Crawl option question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Colt45d, Oct 30, 2015.
  1. Oct 30, 2015 at 7:21 PM
    Colt45d
    Colt45d [OP] New Member
    2016 trd Tacoma
    I have a question on the 2016 Tacoma with the crawl Control. i test drove an automatic today with that option as trying to find a manual Tacoma is literally impossible anymore it seems. I pull a feed wagon loaded with 6 tons of hay Feeding cattle by myself. During my test drive I attempted a fairly steep hill without pressing the gas seems to work In the same sense as a manual. With this option in a automatic work in my application? Has anybody used it in the situation? I did notice when opening the door it deactivated the crawl control but I would imagine there would be a way around that? Thank you guys for your time.
  2. Oct 30, 2015 at 7:29 PM
    Neckbone
    Neckbone Active Member
    Pulling 12,000lbs with a Tacoma? On a slope? Using Crawl Control? Can't tell if serious....
    SACTOWN and specter208 like this.
  3. Oct 30, 2015 at 7:34 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    12000 pounds is out of tow limit, right
  4. Oct 30, 2015 at 7:43 PM
    Colt45d
    2016 trd Tacoma
    I use it with a feed wagon to go feed cattle out in the pasture,flat ground. Yes it may be over the weight limit but I'm traveling it 2 to 3 mph. I have a manual 94 Dodge Dakota when in four low and first gear goes across the field perfectly.
  5. Oct 30, 2015 at 7:53 PM
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    Get a manual, order one and keep using whatever you're currently using for the job until it shows up. You could keep crawl control going by climbing out the window but I don't think I'd trust the auto and constant ABS cycling to be up to the task long term. I wouldn't let the naysayers deter you about being over tow rating, but you already know there's no real risk here.
    Colt45d[OP] and 02Duck like this.
  6. Oct 30, 2015 at 8:08 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
    go buy a dodge. they can do anything
  7. Oct 30, 2015 at 8:15 PM
    forty2
    Cascadia
    2016 DCSB OR 6MT
    Tow rating doesn't count for shit at a snail's pace in 1st gear, 4low. I used to do the exact same task with a 22RE powered '85 pickup and later with a 35 hp tractor, it's pretty low wear.
    02Duck and specter208 like this.
  8. Oct 30, 2015 at 8:30 PM
    Colt45d
    2016 trd Tacoma
    Look babies! I had a simple question that I was looking for a genuine opinion on. I'm not here for the who's got a bigger dick Contest! Nor which make is better! I'm looking for another small truck that will do and last as long as the last one did.
    Thank you forty2 and neckbone for genuine comments and using the site as it was intended.
  9. Oct 30, 2015 at 8:35 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Welcome to TW
  10. Oct 30, 2015 at 9:05 PM
    Colt45d
    2016 trd Tacoma
    Ok just for you, I'll load hay every day that way it'll only be around 6,000lbs. Just so it's clear there's no tongue weight. The question still remains the same.
  11. Oct 30, 2015 at 9:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I don't want to see any shit throwing in here folks. Please keep things civil.
  12. Oct 31, 2015 at 8:50 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Towing feed,(really just pulling) not towing BS; that part comes later.
    How's life Chris4x4?
  13. Oct 31, 2015 at 9:03 AM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    I agree. From what I've seen I'd just order a manual and keep feeding the way you have been. The electronic bs would probably just complicate things and make what your doing more difficult.
    Will never understand why some people on this site seem to get off by quoting the exact manual specs and refusing to see that sometimes you can do things like pull much more than the on road rating or not wear your seatbelt. Maybe they've just never done things that are nowadays considered out of the ordinary?
    Colt45d[OP] likes this.
  14. Oct 31, 2015 at 9:05 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Of course it will work, it was designed to pull 12k pounds. I'd say fuck it and just Grab a 53' trailer from a semi load that up this way your making less trips. This is of course after you JB WELD the slide to your bed to pull it
  15. Oct 31, 2015 at 9:05 AM
    SouthPawCO
    SouthPawCO Active Member
    Northern, CO
    2014 Tacoma DC-TRD Off Road
    Get a canyon.
  16. Oct 31, 2015 at 9:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not bad. Busier than a one legged man in an ass kicking contest.
    SACTOWN and tcBob like this.
  17. Oct 31, 2015 at 9:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Did you not see my post?
  18. Oct 31, 2015 at 9:14 AM
    forty2
    Cascadia
    2016 DCSB OR 6MT
    How many accident do you think the OP is going to cause exactly while traveling at 2 mph across an open field while towing a 12,000 lb drawbar trailer?
    02Duck likes this.
  19. Oct 31, 2015 at 9:19 AM
    forty2
    Cascadia
    2016 DCSB OR 6MT
    Yeah, that's a given, it's a cow pasture. Still not sure how OP is going to cause an accident in an empty field.
    02Duck likes this.
  20. Oct 31, 2015 at 9:21 AM
    02Duck
    He is driving in a field feeding livestock. How will he hurt anyone?
    Same with the seatbelt comment. If I'm pulling my boat on the beach going maybe 10mph, what's going to happen? It's much more important to be able to get in and out quickly in case there's a problem loading and unloading in the surf.
    Some people still like trying to act like they know best but they don't understand the specific situation.
