Crawl control not working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mjaramillo, Mar 15, 2020.
  1. Mar 15, 2020 at 5:32 PM
    Mjaramillo
    Mjaramillo [OP] Member
    Miguel
    2020 toyota tacoma TRD Pro
    Trd pro
    I bought a new 2020 tacoma trd pro and went to try out the crawl control uphill and its not working only works on flat area when you try uphill it want to engage but the truck doesnt move at all just stays there tried it in all speeds wont work
    I know how to use it but its not working
    Go in Neutral go to low 4 engage then drive than engage crawl low speed also high all speeds wont move wont engage crawl control even thought its engage
    its in the toyota service department anyone knows what the problem is what toyota had to do to fix the problem
  2. Mar 15, 2020 at 5:33 PM
    Jpmurph
    Jpmurph Well-Known Member
    17 DCLB TRDOR
    Are you in 4Low?
  3. Mar 15, 2020 at 5:33 PM
    Jpmurph
    17 DCLB TRDOR
    Is it Friday?
  4. Mar 15, 2020 at 5:38 PM
    Mjaramillo
    Miguel
    Trd pro
    Yes it engages but wont go up if its uphill wont work
  5. Mar 15, 2020 at 7:42 PM
    Quacktacular81
    Quacktacular81 Unknown Member
    SW Colorado
    2020 Tacoma TRD Off-Road
    I noticed the exact same thing in my 2020 TRD OR and a second 2020 OR on the test drive. 4Lo and a bit of an incline it would climb until the truck was entirely on the hill (rear wheels a few feet up), then comes to a stop. If I left it attempting to climb, it will shut down the CC system after 20 or so seconds. Both trucks I test drove acted exactly the same. The salesman was surprised when it would not climb the hill that he uses to show off the 4WD system with his customers.
    I've tested it a couple of other times since and my truck will not climb like the various review videos out there showing off the CC "feature".
  6. Mar 15, 2020 at 8:05 PM
    Mjaramillo
    Miguel
    Trd pro
    Do you know what the problem is
    stacksmasher likes this.
  7. Mar 15, 2020 at 8:07 PM
    Infinite_Taco
    Infinite_Taco Well-Known Member
    Aaron
    Medford Oregon
    2020 Tacoma TRD PRO Magnetic Gray Metallic
    This is not good news. I’ll test mine out tomorrow and let you know.
  8. Mar 15, 2020 at 8:15 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    just throw that bby in cruise control! forget about the "CC" its gonna collect dust anyways!
    JK op!
    suaveflooder likes this.
  9. Mar 15, 2020 at 8:20 PM
    Bishop84
    Bishop84 Well-Known Member
    Crawl control is a gimmick, but it's not meant to carry you up a hill while you steer.
    I used only on flat and as a downhill assist. Most of the time I used 4Lo with MTS or the Locker.
  10. Mar 15, 2020 at 8:22 PM
    DR TACO
    DR TACO Well-Known Member
    Denny
    Fort Mohave
    2019 Tacoma Off Road 4x4 Double Cab
    Pro grille, POD lights, SEMA wheels.
    What speed select? You have to be in 2 or above, I think. Try this. I don’t think it will climb at speed setting 1.
    Also, foot on brake or accelerator intervenes the crawl control.
    and, sorry if it is not working. That sucks.
  11. Mar 15, 2020 at 8:33 PM
    Mjaramillo
    Miguel
    Trd pro
    I selected all speeds and took my friend that owns two pro trd one 4runner and a tacoma said it wasn’t normal both a his trd pro work find the one i just bought crawl control when it’s activated wont move the truck just stays in place
  12. Mar 15, 2020 at 8:42 PM
    DR TACO
    Denny
    Fort Mohave
    It does work in flat areas, though? Weird. Take it in.
  13. Mar 15, 2020 at 8:47 PM
    Mjaramillo
    Miguel
    Trd pro
    Its in the service department its suppose to work uphill its in the book and my friends trds do work uphill we tried it mine doesn't I am just frustrated brand new truck that i just bought with 3 miles and crawl doesnt work i was just hoping someone knew why that has experience with crawl control that knew what is the issue will find out i guess in a couple days from toyota thanks
    Anton338, RedWings44 and AKGSD like this.
  14. Mar 15, 2020 at 9:12 PM
    Quacktacular81
    SW Colorado
    I haven't pursued it. I've only tested on the test drive in Oct and a couple of times since. I've wheeled for long enough without CC to not be too bothered by it not working, but it should function as advertised.
    I've tried all speed setting, no brakes, no accelerator, just set it and let the truck do its thing. It travels across flat ground, starts up the hill, slows to a stop and sits there until CC cancels. Even after it cancels, it'll just sit there as the hills I've tried it on aren't steep enough to roll back down.
    I haven't checked any longer descents, but it seems like it works for that.
  15. Mar 15, 2020 at 9:17 PM
    Mjaramillo
    Miguel
    Trd pro
    If you have the same problem you should take in before you have to pay out of packet for repairs crawl control works on mine but not uphill it just sits and doesn’t respond will lost what toyota service department finds
  16. Mar 15, 2020 at 9:25 PM
    DR TACO
    Denny
    Fort Mohave
    He said he took it in. Last thing from me, is you have to make sure 4 lo engages first, or CC won’t. The CC graphic will pop up when it is engaged.
    Sounds like the OP did everything in correct order, which is important, but have to make sure 4-lo engages, then brake, then D or R, then push CC button, graphic or info will come up, then if it works, it sounds like it’s broken.
    OnHartung'sRoad, Tacoman97 and Chew like this.
  17. Mar 15, 2020 at 9:43 PM
    Mjaramillo
    Miguel
    Trd pro
    Thanks everything comes on crawl activates bar comes on than we choose speed low all speeds and it wont run will let tou know what they say hopefully tomorrow thanks
  18. Mar 15, 2020 at 9:52 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Nope. Got me out when I was stuck in a rut in a steep hill climb. Thought I was going to have to get winched out, but worked like magic.
  19. Mar 15, 2020 at 9:53 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I tested mine for goofs, uphill. Worked fine
  20. Mar 16, 2020 at 5:03 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    This is what I was thinking too. Getting in 4 low takes sec and space, even more if you're on a steep incline/decline.
    OP, try turning on CC before approaching incline/decline, and see if it works?
    GillyLink likes this.
