Crawl mode?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JD Hog, Aug 18, 2015.
  1. Aug 21, 2015 at 8:30 AM
    #41
    ErocksTaco
    ErocksTaco Well-Known Member
    Eric
    Denver
    06 4x4 DCSB Sport Radiant Red
    OME 886 and rear Dakars Light Racing Upper Control Arms All pro U-bolt flip with Timbren Bump Stops CVJ Reman axles with off road boots Adventure Offroad Fab Sliders ARB Front Bumper Interior LEDs Weathertechs 2009+ taillights 2009+ headlights
    It's like the difference between ABS and pumping your brakes. You can do it yourself but the computer can be much more precise. The area I see Crawl Control really benefiting is in down hill decent... I'd like to try it out though and mess with it myself.
  2. Aug 21, 2015 at 8:37 AM
    #42
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    Stupid gimmick nothing new.... Hummer H1 also had a version of called TT4..
  3. Aug 21, 2015 at 8:43 AM
    #43
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Just because it's not new doesn't mean it's a gimmick. Does it work? From all the videos I've seen of this on other Toyota vehicles, I'd say it does work pretty well.
  4. Aug 21, 2015 at 8:47 AM
    #44
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    In the hummer application the driver controls the throttle so, not at all like the Toyota version.
  5. Aug 21, 2015 at 8:53 AM
    #45
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    I give up.
  6. Aug 21, 2015 at 9:30 AM
    #46
    TopherWV
    TopherWV Well-Known Member
    Christopher
    OH
    16' DCLB OR Inferno
    http://youtu.be/nRWBX-YxFfg
    Had some time at lunch... As stated beware of audio pollution. Good demonstration of CC working and getting out in less than two minutes.
  7. Aug 21, 2015 at 10:27 AM
    #47
    jowybyo
    Joe
    Baltimore, MD
    I don't care if it's a gimmick. That was pretty awesome. I've seen trucks with lockers on both ends unable to get out of being stuck in shallower sand than that.
    raycie likes this.
  8. Aug 21, 2015 at 11:16 AM
    #48
    SACTOWN
    Greg
    Yea and you control crawl mode with the button... You still have to turn it on. Plus the Gearing in the hummer is so low.. You don't have to press the gas or the breaks.. Pretty much does it for you. I know from first hand experience. It's mechanical vs technology.. It's not all what it's cracked up to be.. To me it's being lazy... woohoo!!! Your computer got you to the top of the mountain..
  9. Aug 21, 2015 at 11:29 AM
    #49
    SACTOWN
    Greg
    Jetboy from mud on crawl control...
    As for lockers vs crawl control - I'll take mechanical lockers any day. No matter how good traction control is, it's not as good at going the last mile offroad as real lockers, but it might be better at cruising around logging roads. The reason is that crawl control still requires wheel slip to engage, and that means you've lost static friction and now have kinetic friction on the tire that slips. Static friction is much greater in most situations than kinetic friction. So with crawl control you can achieve essentially the maximum static friction on the tire with most traction and kinetic friction with the other. With a locker you can get the absolute maximum static friction from both tires on the axle. So for me, ARBs would be my choice over crawl control - or any other traction control system.
  10. Aug 21, 2015 at 11:39 AM
    #50
    jowybyo
    Joe
    Baltimore, MD
    I'm pretty sure it's the other way around. With Crawl Control the computer is identifying which tire is slipping and moving power to the other wheels. It's trying to maximize the static friction by stopping tires that are spinning. With a locker, both locked wheels are turning the same whether they have traction or not. If only one wheel has traction, the other could be digging in deeper.
  11. Aug 21, 2015 at 12:52 PM
    #51
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    This is a contrived test under special conditions. During the ice storm years ago, a Army Guard Humvee broke through the ice into the snow below and had to be winched out. No fancy electronics will help you there or deep mud or wet snow. You can move dry sand at times.......otherwise, have a cell phone handy.
  12. Aug 21, 2015 at 1:05 PM
    #52
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Few if any of these traction aids are as good as open front and rear differentials and chains in deep snow. On ice, regular traction control in 4 wd high with the trac off so the engine shut off is best. Winter conditons are differnt then traditional off road. If you have deep wet snow and you can't spin your tires to keep your treads clear, you will stay stuck. You can leave crawl control on for an hour and co me back 30 days later and it will still be stuck in some winter conditions. This is why on off road model that I have, and I hope the new ones, you can defeat all your off road traction aids and just use 4 wd with open differentials and little to no help from traction aids. Some times...old is better. Bouncing through deep mud, like wet snow works better this way too. Well, at least you get to spray mud everywhere. The advantage is, when I parked my Tacoma at work after a weekend of mud work, few would park next to me.....
  13. Aug 21, 2015 at 4:08 PM
    #53
    JD Hog
    JD Hog [OP] 2014 TRD
    JD
    Eastern KY
    2014 Tacoma TRD
    3 inch lift Smoked LED cab lights Compass / temp. Mirror Dark tinted windows 285-75-16s 1.25 spiderTrax spacers Debadged
    I would
    I would think , ideal conditions , are needed.
  14. Nov 2, 2015 at 7:33 AM
    #54
    hmsailor
    hmsailor Well-Known Member
    Florida
    2015 DCSB 4X4 TRD spORt
    can i do a manual crawl control on a 4x4 with auto lsd(no rear locks). and how?
  15. Nov 2, 2015 at 8:18 AM
    #55
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    you get TRAC, a weak form of ATRAC. It won't control its speed, but it will try to control the speed of each tire
  16. Nov 2, 2015 at 9:31 AM
    #56
    hmsailor
    Florida
    and this is done with L4?
  17. Nov 2, 2015 at 2:55 PM
    #57
    TacomaN8
    TacomaN8 Well-Known Member
    Nate
    tbd
    I love these threads...
    I try to keep life simple.. if front and rear lockers were better than Crawl Control, the Land Cruiser would come that way, but it doesn't.
    So, since Toyota's offroad flagship vehicle has had crawl control since 2008, one can only reasonably conclude crawl control works better under the majority of off-road situations. Crawl Control is not new technology, it's just new to the Tacoma. It's been on the 4Runner Trail since 2010.
    I know change is hard but sometimes, it's for the best.
    I can't wait to hear what people on this forum say about when the Tacoma gets KDSS... wait for it, it's coming for sure in this generation at some point.
    4x4Runner likes this.
  18. Nov 2, 2015 at 3:02 PM
    #58
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    I want to see it do something when its in mud or stuck in boghole.
    They always show it being used in their own set up.
    I want to see some videos of it out on the trails to see how well it actually works.
  19. Nov 2, 2015 at 3:10 PM
    #59
    jowybyo
    Joe
    Baltimore, MD
    This is my opinion only, it comes down to what each person considers "offroading". If you want every modern convenience to keep you and the family from getting stuck at a muddy campsite, then crawl control is for you.
    If you think getting stuck and the ensuing extraction is part of the fun of offroading, then maybe crawl control isn't for you.
    For me, I like to keep the systems I truly depend on as simple as possible. Mechanically and electrically simple. Will crawl control keep me from getting stuck once or twice on the trail? Sure, but it's still not a system that I think will replace a winch. More than likely, that winch will be used to get me out of something during the day, so what's one extra time. Plus, the challenge of figuring out how to get myself out of a sucky situation part of the fun of offroading for me.
    Joe23 likes this.
  20. Nov 2, 2015 at 3:19 PM
    #60
    Joe23
    I see a lot of off road videos in Australia where they use the Land Crusier from the 80s. Actually remember watching a review where the guy was comparing it to the new ones and said he much rather have the old one than the new.
