Regardless of true world dyno #'s and data facts whatever. That being said, there is something going on in there (motor) that's different. I don't know exactly, but the butt-dyno likes the smoother operation. Idles smoother, less gear changing (automatic) and smoother power delivery when stomping the skinny pedal. I'm on my first full tank of premium unleaded and will see if I get better mileage?? Of course, I'll also be installing new sparkies, so I'm probably not going to worry too much about it. All I know is that it is running smoother than what it was and before I forget, I don't have a full on air intake system, only a replacement K/N filter with a removed charcoal filter.... Just my opinions and seat of the butt-dyno feel from installing this part.... We'll chime back in later after a few more fill-ups.... Cheers!!!!
  2. Apr 18, 2017 at 9:33 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    did you disconnect the battery before install?
  3. Apr 18, 2017 at 9:34 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    all you are feeling is a 100% placebo effect.
    I bought one for shits n giggles. And while YES its claim of making the maf sensor see less airflow is true, you have to understand that the ECU will make up for this.
    Without the spacer in, long term fuel trims settle around 2-3% at most. With the spacer in, those long term fuel trims were up around the 10-12% mark. It was OBVIOUS that the ecu was going hmm something is going on here, im reporting less airflow, but im running lean, so i need to add more fuel to get back to my desired AFR as see at the first oxygen sensors.
    Needless to say, things like the spacer are going to be 100% counteracted by the ECU rather quickly.
    uurx, Sje1124 and inwood customs like this.
  4. Apr 18, 2017 at 9:46 AM
    Dvst8r1K
    Greg
    According to Crawford and the 200-something paged thread, you really don't have to, but can if you feel the need. I unplug everytime I install something electrical, so eventually, I will.
  5. Apr 18, 2017 at 9:48 AM
    inwood customs
    Dave
    just wondering because disconnecting the neg battery terminal alone can have some effects like you are describing.
    forces ecu to relearn parameters I believe, and also makes the transmission shift differently.
  6. Apr 18, 2017 at 9:52 AM
    Dvst8r1K
    Greg
    Gotcha.... No I didn't disconnect... All this is from the part alone....
  7. Apr 18, 2017 at 9:58 AM
    Dvst8r1K
    Greg
    I was in a hurry during install and just figured I'd void disconnecting and see what the truck would feel/act like.. So far so good.... It's not a light, and it has positive outcomes with less cost...
  8. Apr 18, 2017 at 10:19 AM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    I haven't noticed any difference in the butt dyno, but I have seen a slight increase in gas milage.
  9. Apr 18, 2017 at 10:30 AM
    Dvst8r1K
    Greg
    That slight increase is the main objective of this part. For the money and for the most part, you can't go wrong... Just my .2c
  10. Apr 18, 2017 at 11:02 AM
    nd4spdbh
    SoCal
    ugh.... again guys, you are not going to see any proper mpg increases... the ecu trims fuel up to compensate for the improper reading at the maf sensor. Any "increase" you see is going to be strictly the difference in environmental changes.
  11. Apr 18, 2017 at 12:41 PM
    RacecarGuy
    Houston, Texas
    '12 DCSB OR
    With the spacer my Long term fuel trims are in the +2% to +3%. I averaged .8-1.3 mpg better with it on, than without it. Over two years of driving with it and without it, led to my findings. I wanted to make sure it wasn't due to summer gas versus winter gas. I am running a snorkel, but do not think it effected anything, because I didn't see a change. I am on month two after installing an XTP manifold spacer, and so far, it looks like its providing an increase in mpg too, only time will tell. I don't have the wide band in right now, but when it was, it was reading 14.82 afr, so just a touch lean in closed loop.
    Maybe it isn't a proper increase and all due to climate change?
