Crazy Leak from the Rear end overnight
Discussion in '3rd Gen. Tacomas (2016-2023)' started by su.b.rat, May 13, 2018.
  1. May 13, 2018 at 1:57 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    That can't be good. Sorry man.
    tcjacado likes this.
  2. May 13, 2018 at 2:38 PM
    GF8er
    GF8er Well-Known Member
    MT. Hood
    18 MGM DCSB TRD OR 6MT
    It looks like a crack between the weld on traction bar bracket and the axle housing. Dealer probably wont do anything for you unless you want to buy a new rear axle housing and remove the traction bars.
    JJ TACO, BillsSR5 and su.b.rat[OP] like this.
  3. May 13, 2018 at 2:49 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    Clean it good and watch it every 2 hours and see where is starting to leak from.
  4. May 13, 2018 at 3:00 PM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Clean all the oil off. Check fluid level. If all good and no cracks found, drive it and see where it's coming from.
  5. May 13, 2018 at 3:06 PM
    Syncros
    Syncros Well-Known Member
    Looks like the axle housing, they aren't very thick and something "tacked on" with that much force applied isn't going to last long.
    BillsSR5 and Garrett75x like this.
  6. May 13, 2018 at 3:27 PM
    Lt. Dangle
    Ohio
    Just needs more welding rod.
  7. May 13, 2018 at 3:53 PM
    su.b.rat
    su.b.rat [OP] broken truck
    my installer is in Ft. Worth and I'm not gonna do that drive... about 40 miles. instead I'll take it to my independent shop for evaluation before the dealer can make their story.. that shop is about 4-5 miles past the dealer, 15 miles total. i don't have time myself but need a clear diagnosis before anything else.
    shakerhood and Lt. Dangle like this.
  8. May 13, 2018 at 5:26 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Good luck dood
  9. May 13, 2018 at 5:41 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Looks like the u-bolt is pressed against the bead on the seam, could it have cracked open? Sounds silly, but since its not a load bearing or hot part, if it where properly cleaned, something like JB Weld would seal the leak. But I’d suggest taking that bar off too.
    Topanga Taco likes this.
  10. May 13, 2018 at 6:42 PM
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Hey @St.Germain, dumb question but did you drive through some rain? With no odor to the fluid that pretty well rules out grease, brake fluid, and oil, and in some of your more recent pics I noticed the underside of the composite bed was wet too. Kinda looks like you might have had water in your bed and it just leaked out over night
    P.S. also, the traction bar normally leaks the grease out because the grease zerks are not sealed, theyre open to the environment. Ive been regreasing every 1k since I discovered that
  11. May 13, 2018 at 6:49 PM
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga STRONG Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    If out in the bush, and trying to get to safety, that would be an option for sure. Day to day, I’d get it TIG welded to make sure it doesn’t get warped in the process. Someone who doesn’t know might get trigger happy on MIG.
  12. May 13, 2018 at 6:56 PM
    OnHartung'sRoad
    Some nice person drilled my steel tank on my 1st Gen for a couple cups of gasoline one night, I used epoxy paste to fix it instead of paying the hundreds of dollars it would have cost to replace it. Lasted 8-years without leaking. Some of the adhesives we have available these days are better than welding in many ways.
    For instance, you cant weld a gas tank with gas in it! Can you TIG weld a differential filled with oil? I dont know. One issue is that glue wont add structural strength to torn metal, so it does have its limits.
    Topanga Taco[QUOTED] likes this.
  13. May 13, 2018 at 6:58 PM
    Topanga Taco
    Rick
    You got me thinking Brother Taco. I’m going to stash several tubes of JB Weld in the emergency pack!
    Devcon is good stuff too.
  14. May 13, 2018 at 7:03 PM
    OnHartung'sRoad
    A bar of ivory soap, too! Soap wont dissolve in gasoline, so you can whittle a plug out of it if your gas tank is ruptured. I learned that from a fisherman in Baja when our van hit a sharp rock and punctured a tank.
    kimo and tcjacado like this.
  15. May 13, 2018 at 7:04 PM
    #35
    Topanga Taco
    Rick
    The crack area would have to be thoroughly cleaned, as for any process to “stick.” Sorry OP if that is the case. :0(
  16. May 13, 2018 at 7:05 PM
    #36
    Topanga Taco
    Rick
    Now that is TW’s Trick of the Week!
    Kilokato and tcjacado like this.
  17. May 13, 2018 at 7:22 PM
    #37
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    looks like the weld burned thru the diff case, why was a weld put there in the first place, I thought traction bars are completely bolt on
    Gearheadesw and tcjacado like this.
  18. May 13, 2018 at 7:23 PM
    #38
    Dacon
    Danny
    Gilbert, Arizona.
    ^^^ Old WWII Army trick.
    OnHartung'sRoad and BillsSR5 like this.
  19. May 13, 2018 at 7:36 PM
    #39
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Tragedy. Rear axle housing is compromised due to poor welding of a poorly thought out/ unecessary mod.
  20. May 13, 2018 at 7:37 PM
    #40
    OnHartung'sRoad
    AeroCooper likes this.
