Crawl control not working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mjaramillo, Mar 15, 2020.
  1. Mar 16, 2020 at 5:47 AM
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    Is your vsc off?
  2. Mar 16, 2020 at 5:49 AM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    CC should work in 4 low regardless of incline or decline. Even on setting one. CC shouldn’t cancel unless you stop it, or over drive it. What it’s meant for really, slow crawling uphill, downhill, etc. Are you getting all the electronic brake booster noise when you engage it?
    Modesto Tacoma and Chew like this.
  3. Mar 16, 2020 at 6:55 AM
    piff
    piff Well-Known Member
    Minnesota
    2019 Quicksand Tacoma TRD OR DCLB AT
    Bone stock baby
    interested to see what the deal is... mine works with no issues. just be glad you tested it while it's under warranty :p I wonder how many people have driven past warranty expiration without ever using CC lol
  4. Mar 16, 2020 at 7:01 AM
    Quacktacular81
    Quacktacular81 Unknown Member
    SW Colorado
    2020 Tacoma TRD Off-Road
    It seems to be a change made to the 2020's. As I mentioned, the salesman was surprised when it wouldn't climb the hill he frequently uses during test drives. He suggested taking the truck I ultimately bought back to the lot and grabbing a second 2020. Both of them did the exact same thing.
    I'm interested to see what OP's dealer finds.
    4x4spiegel and piff[QUOTED] like this.
  5. Mar 16, 2020 at 7:32 AM
    Noch
    Noch Totally not a noob
    Taneytown MD
    '19 TRD OR DCLB Quicksand AT
    You search the mod-list, but don't find anything of interest.
    Well shoot, is this only being reported in the 2020's? I have a 19 OR, I'll go try it if I can find a suitable location nearby. What kind of angle are we talking about? Does it still register on the read out on the pitch display on the dash?
  6. Mar 16, 2020 at 7:45 AM
    Quacktacular81
    SW Colorado
    Not too steep, certainly nothing that I'd normally feel inclined to use CC. I'll try to go out and test it later today to get a better sense. I'll check with the pitch and roll screen.
    Noch[QUOTED] likes this.
  7. Mar 16, 2020 at 8:00 AM
    Friggin Fuego
    Friggin Fuego Well-Known Member
    2004 Toyota Land Cruiser, 2007 Toyota FJ Cruiser 6MT 4x4, 1988 Toyota Hilux SSR Diesel 5MT 4x4
    One of the TFL truck guys had an issue with the crawl control on a 2020 Tacoma. It starts around the 5 minute mark in this video:
    https://youtu.be/z-Z2aq5pSUw
    Anton338, ninernation and Matic like this.
  8. Mar 16, 2020 at 8:05 AM
    Quacktacular81
    SW Colorado
    Yep, exactly except without the articulation or any wheel slip.
  9. Mar 16, 2020 at 4:20 PM
    Riotfunk
    Taco TRD off road
    That’s weird in the video that it stops on that hill. Considering mine will just keep going regardless of the speed. Went up a steep hill today, good uneven muddy 30+degrees and CC worked and even when it gets stuck the wheels keep spinning. Something wrong on the 20s then.
    Jason TRD OR likes this.
  10. Mar 16, 2020 at 5:18 PM
    JPA2002
    JPA2002 Well-Known Member
    Roanoke, VA
    2021 DCSB TRD Pro
    I will check mine tomorrow.
    I know my 18 and 19 had no issues.
    Jon
  11. Mar 16, 2020 at 6:18 PM
    Quacktacular81
    SW Colorado
    Went out and tested today, same results as before...
    Here is the hill and how far CC will make it:
    CC active and pitch display:
    CC set to 5 and stopped on the hill:
    CC message after 15 to 20 seconds of being stopped:
    CC worked as expected on flat and backing down. I don't know if it is normal, but the middle traction control light flashes when CC is active and stops flashing when just in 4Lo.
  12. Mar 16, 2020 at 7:08 PM
    Infinite_Taco
    Infinite_Taco Well-Known Member
    Aaron
    Medford Oregon
    2020 Tacoma TRD PRO Magnetic Gray Metallic
    Checked my Crawl Control, and it is working fine no issues. I tested by putting from 2WD through the motion into 4L and crawl control all while on a 8% grade. Climbed like a champ. I hope you are able to get yours figured out.
  13. Mar 16, 2020 at 7:14 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    So glad that I can mechanically drop my Rubicon into 4 low and engage both lockers and not have to worry about fancy, schmancy dial controls.
    Good luck with getting it fixed. Hope the dealer does you right.
    JVL1985, reg0928, DWD484 and 2 others like this.
  14. Mar 16, 2020 at 7:19 PM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    I don't think they are having issues with getting into 4lo or engaging the locker.....
    ORtoCOTaco, Mike O, ericvega and 7 others like this.
  15. Mar 16, 2020 at 7:27 PM
    #35
    Matic
    Tricky Dick
    Easley, SC
    Right. It's the gimmicky crawl control.
    My point was everything is computer controlled, push button this and that. Turn a knob this way or that way. "Convenience" features.
    More stuff to go wrong. In every vehicle, not just in Toyota.
    JJ04TACO, JVL1985 and Junkhead like this.
  16. Mar 16, 2020 at 7:28 PM
    #36
    Matic
    Tricky Dick
    Easley, SC
    13 members and 18 guests. Lol.
    Maybe they are having trouble too.
  17. Mar 16, 2020 at 7:29 PM
    #37
    Quacktacular81
    SW Colorado
    Build date?
    The Rubicon I traded for my Tacoma had no issue going 2H -> 4H -> 2L -> 4L and the lockers worked fine as well. The Tacoma does all the same functions minus 2L and front locker (for now) and in much better comfort. I haven't put it through its paces, but I don't foresee any issues driving it in any of those settings. CC is a feature, but not a make or break item for me.
  18. Mar 16, 2020 at 7:32 PM
    #38
    Matic
    Tricky Dick
    Easley, SC
    JL's have a small issue going into 4 low. It's hit and miss. It's a bitch doing it from a stand still. You have to be rolling at 1-4 mph.
    Did you come from a JK?was it like that in that model as well?
  19. Mar 16, 2020 at 7:39 PM
    #39
    Infinite_Taco
    Aaron
    Medford Oregon
    we have a 2018 JL and it is a pain to go into 4 Low, I’ll check my build date.
    Matic[QUOTED] likes this.
  20. Mar 16, 2020 at 7:42 PM
    #40
    Infinite_Taco
    Aaron
    Medford Oregon
    @ Quacktacular81
    Build date on my Tacoma is Jan 2020
