Crawl Control sounds bad.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hockeymc3, Aug 14, 2017.
  1. Aug 14, 2017 at 9:25 AM
    Hockeymc3
    Hockeymc3 [OP] Well-Known Member
    Colorado
    2017 Super White Tacoma Off-Road
    I tried putting my truck into crawl control this weekend to make sure I knew how to use it. To say the least I didn't not likewise sounds it made when I tried it, especially when I applied the brake. Normal? How should it act?
  2. Aug 14, 2017 at 9:27 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Yep normal. It sounds like gorillas banging on drums. It's also 90% a gimmick.
  3. Aug 14, 2017 at 9:56 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Normal for it to make all the noises. Also, you don't use your brake when using crawl control; it turns it off. If you're a novice wheeler like me who's only gone on "more difficult" trails, it wasn't a gimmick when I got stuck. I'm still learning to modulate my throttle better and to stop static steering. It's a gimmick on easy stuff, but actually works when you're stuck.
    Make sure use your MTS first too; it totally helped out on the loose rocks on a hill climb I did.
    cblow5 likes this.
  4. Aug 14, 2017 at 9:59 AM
    Cnasianfire
    Cnasianfire Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    What do you mean by "Static steering"?
  5. Aug 14, 2017 at 10:02 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    Static steering is when you turn the steering wheel when the truck isn't moving. I believe it's because when you're aired down you can cause the bead to pop off the wheel. Also puts more stress on your components too when you're all flexed out.
  6. Aug 14, 2017 at 10:05 AM
    Cnasianfire
    Charles
    Wilmington, NC
    Gotcha, thanks!
    How low do you air down? I have never aired down more than 15 psi. And yet to air down besides going in sand which isn't as hard on it as rocks would be.
  7. Aug 14, 2017 at 10:09 AM
    eon_blue
    Azusa, CA
    15 psi is a good number, that's usually what I'm at on most trails. In sand I've gone as low as 6 psi to get unstuck, worked like a charm but aired back up a bit once I was out. Having a good compressor on hand when wheeling with low tire pressure is essential IMO
  8. Aug 14, 2017 at 10:11 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It's not a gimmick. The noise you are hearing is ABS activating and pulsing. Sure, on easy stuff you don't need it but on my 4Runner it was very good in certain situations.
    cblow5 and rlx02 like this.
  9. Aug 14, 2017 at 10:14 AM
    Pella
    Pella Well-Known Member
    Pella
    209
    SSMDCSBORFTMFW
    Just curious, did you happen to engage crawl control on asphalt?
  10. Aug 14, 2017 at 12:16 PM
    Hockeymc3
    Colorado
    Yes but did not turn. Just went forward and back 5 feet.
  11. Aug 14, 2017 at 12:19 PM
    trdsupreme
    trdsupreme Well-Known Member
    2017 TRD OR DCLB Silver Sky
    I think there are instructions somewhere that specifically state Crawl Control should not be activated on asphalt (or the likes of). I think it was on the sticker on the driver side door interior
    Pella likes this.
  12. Aug 14, 2017 at 1:12 PM
    Hockeymc3
    Colorado
    I believe that's just for the lock.
  13. Aug 14, 2017 at 1:18 PM
    trdsupreme
    You're right. It is for the Diff lock!
  14. Aug 14, 2017 at 1:42 PM
    Kenjiro
    Kenjiro Well-Known Member
    2016 DCSB TRD-OR
    The lowest setting (1 mph) is going to be loudest. Freaked me and the wife out first time also. Its the abs modules kicking in.
    cblow5 likes this.
  15. Aug 14, 2017 at 1:54 PM
    Pella
    Pella
    209
    SSMDCSBORFTMFW
    Theres some good youtube videos of it being used. I remember one was a video the dealer was making. They thought they broke it. Ive never used mine lol.
  16. Aug 14, 2017 at 2:00 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Yeah, it makes quite a racket. Especially if you use it on the slowest speed settings as the brakes are constantly engaging. If you set it to go faster it won't be so noisy.
    Kenjiro likes this.
  17. Aug 14, 2017 at 2:00 PM
    smitty99
    Scottsdale
    Don't run it too long you can muck stuff up.
    Pella likes this.
  18. Aug 14, 2017 at 4:51 PM
    Cnasianfire
    Charles
    Wilmington, NC
    Yeah, I always carry a compressor with me.
    eon_blue[QUOTED] likes this.
  19. Aug 14, 2017 at 4:52 PM
    Cnasianfire
    Charles
    Wilmington, NC
    I don't do anything but 2wd on asphalt. Perhaps I am being over careful.
    Pella likes this.
  20. Aug 14, 2017 at 5:29 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    I don't think it sounds bad, it sounds horrible!!!
    But it is IMO better in short burst than anything out there.
    But as for me, I'd rather have front & rear lockers than worry about overheating the braking system or have the entire system down due to a sensor malfunction. Although that does not appear to be an issue thus far so i can safely say that's just me
    Cheers
    bullaculla likes this.
