Crawl Box for Different Tire Sizes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheNatural, Jun 21, 2014.
  1. Jun 21, 2014 at 12:03 AM
    TheNatural
    TheNatural [OP] Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    I run 33's on my '12 (4.0 auto), but I've been considering getting a set of the 37x12.50 humvee take offs. My biggest issue is that I want to continue using the 33's for daily use and throw the 37's on for wheelin' trips but my gearing should be different for the two different sizes. The idea that came to me today is using a "crawl box" with a ratio suitable to switching between tires. Have it in 33" mode as it sits now, then engage the crawl box when I put 37's on to end up with a little lower gear ratio and hit the same sort of RPM's. I have been looking around and haven't seen any crawl boxes that have a ratio anywhere close to what I would need. Does anyone have any better ideas, or an idea of where I might find a crawl box suitable for what I want to do?
    Yes, 37's are going to be real tough to clear, they're going to be heavy, I'm probably going to break a lot of stuff, and so on. I know. Please keep the comments related to gearing. Thanks!
  2. Jun 21, 2014 at 3:16 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
  3. Jun 21, 2014 at 3:35 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    best your going to do is regear for a tire size of like 35's. Crawlboxes offer substantial changes in gear ratios, the difference between the 33 tire size ratio and 37 isnt nearly that much.
    btw good luck fitting 37's
  4. Jun 21, 2014 at 3:39 PM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    All Pro's Brownie build and at least one other guy I can think of off the top of my head run them.
  5. Jun 21, 2014 at 11:11 PM
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    These things look interesting, although I don't see anything for Toyotas?
    Gearing somewhere in the middle would be the easy way, but I'd really like to find something better. I'd be revving pretty high on the highway most of the time, and be a little sluggish with the 37's.
    With a big enough hammer and enough cut off wheels you can accomplish anything. Also, I've seen it done.
  6. Jun 21, 2014 at 11:30 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    What are you looking to spend? Could look at a Atlas 4 speed there custom made units it would give a 1:1 for 33's and custom ratio for 37's high range and 2 different lows. Looking at at least 4k for something like that.
    I don't know if they can make a ratio between 1:1 and 2:1 as well
    I'm geared to 4.56 on 35's, drove for awhile on 33's great and I'd like to get to 37's eventually with the wheeling I'm doing but will prob come with a sas.
    Btw if your looking for some local info feel free to check out our BC Toyota 4wd group on Facebook.
  7. Jun 22, 2014 at 3:23 AM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Sounds like the perfect recipe for you to be the first guy with an 05+ to go dual transmissions. :D
    Never seen anyone use a crawl box to accomplish what you want.
    A crawl box either has 2.28:1 or 4.7:1. Normally you're at 1:1 in high range.
    2.28:1 would be too low for highway use. You'd top out at 45, if you're lucky.
    You'd need something like 1.5:1 crawl box gears.
