Crawl control not working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mjaramillo, Mar 15, 2020.
  1. Jun 6, 2020 at 3:13 PM
    #181
    JPA2002
    JPA2002 Well-Known Member
    Roanoke, VA
    2021 DCSB TRD Pro
    We are going to get our crawl control fixed!!!!!!!
    Jon
    Anton338, CanadaToy and trevnologies like this.
  2. Jun 6, 2020 at 3:14 PM
    #182
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    I need drool control sometimes.
  3. Jun 6, 2020 at 3:19 PM
    #183
    urbncby
    urbncby Well-Known Member
    Scott
    Pittsburgh, pa
    '20 TRD Off-Road
    Ironman 4X4 Foam Cell Pro stage 2, 33” MT’s, Victory 4x4 winch bumper.
    what are they going to do?
  4. Jun 6, 2020 at 3:39 PM
    #184
    viperbsd
    viperbsd Well-Known Member
    Sacramento, Ca
    2020 MGM TRD Pro Auto
    I have not tried the CC yet, but if I ever need it I want it to work.
    trevnologies likes this.
  5. Jun 6, 2020 at 3:43 PM
    #185
    trevnologies
    trevnologies Well-Known Member
    Utah
    2020 Off-Road DCSB Cement
    Hopefully it’s just a simple software update but we will see as more people report this issue and get Toyota to acknowledge the issue.
  6. Jun 6, 2020 at 5:03 PM
    #186
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Any chance you have an OBD reader? I am curious to see just about much throttle a 2016-2019 is allowed to apply.
  7. Jun 6, 2020 at 5:24 PM
    #187
    Berner
    Berner Member
    Berner
    2020 Tacoma TRD OR DCSB
    Tried out my CC today. Truck has less then 600 miles. Attempted a few different experiments.
    1. With CC engaged, attempted to climb somewhat wet grassy hill in the shade. The hill was approximately 50 ft high at 5% grade (best guess)
    2. With CC engaged, attempted to descend the same 50 ft high grassy hill.
    3. With CC engaged, attempted to climb the same hill at approximately a 45 degree angle.
    4. With CC engaged, attempted to descend the same hill at approximately a 45 degree angle.
    5. With CC engaged placed 4 x 4 blocks in front of all 4 tires.
    All of the experiments resulted in the truck successfully traversing all obstacles.
    Sucks for the people with the 2020’s with CC problems, but my 2020 OR seems to be functioning correctly. Maybe this is just a Pro problem?
    Graham5david likes this.
  8. Jun 6, 2020 at 5:36 PM
    #188
    JNG
    JNG Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    No, sorry I don't have a OBD reader. All I can offer is this, today on the final trial, the truck had to travel over staggered tall sets of blocks in front of all 4 tires. The computer increased the engine rpms significantly to get over all 4 blocks. Like a dummy I failed to watch the tach so I don't know how high the rpms were exactly but by sound I would say roughly 2000-2500 rpm.
    At the hunt club there is a steep gravel hill one must go up to get to the east side of the property. I have for laughs and grins used cc on this hill a couple of times. The truck will basically idle up to the hill then apply throttle on it's own to maintain speed and then taper off back to idle once the truck gets over the crest of the hill. Once again I've never bothered to look at the tach but it will increase rpms significantly to go up the hill.
  9. Jun 6, 2020 at 5:39 PM
    #189
    JNG
    The next time I go to the club I'll see how high the rpms are going up the hill.
  10. Jun 6, 2020 at 5:47 PM
    #190
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    So a 2020 that will climb over 4x4's on crawl control. Happen to know the build date and location?
  11. Jun 6, 2020 at 6:09 PM
    #191
    Berner
    Berner Member
    Berner
    Build date of 2/20 Mexico plant unfortunately
  12. Jun 6, 2020 at 6:27 PM
    #192
    Berner
    Berner Member
    Berner
    Mine doesn’t flash
  13. Jun 6, 2020 at 6:34 PM
    #193
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    Interesting, mine flashes, and the owners manual has this "Crawl Control on/off switch - The Crawl Control indicator comes on and the slip indicator flashes when operating."
  14. Jun 6, 2020 at 6:37 PM
    #194
    Berner
    Berner Member
    Berner
    I guess I cannot say for certain if it was flashing or not. I wasn’t exactly looking at the dash while I was doing this. I will check again tomorrow and verify if it was or wasn’t.
  15. Jun 6, 2020 at 8:28 PM
    #195
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Another worthless gimmick,you cant make up for experience in off roading by adding gimmicks too trucks.
    1 crazyman and BSFord like this.
  16. Jun 6, 2020 at 10:18 PM
    #196
    angerbot
    angerbot Well-Known Member
    Thank you for your helpful thread contribution.
  17. Jun 6, 2020 at 11:03 PM
    #197
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Not helping :(
    Anton338 likes this.
  18. Jun 6, 2020 at 11:30 PM
    #198
    Anderson5290
    Anderson5290 Well-Known Member
    Brandon
    Corona, Ca
    2018 Tacoma TRD OR 4x4
    Tuned Fox 2.5 resi with dsc, JBA HD UCA, total chaos knuckle gussets, rear trd pro fox shocks, Deaver U402 stage 1 rear leafs, archive garage u bolt flip with fox 2.0 air bumps, White knuckle off road rock sliders, BAMF 1/4” steel skids, Magnaflow exhaust, Archive Garage Hammer Hangers, Cbi high clearance rear bumper, 285/75/16 tires.
    Crawl control is not a gimmick. And it’s far from worthless. I don’t need it to make up for experience, I need it to make up for a front locker which is does a damn good job at. My guess is that you must either not get your truck in situations where you need it and or you yourself don’t know how to use it.
    gurneyeagle, Madtiger and JNG like this.
  19. Jun 7, 2020 at 6:48 AM
    #199
    urbncby
    Scott
    Pittsburgh, pa
    '20 TRD Off-Road
    Still doesn’t work going uphill. It will successfully pulse the brakes on a crawl downhill but not give throttle crawling up.
  20. Jun 7, 2020 at 7:03 AM
    #200
    angerbot
    Very odd, although this pretty much rules out it being a hardware issue which is encouraging.
