Crawl control not working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mjaramillo, Mar 15, 2020.
  1. Jun 4, 2020 at 4:16 PM
    #141
    JPA2002
    JPA2002 Well-Known Member
    Roanoke, VA
    2021 DCSB TRD Pro
    I called corporate. They are having a regional tech review the case.
    next is a buy back review as it was not sold as advertised.
    Jon
    Anton338 and WZ00R2 like this.
  2. Jun 4, 2020 at 4:19 PM
    #142
    Chako
    Chako Well-Known Member
    Utah
    1998 TRDOR M/T 2020 TRDOR M/T
    Man, sucks for you guys. Its really terrible. But I'm glad I got a manual. Low range 1st gear is my crawl control.
    PopishMetalFab and Junkhead like this.
  3. Jun 4, 2020 at 4:20 PM
    #143
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Does cc only work in 4wd low?
  4. Jun 4, 2020 at 4:21 PM
    #144
    angerbot
    angerbot Well-Known Member
    Yes. 4LO, supposed to work in either forward or reverse. Would be interesting to test backwards and see if it makes any difference with the current issues.
  5. Jun 4, 2020 at 4:37 PM
    #145
    Berner
    Berner Member
    Berner
    2020 Tacoma TRD OR DCSB
    After reading through all of this, I am going to try mine out this weekend. I just got a 2020 TRD OR so I am interested to see if mine works. I will post results after testing mine. If it is not working, I will be taking it in.
  6. Jun 4, 2020 at 5:17 PM
    #146
    JPA2002
    Roanoke, VA
    2021 DCSB TRD Pro
    Does the same thing in reverse.
    Jon
    TheIncredibleTaco likes this.
  7. Jun 4, 2020 at 5:23 PM
    #147
    mchertel
    mchertel Well-Known Member
    Mark
    Colorado Springs CO
    2020 Tacoma Off-road
    Toytec 2 inch boss lift
    Went and tested mine tonight and it seems fine to me. Not sure it’s really needed for the most part. And that sound of ABS and whatever else it’s doing is hideous. Won’t use it often for sure.
  8. Jun 4, 2020 at 5:26 PM
    #148
    VaToy
    Parts Unknown
    No offense but I glad I don't have cc. Even if I would never use it, I would still want it to work.
  9. Jun 4, 2020 at 7:18 PM
    #149
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Just tried the same test @BandonBeachBumb did. Wood blocks, 4x4's on both front, 2x4's on both rear. While in 4L, neutral, flat surface, chocked all 4 tires. Into drive, release brake and engine idle brings it solid up against the blocks. Turn on crawl control, low setting; CC gives it throttle and the truck just sits there against the blocks, no climbing. I watch for 5 seconds, adjust CC to the high setting - no change; CC was just holding it there at a steady throttle. Sit and watch, after 15 seconds the screen has a "crawl control deactivated" warning. Another 5 seconds and CC releases the throttle and the engine returns to idle. Repeated this several times with the same results. I tried just 4x4 blocks in the rear, same process, it climbed over just fine.
    It appears there is a maximum throttle limit CC is allowed to apply. After that, if there is no movement it gives up and turns off. I somewhat expect a give up and turn off feature for safety reasons. From what I am seeing on mine, and BandonBeachBumb's tests, it appears either 2016-2019 had no CC throttle limit, or at least it was much higher than the 2020 CC throttle limit.
    When I get some time this weekend I will retry this test with an OBD reader watching the throttle position.
    trevnologies and Chako like this.
  10. Jun 4, 2020 at 7:47 PM
    #150
    BandonBeachBumb
    BandonBeachBumb Member
    Tom
    2020 Cement TRD Off-Road Long Bed
    Same experience, and I believe the same about the throttle threshold.
    When I said my Off-Road 4Runner really hit it, it was very aggressive.
    The throttle was enough that most tires left skid marks after coming off the blocks. But it did, within a split second, slow itself down.
    The whole thing was kind of jarring. So I can understand them turning it down a bit, if previous Tacoma’s were like that. But not completely neuter it.
    I wonder if the 2020 4Runners are doing the same.
    trevnologies likes this.
  11. Jun 5, 2020 at 2:51 AM
    #151
    JPA2002
    Roanoke, VA
    2021 DCSB TRD Pro
    yep, you are on it. 2019 truck applied throttle when it gets into a stuck situation and 2020 does not.
    I don’t know about you guys but that makes craw control pretty much a useless feature and it doesn’t work as advertised.
    Jon
  12. Jun 5, 2020 at 8:33 AM
    #152
    Mace27
    Mace27 Well-Known Member
    18 TRD OR
    Have any of you guys with CC not working tried disconnecting the battery?
  13. Jun 5, 2020 at 10:39 AM
    #153
    JPA2002
    Roanoke, VA
    2021 DCSB TRD Pro
    Corporate is sending out a regional technician to review my truck on July 7th.
    Jon
  14. Jun 5, 2020 at 11:11 AM
    #154
    angerbot
    Awesome, looking forward to hearing what the issue is. Hopefully this will result in a fix for the rest of us.
  15. Jun 5, 2020 at 11:43 AM
    #155
    trevnologies
    trevnologies Well-Known Member
    Utah
    2020 Off-Road DCSB Cement
    Thanks for all your work on this Jon!
  16. Jun 5, 2020 at 11:57 AM
    #156
    Kirru
    Kirru Off-roading nEwB
    Cory
    Conyers, GA
    2020 AG TRD Pro
    See Build Thread ;)
    Awww shizz. Now I have to go test my CC out. Be back shortly.
  17. Jun 5, 2020 at 12:11 PM
    #157
    Kirru
    Cory
    Conyers, GA
    2020 AG TRD Pro
    See Build Thread ;)
    Mine seems to be working. Found about a 25- to 30-degree hill in the back yard and approached it sitting at about 10- to 15-degrees before engaging CC. Carried me right up. Build date is 01/20 if that helps.
    I do have about 1100 miles on it as well.
  18. Jun 5, 2020 at 2:11 PM
    #158
    JPA2002
    Roanoke, VA
    2021 DCSB TRD Pro
    Did it apply enough throttle or just stay at idle?
    Jon
  19. Jun 5, 2020 at 2:19 PM
    #159
    BandonBeachBumb
    Tom
    That’s a good climb, but would be curious what would happen if there was an obstacle.
    Encouraging if yours does work though.
  20. Jun 5, 2020 at 2:23 PM
    #160
    Kirru
    Cory
    Conyers, GA
    2020 AG TRD Pro
    See Build Thread ;)
    @JPA2002 it applied throttle pretty good. I did a few passes with varying speeds on CC. Infact, the first pass was rather quick as I may have had it to high for what I was testing. The second pass involved the brakes groaning. My guess is that is how it is controlling the speed for each wheel and preventing roll back.
    @BandonBeachBumb does climbing over a destroyed pompas grass bush count? Haha it was the steepest part in the yard.
    I can get a picture of said "hill" if y'all would like it.
    Edit: I think I have some 4x4 posts that I could throw down at the wheels and try it again and see. I did not air down for any of this. Not sure if that has anything to do with it as well.
