Crawl control not working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mjaramillo, Mar 15, 2020.
  1. Jun 9, 2020 at 7:56 AM
    #221
    mchertel
    mchertel Well-Known Member
    Mark
    Colorado Springs CO
    2020 Tacoma Off-road
    Toytec 2 inch boss lift
    sorry missed this yesterday, mine has a build date of 11/19 in Mexico.
  2. Jun 9, 2020 at 8:06 AM
    #222
    AG-TACO
    AG-TACO Well-Known Member
    North Carolina
    My 2020 Pro with a build date of 10/19 does NOT work once it meets and obstacle.
    BandonBeachBumb likes this.
  3. Jun 9, 2020 at 8:09 AM
    #223
    Grindstone
    Grindstone Requires Adult Supervision
    Tested mine up a mild incline on a dirt/gravel road yesterday. Even drove it over a few large rocks. No issues. Was a bit too slow a few times, but I just gave it a little nudge on the gas pedal. Never shut off on me.
  4. Jun 9, 2020 at 8:36 AM
    #224
    AG-TACO
    North Carolina
    I think that's what the issue is... mine doesn't cut off on me either... works great going up and down hills... but once it reaches any sort of obstacle or resistance it just stops and doesn't automatically apply the throttle needed to overcome the obstacle. The crawl control on my 2016 4Runner Trail & 2019 Landcruiser overcome the same obstacle with ease that the tacoma gets stuck on.
    trevnologies likes this.
  5. Jun 9, 2020 at 8:59 AM
    #225
    Outdoorsy_Yota
    Outdoorsy_Yota Hella-Known Member
    duhbondo JIW Local 378
    Bay Area
    17 DCLB TRD OR LOL
    Dang, this is legit an issue, huh? Terrible.
  6. Jun 9, 2020 at 4:37 PM
    #226
    Barkley
    Barkley New Member
    White Tacoma trd
    None yet
    I have a 2020 Taco OR. Went to moab white rim trail last week and tried my CC and didn’t work on uphill it will stop when starts to climb. Anybody has same problem and fixed?
  7. Jun 9, 2020 at 5:04 PM
    #227
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    No fix yet, another member has a regional tech scheduled in July to have a look at his truck. Seems some function as expected and some it function but not as expected.
  8. Jun 9, 2020 at 6:18 PM
    #228
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    I was perusing through the factory service manual. Has anyone with issues performed the crawl control calibration in the manual with with a techstream or jump wire? It seems to be mostly for calibrating the actual switch so may not fix this problem, but it's worth a long shot.
  9. Jun 9, 2020 at 6:20 PM
    #229
    Bishop84
    Bishop84 Well-Known Member
    You found one video on a site with a myriad of posts saying they had issues climbing hills with it.
  10. Jun 9, 2020 at 6:27 PM
    #230
    Loaded NightraiN
    Loaded NightraiN Well-Known Member
    17 TRD Off Road
    Read the post he quoted. Has nothing to do with the non workers
    Stocklocker likes this.
  11. Jun 9, 2020 at 6:28 PM
    #231
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    Your talking about the zero point calibration. The procedure manipulates the CC switch. The switch is just a switch with open / close contacts. I have not found any clues yet on what this calibration does in terms of the function of CC. It is worth a shot but I do recall the 2020 needs the cable, pin jumping is not an option.
  12. Jun 9, 2020 at 6:34 PM
    #232
    ShimStack
    Ben
    NC
    I was looking at older versions that had a check wire option. Only thing I could think of is it doesn't recognize the switch range at all and doesn't up the chooch past minimum. I guess for those of you that have this issue, does the set speed increase as it should with your switch? If that's happening I guess it's calibrated and I'm back to thinking a too low tune parameter in the skid control ecu.
  13. Jun 9, 2020 at 6:42 PM
    #233
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Yes thanks for clearing that up for our buddy. I’m not refuting that some guys got problems. Mine works great. Especially climbing hills.
    2017’s got extra powerful crawl control maybe? I dunno.
  14. Jun 10, 2020 at 7:23 AM
    #234
    Outdoorsy_Yota
    Bay Area
    17 DCLB TRD OR LOL
    my 17 plows through everything.... maybe toyota neutered the CC on the 2020 for "safety".... youre a helluva lot more likely to roll your truck with a computer forcing it up the hill with no regard to pitch and roll than with one that hands YOU control at the slightest elevation change
  15. Jun 10, 2020 at 4:01 PM
    #235
    urbncby
    urbncby Well-Known Member
    Scott
    Pittsburgh, pa
    '20 TRD Off-Road
    Ironman 4X4 Foam Cell Pro stage 2, 33” MT’s, Victory 4x4 winch bumper.
    I’m taking mine in this month on the 20th for it’s 5K mike check over. I’ve notified them of the non-working CC. We’ll see what happens.
  16. Jun 11, 2020 at 4:59 PM
    #236
    EvenSlow
    EvenSlow Active Member
    Bixby, OK
    2020 MGM TRD Pro
    2020 PRO, build date 09/19. All good on crawl control, started on slowest setting and progressed to fastest. Hitch was dragging on grade transition, kept on going with no input from me on the accelerator pedal.
  17. Jun 11, 2020 at 5:09 PM
    #237
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    If you're willing, try the unofficial test - chocking all 4 tires with 4x4 wood blocks.
    BandonBeachBumb and trevnologies like this.
  18. Jun 11, 2020 at 6:49 PM
    #238
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Look at it this way, the pre-20's took it for the team with creaky leafs, leaky diffs, transmission shifting issues, leaky third cab lights, rusty frames... etc. The least we can do is deal with whimpy CC for the remaining years in this generation. Hope they resolve this (I'm sure it'll be an ecu or TCM update) after they get enough people pushing for it.
    angerbot and Tacohumper13 like this.
  19. Jun 11, 2020 at 7:04 PM
    #239
    angerbot
    angerbot Well-Known Member
    2020 Tacomas: we died so that you may crawl
  20. Jun 14, 2020 at 4:35 AM
    #240
    eclane
    eclane Well-Known Member
    2020 Black TRD OR DCSB
    I was able to go up an 8 inch curb with CRAWL. 2020 built in Mex 11/19. 1st time in 4Lo/Crawl, the was a pretty loud event.
