Crawl mode question
Discussion in 'Technical Chat' started by phawk, Dec 14, 2015.
  1. Dec 14, 2015 at 6:32 PM
    phawk
    phawk [OP] Active Member
    Phillip
    2016 Tacoma TRD OR
    I've had my new 16 Taco TRDOR for a couple weeks now. I had a chance to use the Crawl feature today. Got the book out for the setup and put it to work. It was jerky and the sound was that it wasn't fully engaged as if jumping cogs. I turned it off and went thru the sequence again with the same result. Does anyone no if I'm doing something wrong or missing something?
  2. Dec 15, 2015 at 6:48 AM
    tgear.shead
    tgear.shead Well-Known Member
    I doubt that it was "jumping cogs". The grinding noise was probably your brakes pulsating to distribute power more evenly.
    As far as the jerkyness, typical side-effect of operating at a low gear range.
  3. Dec 15, 2015 at 6:57 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Crawl Control is basically low-speed cruise control with A-Trac, nothing to engage mechanically. If you are already stuck, the system will be jerky and give similar sounds as if ABS or traction control is active.
    Make sure 4Lo is firmly engaged before activating Crawl, however.
  4. Dec 15, 2015 at 7:01 AM
    tgear.shead
    I think that is probably the key.
  5. Dec 15, 2015 at 7:03 AM
    tgear.shead
    Except on hard surfaces....
  6. Dec 15, 2015 at 7:05 AM
    tgear.shead
    So you like to constantly lock and unlock, when you can just let it do its thing?
    Sounds like a whole hell of a lot of fun....
  7. Dec 15, 2015 at 9:34 AM
    KenLyns
    Belly of the Beast
    Wonder what's the real reason no automaker currently offers front lockers with an independent front suspension. Durability of the CV shafts?
    DoorDing likes this.
  8. Dec 15, 2015 at 10:56 AM
    tgear.shead
    The simplest answer is... to prevent people from becoming DEAD. Even at relatively low speeds, on a high traction surface, an attempt to turn could cause the vehicle to jump and possibly roll over.
  9. Dec 15, 2015 at 11:11 AM
    tgear.shead
    I don't think they are the devil.
    But for the majority of uses, they aren't helpful, and can actually be a hindrance.
    Limited slip is far superior from a handling and stability point of view, and in most cases, at LEAST as effective.
    In MANY cases, more effective, since any attempt to turn with a locked differential necessarily requires traction on one side to be broken.
    It is far more effective to be able to apply the same force everywhere, without taking away the "give" that is needed to steer.
  10. Dec 15, 2015 at 11:20 AM
    tgear.shead
    Even easier: do absolutely nothing.
    Result: the thing actually drives correctly.
    Just what the hell is your point?
  11. Dec 15, 2015 at 12:29 PM
    phawk
    Phillip
    2016 Tacoma TRD OR
    Thanks guys. I really really trust Toyota to build a good product. I retired from road building industry where any number of heavy equipment machines utilize a creep or "crawl" mode to accomplish whatever they do. They r O so smooth and probably use a different technology altogether. I called the dealership and they as well as u guys have assured me this is what it is. Hurts my feelings to hear all the clicking and clanking that sounds like gears jumping. Hope I don't have to use it much. Thanks for the help.
  12. Dec 15, 2015 at 3:35 PM
    KenLyns
    Belly of the Beast
    ^It sounds bad but that's all it is, sound. In reality, the system is probably less stressful on the front diff and CV axles than a front locker.
    That's the wrong answer. Three production vehicles are currently offered with a front locker: Rubicon, Power Wagon, and Mercedes G-Class. The Land Cruiser / LX had a front locker until the design change from solid axle to IFS.
  13. Dec 21, 2015 at 8:46 AM
    tgear.shead
    Doesn't make it a good idea.
  14. Dec 21, 2015 at 11:32 AM
    KenLyns
    Belly of the Beast
    ^A front locker is a useful feature off-road as it operates smoother in constantly changing traction conditions, whereas A-Trac is jerky. With existing electronic interlocks (i.e. 4Lo only), if Mercedes can offer this feature in a vehicle driven mostly by lawyers and rich housewives without liability concerns, who are you to say otherwise?
  15. Dec 21, 2015 at 12:00 PM
    tgear.shead
    Physics always wins.
  16. Dec 21, 2015 at 12:06 PM
    fishfinder
    fishfinder Whoever dies with the most toys wins
    Mikey
    Santa Barbara
    2015 MT DCLB
    CBI armor, Kings, 35s, Lockers
    No IFS in any of these...
  17. Dec 21, 2015 at 12:27 PM
    KenLyns
    Belly of the Beast
    Yes, and there are situations (e.g. off-camber turns where the vehicle is already at a high bank angle or pitch angle) the jerkiness of A-Trac can cause the vehicle to tip over.
  18. Dec 21, 2015 at 12:40 PM
    KenLyns
    Belly of the Beast
    Try to keep up. :) I was asking why no production model with IFS is offered with a front locker. tgear.shead thinks it’s due to liability. I say he’s wrong because there are several solid axle models offered with front lockers, and liability doesn’t change whether the vehicle is IFS or solid axle.
  19. Dec 21, 2015 at 12:42 PM
    fishfinder
    Mikey
    Santa Barbara
    2015 MT DCLB
    Caught me!:thumbsup:
  20. Dec 24, 2015 at 8:54 PM
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    HDC makes the same sounds.
