Crawler/overlandish build thread
Discussion in '2nd Gen. Builds (2005-2015)' started by tgelata, Sep 1, 2022.
  1. Apr 21, 2024 at 8:49 PM
    #41
    tgelata
    tgelata [OP] Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    New rack, pump and lines in.
    Picked up a set of TMR toe alignment plates.
    Haven’t drove the truck yet to see how close i got it.
    Also changed all the dif and t-case oils
    First long term rear dif oil change since installing the locker. Nothing questionable came out so id say i did a good enough job
    Almost ready for wheelin season now :thumbsup:
    Windigo likes this.
  2. Apr 22, 2024 at 3:54 AM
    #42
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    like the toe plates. intrested to see how it turns out. with a solid axle i can see adjusting the tie rod tube will bring both wheels in and out but with our ifs I was thinking one end of the tape measure should be at a fixed point because each front wheel is adjusted seperatly. I just dont understand it yet. let us know how that turns out. thanks
    tgelata[OP] likes this.
  3. Apr 22, 2024 at 7:26 AM
    #43
    tgelata
    Probably at work.
    Hopefully ill be able to get out for a quick drive in it tonight.
    Ill post up the alignment sheet when i get it to see how close it was.
    As long as the wheels are parallel thats good enough to get it to the alignment shop.
    I just eyeballed the tires being straight to the steering wheel
    String method would be better for that.
    would be better if only changing 1 tierod.
    if they worked good ill be keeping them in the truck for if when I need to change a tierod on the trail.
    Windigo[QUOTED] likes this.
  4. Apr 22, 2024 at 4:29 PM
    #44
    tgelata
    Probably at work.
    Steering wheel’s out a bit but i expected that.
    pretty impressed with how straight it tracked down the road. Would definitely
    feel comfortable driving home doing a trail alignment with these plates.
    Ricardo13x and Windigo like this.
  5. Apr 22, 2024 at 4:46 PM
    #45
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Hell yeah dude!
  6. Apr 23, 2024 at 4:49 PM
    #46
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I use them to take a measurement before and then try and get it close afterwards. Not perfect but helps.
    tgelata[OP] and Windigo[QUOTED] like this.
  7. Apr 29, 2024 at 8:53 AM
    #47
    tgelata
    Probably at work.
    Sealed up my t-case shifter last night.
    I wish i gave myself a bit more time so i could have done it a little cleaner but should work fine
    cut the top layer off to give myself a nice mounting surface
    Made some plates out of some aluminum sheet i had kicking around
    I forgot my hole saw at work. Made it work with a jig saw and a round file.
    Final product
    use a silicone funnel from Amazon.
    still have full access to the top of the t-case without having to drop it.
    lowmower, tacoma16 and Windigo like this.
  8. Apr 30, 2024 at 4:52 PM
    #48
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    turned out great!
    tgelata[QUOTED][OP] likes this.
  9. Jul 22, 2024 at 6:21 PM
    #49
    tgelata
    Probably at work.
    Oh boy.
    Wheeled May 2nd weekend.
    Truck did great.
    Broke the power steering reservoir.
    Got lucky and jb welded it back together.
    Ran 5w-20 as PS fluid to get home because i gave my ATF to someone that blew a line earlier in the weekend
    Trucks been sitting since. (Minus a handful of drives to work because the daily was down.) :pout:
    Decided i need this truck for some work in the bush during my upcoming holidays so working on getting some TLC done.
    (And prep for upcoming road trip)
    Flushing PS fluid, dealing with the fj axle seal that sprung a leak while sitting and looking into options for leaking fj case shift boot.
    Windigo likes this.
  10. Jul 22, 2024 at 6:54 PM
    #50
    Windigo
    Farook
    '14 Acess Cab
    Better repaired in a nice garage than on a rainy trail. :thumbsup:
  11. Sep 9, 2024 at 7:34 PM
    #51
    tgelata
    Probably at work.
    Arb locker wasn’t engaging.
    Since there was no leak i fugured it was seized or the airline was kinked/clogged.
    Pulled the airline off the solenoid and when engaged no air came out.
    Couple squirts of wd-40 later and we’re back in action.
  12. Dec 6, 2024 at 5:49 AM
    #52
    tgelata
    Probably at work.
    Uge update.
    Did a ton of maintenance for a Utah road trip
    Marine battery upgrade for powering my Domectic fridge
    I do intend on coming back to clean up the wiring later. It’s as clean as i could get it with what i had at the time.
    Ran a wire right off the battery into the cab
    Ran one into the bed as well but the fridge doesn't like that one for some reason. I didn’t need it for the trip so I’ll have to revisit in the spring.
    Finally got around to finishing up all the shifter boots on the FJ case.
    Also got around to almost installing extended breaklines i had on the shelf since 2019 upload_2024-12-6_8-37-20.jpg
    Moments before this picture was taken I just finished telling my girlfriend “I’ll just let the mechanic do this one, i don’t really like the look of the break lines so it can just be his problem.” Then immediately regretting my decision to try anyways.
    Took care of my hot air intake and did a cowl snorkel. I’ll have to come back to this and put rubber around the hole as i used plastic protecter that rubbed through half way through the trip.
    Just did a handful of other boring general maintenance. Before towing it to the mechanic. for an alignment and break lines.
    Decided it was best to send out the break lines since it had been some time since the last time i made a set and being a couple weeks before the trip.
    Used every square inch the uhaul trailer had. -38 offset wheels are as wide as the deck can go.
    Got it back with 1 weekend left before the trip so took it to the cottage to do some work/testing everything.
  13. Mar 20, 2025 at 5:55 AM
    #53
    tgelata
    Probably at work.
    Utah road trip back in October was unreal
    10/10 will go back.
    Had an issue with my steering being knocked out every time we left pavement for the first half of the trip.
    I thought it was steering rack related for most the trip(because i just installed it) but couldn’t find anything loose or weird going on with it.
    Sucks because it really kinda ruined the wheeling part of the wheeling trip for me wondering what was wrong with my steering. :annoyed:
    Ended up being 1 of my LCA bolts was loose and kept sliding around in the slop of my bison cams.
    Was “fixed” about 2/3 of the way though the trip.
    tacoma16, lowmower and Windigo like this.
  14. Mar 20, 2025 at 6:37 AM
    #54
    Windigo
    Farook
    '14 Acess Cab
    Amazing. One day I hope to get there.
  15. Mar 20, 2025 at 8:30 PM
    #55
    tgelata
    Probably at work.
    After the trip the truck just sat in my driveway all winter
    Maybe moved 4-5 times but never left my street.
    Finally got it pulled in and started looking at these bison tabs.
    Found its kind of interesting that both aftermarket cam delete options (that I’m aware of) are both a full 2mm smaller than the OEM
    OEM
    Bison
    Taco tabs
    These are for the front LCA mount, the rear is similar.
    so the Front LCA is in direct relation to your tie rods so if they move within the 2mm of the slop it will knock your toe out
    Cam pulled all the way out within setting #4
    Toe measurement
    Cam pushed all the way in on setting #4
    Toe measurement
    TMR toe plate takes the measurement 10” from centre
    so 1/16 of measured movement is about .36° of toe movement on one side.
    Windigo likes this.
  16. Mar 20, 2025 at 8:40 PM
    #56
    tgelata
    Probably at work.
    I ended up just making myself a cam delete kit for the front mounts since I couldn’t find any kits the work with the marlin gussets.
    the bison rears are only about 1mm smaller (still not great) but i figured it would be alright since if that one moved it wont mess with my toe much.
    I also bumped the bolt size from a 5/8 (and a copper tube to get to 3/4) to an actual 3/4 bolt.
    made 3 offset amounts so just as adjustable as the bison kit but just as strong as the taco tabs or 333 kit.
    almost no play at all.
    temporary bolt to make sure it all fit.
    Sending these out for plating tomorrow
  17. Mar 20, 2025 at 9:21 PM
    #57
    Windigo
    Farook
    '14 Acess Cab
    Wow that's some nice work.
  18. Mar 28, 2025 at 8:04 AM
    #58
    tgelata
    Probably at work.
    Finished product
    Decided to bump up to a 3/4-16 bolt to avoid the copper tube that came with the bison kit.
    One less thing that might get seized.
    tacoma16 likes this.
  19. Mar 28, 2025 at 9:34 AM
    #59
    Windigo
    Farook
    '14 Acess Cab
    nice. I'm getting in the habit of just spray painting everything as i go. even if its different colours. seems like when i put stuff on the next time i look at it its rusty. I hate that.. I'd hit that beautiful tab and bolt with some paint
  20. Mar 28, 2025 at 9:37 AM
    #60
    tgelata
    Probably at work.
    I’ll probably hit em with the spray can when it comes back from alignment, just because I had to cut 1/2” off the bolt.
    But the tabs themselves I had sent out for zinc plating so shouldn’t be any rust going on here (hopefully lol)
