Crazy Leak from the Rear end overnight
Discussion in '3rd Gen. Tacomas (2016-2023)' started by su.b.rat, May 13, 2018.
  1. May 19, 2018 at 8:24 AM
    #81
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    Unless you’re driving around in low range my new Tacoma didn’t have enough power to cause any problems unfortunately lol , it felt underpowered and doggy the last thing I felt like it needs is something to control high performance problems like axle wrap and wheel hop. Also understeer , oversteer none of those terms seem to fit the 4x4 Tacoma.
  2. Jul 23, 2018 at 1:50 PM
    #82
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    i would cut the bracket off, fix the hole, draw up a new bracket that has much more weld surface area and you should be good. i have a similar setup on my fj40 as wheel hop sucked
    su.b.rat[OP] likes this.
  3. Jul 23, 2018 at 1:56 PM
    #83
    su.b.rat
    su.b.rat [OP] broken truck
    that's the re-do plan eventually but we already got this all fixed for now. the axle housing is patched up all good as new. but i'll tell you i'm seriously missing the bar just for the driving.
  4. Jul 23, 2018 at 3:08 PM
    #84
    paranoid56
    San Diego
    14 double cab taco
    yea, i hear you on that, on my FJ with a large v8 and 37" tires the wheel hop when doing stop light burnouts was crazy. a nice beefy bar with 1.5" rod ends fixed that lol.
    su.b.rat[QUOTED][OP] likes this.
  5. Jul 23, 2018 at 3:40 PM
    #85
    su.b.rat
    my guys want to do a full gusseted wrap around bracket solution, but their new shop isn't outfitted for fab work yet, and I'm not confident it will happen in my timeframe. I'm looking for a maker with skills & tools local to me up do it, but finding that situation isn't so straightforward. in the meantime I'm just focusing on the exhaust redo.
  6. Jul 23, 2018 at 3:41 PM
    #86
    paranoid56
    San Diego
    14 double cab taco
    where are you located? lots of fab shops all over the place. offroad shops usually can do a good job.
  7. Jul 24, 2018 at 7:47 AM
    #87
    su.b.rat
    I'm in DFW. i try not to gamble so I'm always looking for a proper referral. anyone can fab. having the knowledge about our hardware to do it right is the trick.
  8. Jul 24, 2018 at 10:25 PM
    #88
    Hiluxski
    Ventura California
    An old FJ with leaf springs and a big V-8 would need some traction bars. A underpowered 6 cylinder Tacoma no so much.
  9. Jul 25, 2018 at 8:10 AM
    #89
    paranoid56
    San Diego
    14 double cab taco
    not true, i can gun it from a light in my heavy taco and you can see some bad axle wrap. I really notice it on dunes.
  10. Jul 25, 2018 at 12:07 PM
    #90
    su.b.rat
    truth. i can literally hop my axle whenever and just about wherever i want. i drive with that in mind continually, and that was a zero issue when i had my trac bar on. it's all about how you setup your vehicle, and mine is setup for on road handling, so a little throttle gets me quite a bit of traction challenge. i like the challenge but i prefer the traction, so I'm looking to get it back with some version of a trac bar again someday.
  11. Jan 11, 2019 at 11:47 AM
    #91
    kgautier
    kgautier Active Member
    2016 TRD OR 4X4 6MT
    Thanks for linking this to me. I had this fear when I saw the design of the budbuilt bar. I'm definitely planning on going a totally different direction with mine. My machine shop build out is about 4 months past my original time frame. I think in the next couple months I'll actually be able to start making parts.
  12. Jan 11, 2019 at 3:20 PM
    #92
    su.b.rat
    loop me in!
    btw it's been on the table with my shop, Tandem in Ft Worth, to do this right with a custom gusseted bracket solution. like mentioned, the bar is totally good if mounted right. i haven't committed to that yet since I've got a couple other things to do before that. but for now that's my plan maybe later this year.
  13. Nov 2, 2021 at 6:20 PM
    #93
    TACO TM
    TACO TM Well-Known Member
    2021 Pro
    Do you still have this? Would you recommend it knowing that the bracket needs to be beefed up or start from scratch?
  14. Nov 2, 2021 at 7:01 PM
    #94
    su.b.rat
    i do not, i sold it to a TW member.
    i strongly do not recommend it on a stock axle housing. and if you were bold enough to use the bar, which isn't totally awful in itself, then you absolutely will need to custom fab a proper solution for mounting at the rear. the design is terrible unless you rework it significantly.
    i think i mentioned, i did like it for the 48 hours or whatever it was when it worked.
    TACO TM[QUOTED] likes this.
  15. Nov 2, 2021 at 8:02 PM
    #95
    fullsend604
    fullsend604 Well-Known Member
    2018 Tacoma TRD Sport 4x4 DCLB
    Yukon 5.29 gears, Eaton ELocker, Stoptech 6 Piston front BBK + Stoptech 4 Piston rear BBK conversion (Tundra master cylinder upgrade), 315/70R17 Falken Wildpeak AT3W, Advan RG-D2 17x8.5 wheels (Indigo Blue), Fox 2.5 PE mid travel w/DSC adjust, Icon RXT leaf pack, DRT shackle hangers w/crossbar, BTF high caster LCA, SPC UCA, OVTune 5.29 (87 regular tune), C4 Hybrid front bumper (30" Rigid light bar + 3" pods), C4 Rock Runner HC rear bumper (Baja Designs S1 wide cornering reverse lights), C4 oversized tire fender kit, Cali Raised trail rock sliders, Cali Raised Overland bed rack, Cali Raised bed stiffeners, RCI engine/trans/tcase skids, CBI fuel tank skid, Prinsu cab rack, Borla Type-S exhaust, Morimoto XB LED head + tail lights.
    That looks like the same as my rear sway bar with identical brackets except mine is made by Hellwig USA. I noticed in the pictures you installed your brackets on the inside (closer to diff) of the axle housing where the welds are and not on the outside of that protruding line of the axle housing. I installed mine on the outside (towards wheel) where the red line is, please view the picture below. I've put on 15,000 miles since the install with zero issues, how long did you have the rear sway bar installed before this happened?
    EDIT: Nevermind, your issue was caused by the weld-on Budbuilt bar mount and not the rear sway bar so please disregard my post.
  16. Sep 15, 2024 at 9:08 AM
    #96
    Beats231
    Beats231 Member
    05 tacoma TRD
    Bringing this alive again
    Any more updates? I feel a bit stupid that I went ahead and jumped on this bud built bar after seeing a successful thread on Tacoma world.
    But after installing it and running into a couple issues, I found this post and think I may also have a similar issue on my axle ripping a hole but its very tiny and Ive been running it for over 2 months now doing pretty serious off roading in CO mts.
    The bar has done its job though as far as handling and I’m very happy with that, but I agree that there should be a little beefier design on the bracket attaching to the axle. I am looking into this now, but just curious if some of you guys came up with anything.
    Thanks for your time. Good luck on your mods
