Crazy or normal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Diabl0, Jan 18, 2023.
  1. Jan 18, 2023 at 6:42 PM
    Diabl0
    Diabl0 [OP] 2005 TRD Off Road DC SR5
    Tim
    Massachusetts
    2005 TRD off Road DC SR5
    AUCar Android Stereo Bluetooth Katskin Leather Soft Bed Cover Dual kicker comp s10’s Bull bar Euro headlights Black grill Clutch bypass switch Alpine 6.5 and 6x9 speakers Kicker Subaru Tweeters Diamond floor mats Dick Cepek DC2 Wheels Toyo Open Country ATII Tires Black Aftermarket Grill Rhino lined Tube Side Steps Back up Camera
    I got on the highway and noticed she may be revving high. Its a 05' off road sr5 6 speed and when I’m doing 70 mph, I’m around 3,000 RPM. When I let off the gas and both the clutch is in and I’m not in any gear the RPMs hang around 2,000. Shouldn’t, they drop to 780ish? When I’m costing at low speeds the RPMs stay around 1500 then drop to 780 when I come to a complete stop. Is this acting right? I have an aftermarket exhaust and sometimes when it hangs I can hear the throatyness of it around 2000 RPMs or 1500 and then idle near 780 and it goes away. Sometimes it will say 1500 RPM and it will sound like 780. What could be going on?
    HondaGM likes this.
  2. Jan 18, 2023 at 6:43 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    You’re not crazy, and it’s not normal unless you’re driving the taco. I think it’s for emissions. Very annoying indeed.
    XSplicer62, HondaGM and Dm93 like this.
  3. Jan 18, 2023 at 6:47 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds fairly normal, the PCM is programmed to hold RPMs up while moving in neutral. Kind of anoying at times but not much can be done about it, tuning can calm it down a bit but I don't think it can be totally eliminated.
    Mine typically hangs around 900-1200 coasting, prior to tuning it was a bit higher (like 1000-1400).
    HondaGM likes this.
  4. Jan 18, 2023 at 6:47 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Rev hang
    Emissions reasons..
    Wulf, Torspd, XSplicer62 and 2 others like this.
  5. Jan 18, 2023 at 7:51 PM
    Diabl0
    Tim
    Massachusetts
    what does emissions mean and so when im doing 80 3200 rms is natural? it seems high, gas guzzler
  6. Jan 18, 2023 at 7:54 PM
    Diabl0
    Tim
    Massachusetts
    at idle its around 1000 rpm is it the pcv valve or vacuum line or should i be ok?
  7. Jan 18, 2023 at 7:54 PM
    Bishop84
    Bishop84 Well-Known Member
    Keeps the cats warm.
    Wulf, Bivouac and b_r_o like this.
  8. Jan 18, 2023 at 7:58 PM
    Diabl0
    Tim
    Massachusetts
    nothing to worry about then what about the idle at about 1000 at rest?
  9. Jan 18, 2023 at 8:03 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Your saying it's not coming down to base idle (~750 RPM) when stopped at operating temp?
    TnShooter likes this.
  10. Jan 18, 2023 at 8:04 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Engine fully warm?
    Or is it still “cold”?
  11. Jan 18, 2023 at 8:22 PM
    Diabl0
    Tim
    Massachusetts
    no some times it does but often its high around 1000
  12. Jan 18, 2023 at 8:23 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Is your engine getting up to operating temp? It won't come down to base idle or learn it's idle until coolant temp reaches 174F
    b_r_o likes this.
  13. Jan 18, 2023 at 8:25 PM
    Diabl0
    Tim
    Massachusetts
    im not sure the gauge for the temp is normal, im not sure if the gauge is rpm malfunctioning
  14. Jan 18, 2023 at 8:28 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Do you have an engine light on?
    Typically any vacuum leak large enough to affect the idle would cause a lean code to set.
    Also make sure your floor mat isn't on top of your gas pedal, may sound stupid but I have had one come in the shop before with a high Idle complaint and that's all it was.
  15. Jan 18, 2023 at 9:04 PM
    Diabl0
    Tim
    Massachusetts
    no codes or engine light. just keeps going. just high idle and hangs, I'm thinking faulty gauge
  16. Jan 20, 2023 at 3:49 AM
    Diabl0
    Tim
    Massachusetts
    I cant figure out the high idle at rest its around 1100 all the time once a week it read 780ish. I can hear the exhaust rev up at this time. I've heard vacuum leak or PCV valve. Thoughts? If its idleing this high wont my RPMs be high as well when driving?
  17. Jan 20, 2023 at 5:19 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Clean the throttle body and MAF. unplug your battery and let the truck relearn the idle.
    Torspd and Dm93 like this.
  18. Jan 20, 2023 at 9:17 AM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I could see the truck wanting to keep a higher RMP at higher speeds when in nutral so that whenever the gear/clutch is re-engaged, it's a closer match to the proper RMPs (rev matching)?? More of a sports car thing, but I guess it would apply to any manual transmission vehicle :)
  19. Jan 20, 2023 at 10:02 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Its totally normal on manual trucks. Its called "throttle cracker" in the tune. It can be fully eliminated via a tune if you want. Its not for emissions reasons its for "drivability" to keep rpms up between gear changes so you dont have to blip the throttle etc. Its annoying if you are used to an older car that would return to idle as one would expect.
    6 gearT444E likes this.
  20. Jan 20, 2023 at 11:07 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    So you're saying it was added in as a crutch for those who can’t shift fast enough ;)
    nd4spdbh[QUOTED] likes this.
