Craziest thing pulled from a tire?!?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Aug 4, 2018.
  1. Aug 8, 2018 at 7:07 AM
    #121
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Don't have a picture but pulled a 5"long 3/8 bolt out of my sister's tire
    And pulled a roughly 12"long piece of rebar out of a work truck once.
  2. Aug 8, 2018 at 8:29 AM
    #122
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    Years ago, I was a broke college kid at the time, I had a truck running bias ply tires. That's right no steel belt. They were cheap, but felt expensive at the time.
    Hit an already dead animal, coyote I think, on a back road at about 50. Immediately felt problems with the tire. I had somehow managed to get a rib through the tread of the tire. Damned near an instant flat.
    The only other "odd" thing that actually caused a flat, same truck, was some barbed wire that not only wrapped up in the tire to caused a flat but ripped the brake line out as well. Picked it up driving out of a pasture after fishing. Was a hell of an expensive fishing trip.
    Gunshot-6A likes this.
  3. May 30, 2019 at 5:25 PM
    #123
    Joisey
    Joisey Well-Known Member
    That is a copy of an old fashioned nut pick. Used to pick pieces of nut out of the shell.
  4. May 30, 2019 at 7:00 PM
    #124
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    Back in college I worked at a tire and lube shop. We had a truck come in on a wrecker, flat tire and no spare. We got it racked up, pulled the wheel, found a massive hole in the tire, and through wheel. Mechanic popped the brake drum off, found the handle for a chain binder (used by 18 wheelers to strap their loads down). Must’ve fallen off a truck and this guy ate it in the rear tire.
    Final bill: one new tire, one used wheel from a local yard, completely rebuilt rear brakes. We hung it on the shop wall.
  5. May 30, 2019 at 7:35 PM
    #125
    ndoldman59
    ndoldman59 Well-Known Member
    Murray
    West Fargo, ND
    2021 magnetic silver SR5 DCSB V6
    Porky pine quills, didn't flatten it though, did actually see corn stock go through once on a friends while hunting.
    Had a 2013 Elantra and got a nail in it however it was shot as tire cut up from rim. Best part that yr they put a can of stop leak and a air compressure in whare the spair went to meet cafe standards for milage.
  6. May 30, 2019 at 7:41 PM
    #126
    trackdaybro
    trackdaybro Well-Known Member
    I was getting my tires mounted when a guy had his car flat-bedded to the shop. Mentioned a truck spilling nails and he caught two flats on one side.
    Tech takes the wheels off and you could see through the hole in the tire.. and the rim.. Fella must have hit a curb or fixed object and thought it was just the tires.
  7. May 30, 2019 at 7:52 PM
    #127
    hawaii_dave
    hawaii_dave Well-Known Member
    2017 trd pro
    Few years back was driving my Mitsubishi delica space gear 4x4 and the steering wheel and shaft just came loose in the middle of the highway in the Philippines, I could just spin the wheel no longer connected to the steering gear. Yeah I know this is about strange things in tires. About 3 days latter I had a flat tire, In the tire was the missing bolt from my own steering column.
  8. Oct 28, 2020 at 11:51 AM
    #128
    canehigh
    canehigh New Member
    I had the same thing happen to me today, by the exact same piece of metal. I was pulling out of a Burger King and noticed the curb had broken off. I thought I was driving over a harmless chunk of concrete but it blew my tire out. Could this be some sort of rebarb material?
    JoeCOVA[OP] likes this.
  9. Oct 28, 2020 at 12:01 PM
    #129
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Doesn’t look like rebar at all to me. Why would you knowingly drive over some chunk of broken concrete? Also probably a good thing you did. That tire wear doesn’t look good. Get some new tires and an alignment
  10. Oct 28, 2020 at 12:44 PM
    #130
    canehigh
    canehigh New Member
    I didn’t knowingly drive over it. I noticed it as I was exiting and tried to avoid it, but my back tire clipped it.
    And yes, I was fortunate overall. One, that it happened in front of the place I work, and two, because I needed new tires. It’s been on my to-do list, but times have been tight.
    FLA_Hoosier likes this.
  11. Oct 28, 2020 at 12:55 PM
    #131
    offgrid taco
    offgrid taco Well-Known Member
    ned
    mass
    24 trd off road bronze oxide
    IMG_20190816_121857.jpgTire was brand new, only had 300 miles on it. My guess is it was an exhaust hanger. Left about a 1" slice thru the sidewall.
  12. Oct 28, 2020 at 1:02 PM
    #132
    theturbodog
    theturbodog Well-Known Member
    Fort Worth, TX
    I somehow ended up with an almost entirely intact and still useable screwdriver in the tire. Have picked up a few near foot long pieces of rebar over the years too.
  13. Oct 28, 2020 at 1:06 PM
    #133
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Pretty boring, but I just picked up a 4 x 1/4" lag bolt, with washer. Thank goodness it was in the second tread and D.T. patched it for free. Thanks again, Home Depot. :censored:
  14. Oct 28, 2020 at 1:59 PM
    #134
    snefo
    snefo Well-Known Member
    My stepdad pulled a Peterbuilt key out of his tire.
  15. Oct 28, 2020 at 2:12 PM
    #135
    HasbroGamer
    HasbroGamer Well-Known Member
    Nicola
    Washington State or Arizona
    2007 V6 Tacoma TRD Sport Double Cab
    Bed Stiffeners, Martin roof rack, 2 inch Dobinsons lift, black seat covers, taco garage tech deck and ram mounts, amazon backup camera, custom 2.5 gen facelift, Stingray front bumper, Diode dynamic foglights, wheels & tires, OME leafs.
    I work at discount tire and the funniest store I have is one of my coworkers pulling out a drill bit and the customer saying "Oh I did that by accident... Could I have it back?"
  16. Oct 28, 2020 at 2:18 PM
    #136
    AmericanDrug
    AmericanDrug Well-Known Member
    Rod
    Valdosta, GA
    2018 TRD OR 4x4 6mt
    If it happens it's usually a screw or nail
  17. Oct 28, 2020 at 2:22 PM
    #137
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Test drove a customer truck one time for intermittent vibration. Got a mile from the shop and it started vibrating like crazy, awesome I thought I duplicated it, went to make a u turn at next intersection and could hear the hissing, 1 inch by 3 inch chunk of aluminum sticking out of tire that i picked up on test drive to duplicate a vibration.
    It was pouring rain and my boss was already pissed because of shop comebacks that morning so I changed out the customers tire with their spare on the side of the parkway so he wouldnt have to pay for a tow truck to bring me back.
    Pouring summer rain. New Hanover county sheriff pulls up and stands beside me in the rain getting soaked so I wouldnt get hit by a passing car. Tells me it's his job to keep us safe.
    Lawfarin likes this.
  18. Oct 28, 2020 at 2:29 PM
    #138
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Latch to a utility truck bed system 9948336C-046B-4BC8-AACE-BE934D463E7C.jpg 55E95B6A-F878-4B73-B884-C2DFA6D1714F.jpg
  19. Oct 28, 2020 at 6:44 PM
    #139
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Looks like it was putting the tire out of its misery.
    Its dead jim.
    GarlicFarts likes this.
  20. Oct 28, 2020 at 8:21 PM
    #140
    JoeCOVA
    JoeCOVA [OP] Well-Known Member
    Joe
    Colorado Springs
    HA looks super similar to mine!
