Crazy Leak from the Rear end overnight
Discussion in '3rd Gen. Tacomas (2016-2023)' started by su.b.rat, May 13, 2018.
  1. May 14, 2018 at 5:04 PM
    #61
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
    Why is a traction bar needed for a 3rd gen? Is it pounding the pavement with that high hp? Tired of trying to do a burnout and the wheels hopping around? Just curious?
  2. May 14, 2018 at 5:05 PM
    #62
    su.b.rat
    su.b.rat [OP] broken truck
    bracket design is the issue. we never should have mounted it with that bracket. it never provided enough material to handle the loads there. so we're considering starting from scratch with a new design.
  3. May 14, 2018 at 5:10 PM
    #63
    su.b.rat
    it's how i drive. i throttle steer a lot and put power down very early in turns. combine that with my tires which are E range and 265/65-17 and like hard little rocks, and you get plenty of traction challenges. i live to drive like this, it's the most fun thing i do. the trac bar helps with early throttle in the turns significantly. firms up some of the rear handling slop as well.
    and btw i never said anything is "needed" for anything. it's all preference.
  4. May 14, 2018 at 5:15 PM
    #64
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I can appreciate your view, but I feel like the truck is more likely to understeer than anything in this scenario. I have an OR so maybe that's why.
  5. May 14, 2018 at 5:23 PM
    #65
    su.b.rat
    this is the most understeering vehicle I've ever driven. i did some setup work and got the front to respond, but the rear was too loose for it. added the trac bar and a rear sway and I'm fully in business. now i have both under& oversteer instead of just understeer. which is the solution, actually. can't change the front heavy weight distribution. just gotta make use of it. i can lose the trac bar but that will compromise throttle steering. yeah I'm a handling junky and doing it in a truck with AT's just makes it that much more fun. especially when you're running 265/65-17 E ranges. find your traction or die trying.
    boynoyce likes this.
  6. May 14, 2018 at 5:23 PM
    #66
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I'm not sure what surprised me more, the leak or the sway bar.
  7. May 14, 2018 at 5:25 PM
    #67
    su.b.rat
    lol.
    kgilly likes this.
  8. May 14, 2018 at 5:31 PM
    #68
    Lt. Dangle
    Ohio
    You've clearly spent more time than I have thinking about this so I will defer to you lol. The mod isn't for me, but I can respect your situation. Good luck getting it fixed and keep us updated.
  9. May 14, 2018 at 5:36 PM
    #69
    su.b.rat
    thanks, hoping for a little more good luck myself.
  10. May 14, 2018 at 5:40 PM
    #70
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I'm just waiting for someone to take a SR5 access cab, strip weight, cage it and put twin turbos on it. Not for me but I can appreciate the intent and will follow closely.
    kgilly likes this.
  11. May 14, 2018 at 5:44 PM
    #71
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    you should be in a sports car bruhh
    kgilly, BillsSR5, kimo and 3 others like this.
  12. May 14, 2018 at 5:57 PM
    #72
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    That is one of the things that interests me about TW.
    The people with knowledge doing things to their trucks to improve the performance.
    I respect anyone who freely shares their experience, especially those members that share the problems- that takes guts.
    This means you @St.Germain.
    Get those kinks worked out and back in the driver's seat.
  13. May 14, 2018 at 6:01 PM
    #73
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yeah exactly. Some guys lie like a rug, others truly need help with a problem. That, plus the intermittent amazing thread (knob) keeps me coming back!
  14. May 14, 2018 at 6:15 PM
    #74
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Yeah... not for me either. It’s completely lost on me, the trying to get a truck to be something it clearly isn’t. A track CAR. But I like the OP. OP, bro, gussets will be your friend. I mean. That thing was BARELY on there.
  15. May 14, 2018 at 6:22 PM
    #75
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Right? I gusset my underwear...
    kgilly likes this.
  16. May 14, 2018 at 7:28 PM
    #76
    Drunken Chewbacca
    Josh
    3rd Gen Taco
    Not enough to list
    I had a aftermarket one on my 500hp 02 z28 Camaro. It helps for sure. Just really never saw one on a pickup truck.
    kgilly likes this.
  17. May 15, 2018 at 3:19 AM
    #77
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Im right there with him! these trucks have plenty of potential when you put some thought and some effort into them... Plus, making a taco fast is way more of a challenge, more rewarding, and honestly just more fun than a lot of sports cars. Plus with a sports car, if you hit a pothole or something like that you're seriously at risk of not having a functioning car anymore and you can't really ever go offroad unless were modifying 'sports car' to include a WRX STI or Evo or other things of the AWD ilk. With a taco thats tuned well you can rip it offroad, onroad, over jumps, and wherever else you can fit it. Sure, its a little more expensive that way, but if we are comparing to sports cars then even all my mods plus cost of the truck doesnt even scratch the surface yet. A Porsche Boxster S costs 70 grand today, for reference.
  18. May 15, 2018 at 3:25 AM
    #78
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    kgilly, BillsSR5 and Joe23 like this.
  19. May 15, 2018 at 10:01 AM
    #79
    su.b.rat
    100% agree and we are on the same page for sure. driving near the limit is where my fun is. try doing that in a sports car and you end up w/o a license. try it in a Tacoma and you'll find out what driving fun is all about and you'll probably still be w/in the speed limit, too.
  20. May 15, 2018 at 2:02 PM
    #80
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    sucks about the hole burned through the diff. I had to modify my bracket with a notch to go around the weld on the axle stock, so it would sit flush then welded her up good.
    FYI people, you wanna know why this tracbar is useful, stick a go pro underneath your truck, get up to 20 or so mph in 1st doing heavy engine breaking, then stomp on it, Id bet your pinion moves about 4-5in upwards, axle wrap on these trucks is so SO bad.
    CdnSldr and su.b.rat[OP] like this.
