Crawl control worth it?
Discussion in '3rd Gen. Tacomas (2016+)' started by DRAWN, Oct 22, 2015.
  1. Feb 4, 2016 at 8:16 AM
    #281
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    I have A-TRAC and DAC on my Tacoma (and Crawl is using the same mechanics, basically) so I am well aware of the bizarre sounds and other noise when operating, thank you!
  2. Feb 24, 2016 at 9:54 AM
    #282
    SOCO Taco
    SOCO Taco Well-Known Member
    BSR
    Pueblo County
    `16, SW, DBL, Short, 4X TRD Off Road
    Yup. I honestly thought the salesman broke something while demonstrating CC in the parking lot. Sounds like your getting ready to walk out from your little excursion.
    I had a '14 Sport and thought I was never going to use it's simplistic 4X system over 50%. With the '16 OR in 4LO, I'm going to raise that to about 97% forget the MTS and CC.
  3. Apr 11, 2016 at 6:55 AM
    #283
    mojavejohn
    mojavejohn Well-Known Member
    Mojave Desert, Ca
    2016 Dbl. Cab Off Road MGM
    So I was out in the desert looking for petroglyphs today and had the pleasure of using CC again.
    We got stuck going up a pretty steep little hill. This was about a 150' hill climb on a 20%-25% grade. It was so steep in fact that my wife opted to get out and walk up. As I got to the top, the sand got really soft and I just dug in. I engaged the locker but this didn't help. So I backed down to make another run at it. This time I turned on CC and we cruised up pretty good. We started to lose traction again at the top but it did it's job and got us up. So, I'm liking the CC again. We didn't heat up the tranny or warp the drums this time. I've even been contemplating selling this and going to a manual. The only reason that I didn't was because of the CC. Well, I'm pretty glad that I had it yesterday. It worked exactly as advertised.
    Thunder Fist, smitty99 and VetteVert like this.
  4. May 19, 2017 at 3:15 AM
    #284
    Chief Taco
    Chief Taco Well-Known Member
    Nicholas
    Indianapolis, Indiana
    2016 TRD OR DCSB
    Mobtown Offroad IFS Aluminum Skidplate
    Do you use the crawl control and locking dif at the same time I have work with lockers quite a bit but never the crawl control
  5. May 19, 2017 at 6:18 AM
    #285
    mojavejohn
    Mojave Desert, Ca
    I have used them both at the same time. I typically use them independently of each other though. I don't remember if the owners manual addresses this or not.
  6. May 19, 2017 at 6:45 AM
    #286
    Chief Taco
    Nicholas
    2016 TRD OR DCSB
    Cool thanks I looked thru the owners manual and it just wasn't clear it wasn't listed as a step to or anything that had to be done to engage the crawl or visa versa so i wasn't whether or not to only run them independently since the crawl mode seems to work off individual wheel slippage
  7. May 19, 2017 at 6:51 AM
    #287
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
    I haven't found a use for CC. But MTS is nice.
  8. May 19, 2017 at 9:23 AM
    #288
    David K
    The locker is for emergency only... Use MTS (A-TRAC) always in Low Range. Crawl Control if you need or want. The chances are the locker is not ever needed... but if it helps (as it doesn't retard power), you have it in the hip pocket.
  9. May 19, 2017 at 1:02 PM
    #289
    Chief Taco
    Nicholas
    2016 TRD OR DCSB
    Agreed that is how I used lockers on my Rubicon was sparingly and only in specific scenerios
  10. May 19, 2017 at 5:06 PM
    #290
    David K
    Does the Rubicon have any limited slip features like Toyota's 'TRAC', 'AUTO LSD', or 'TRAC OFF' traction control or are they just open differentials when not locked?
  11. May 19, 2017 at 6:45 PM
    #291
    Paterico
    Paterico Well-Known Member
    San Antonio, TX
    2017 DCSB TRD OR 4x4
    If crawl control modulates braking to each wheel independently and the locker locks both rear axles together, wouldn't you want to avoid using them both together?
    Seems like you could put unnecessary stress on both the braking system and the rear drive components
  12. May 19, 2017 at 7:28 PM
    #292
    David K
    When the rear is locked, A-TRAC (MTS now) is not active unless you are under 3 mph, or basically stuck/ stopped... and then it is only working on the front (when locked).
    Just use the MTS/CRAWL (A-TRAC) and if fails to get you through, up, over... then lock the rear. As the sticker says, use only for emergency stuck.
  13. May 20, 2017 at 9:48 AM
    #293
    Chief Taco
    Nicholas
    2016 TRD OR DCSB
    That's what it thought! And why I was questioning it but if it was super serious or bad for the system seems like the there would be a warning in the manual about using in conjunction
  14. May 20, 2017 at 10:20 AM
    #294
    David K
    See my post right above yours.
