crazy popping noise from rear end when suspension is flexing. Help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoBry19, Jul 23, 2024.
  1. Jul 23, 2024 at 1:24 PM
    TacoBry19
    TacoBry19 [OP] Member
    Bryan
    Western Massachusetts
    2019 TRD Off Road
    Okay guys. Ive endlessly been researching everywhere to figure out this sound and I just can not get to the bottom of it. My rear end makes a crszy popping noise when the suspension is flexing, such as turning up into a sloping driveway. I rarely hear it on level surfaces. My instincts say leaf springs, but ive inspected them dozens of times and everything looks fine. This is a 2019 trd off road with only 60k on it. Any help would be greatly appreciated!! Heres a link to the video: https://youtube.com/shorts/c6aJhJQN_-4?feature=share
    https://youtube.com/shorts/dq3rPq18VNE?si=MwFSWu-lMhL56ROb
    xerogs1 and Gunshot-6A like this.
  2. Jul 23, 2024 at 1:31 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Is your truck bone stock? List your mods, or at least all the suspension/wheel/tire related mods if you have any. Any work that may have been done, was it by a shop, or you, or?
    Gunshot-6A and Chew like this.
  3. Jul 23, 2024 at 1:34 PM
    TacoBry19
    Bryan
    2019 TRD Off Road
    So, I bought it with a modest lift installed by the previous owner. Was told by the dealership that it was "done the right way" whatever that means. Have had the truck for 3 years and it just started doing this recently. Not exactly sure on the specs but it isnt much of a lift. Maybe 1.5 inches? Nothing crazy. No wheel or tire mods.
  4. Jul 23, 2024 at 1:38 PM
    YF_Ryan
    Kent, WA
    It means the dealer wanted to sell you a truck. Not saying it was or wasn't done the right way, but can pretty much guarantee they don't know what they are talking about, hahaha.
    To me, it almost sounds like tire lugs popping against a fender liner. Can you look up in there and see if there is any rub marks on anything? Sounds like it correlates to popping faster when driving faster, right?
    MR E30, Gunshot-6A and Chew like this.
  5. Jul 23, 2024 at 1:40 PM
    TacoBry19
    Bryan
    2019 TRD Off Road
    Ive actually never heard it at speeds higher than what I was going in the video....so very slow.
    Seems to only be low speed on uneven terrain. Never flat surfaces.
  6. Jul 23, 2024 at 1:41 PM
    YF_Ryan
    Kent, WA
    I don't mean high speeds i mean the difference between Pop Pop Pop at 2 mph and pop...pop...pop at 1 mph.
    Gunshot-6A likes this.
  7. Jul 23, 2024 at 1:42 PM
    TacoBry19
    Bryan
    2019 TRD Off Road
    Right, sorry.
    I think thats a fair assessment, yeah.
  8. Jul 23, 2024 at 1:44 PM
    YF_Ryan
    Kent, WA
    My front tire can catch and pop against my aftermarket mud flaps and sounds similar when the tire is semi-stuffed, which is why I was thinking MAYBE a loose fender liner hitting your tire when the suspension is compressed a bit.
  9. Jul 23, 2024 at 1:46 PM
    TacoBry19
    Bryan
    2019 TRD Off Road
    Thats not a bad thought.
    I see no evidence of rubbing there, however.
    The sounds seems to come from both sides intermittently, and specifically from the front portion of the leaf springs. Or thats the best I could pinpoint it so far. Haha
  10. Jul 23, 2024 at 1:56 PM
    YF_Ryan
    Kent, WA
    I think you're gonna need a friend to watch and listen, or drive and you watch and listen. I'd volunteer but I'm a couple thousand miles away, lol.
  11. Jul 23, 2024 at 2:04 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    There are certain bolts, such as the lower shackle bolts, that should not be torqued after a leaf spring install until the truck is off the lift or jacks under full load. Is it possible these were improperly torqued prior to this and the bushing is what’s making the noise when the rear suspension flexes? Or possibly somewhere there is a bolt just not tightened properly, u bolts, other bolts holding the leaf springs in place?
    Gunshot-6A and Inyo_man like this.
  12. Jul 23, 2024 at 2:10 PM
    Dillusion
    Dillusion Well-Known Member
    Kyle
    2018 TRD Sport
    It doesn't sound like tire rubbing thats fore sure.
    I'd re check torque on rear suspension stuff first.
  13. Jul 23, 2024 at 2:28 PM
    YF_Ryan
    Kent, WA
    If that was pointed at me, I'm not talking rub. Talking a piece of plastic that gets caught on a lug, then bent until it pops loose, making a pretty much identical sound. When I'm crawling slow and stuffed, that's what it sounds like. Kinda like a playing card in the spokes of a bicycle.
  14. Jul 24, 2024 at 7:13 AM
    girMobi
    girMobi Well-Known Member
    2020 TRD OFF
    RCI, Martin, Vort and Irken tech
    do you have armor on the bottom? video doesn't really narrow down that its coming from the rear
  15. Jul 24, 2024 at 7:16 AM
    TacoBry19
    Bryan
    2019 TRD Off Road
    Do you mean skid plates or a bed liner etc? If so there is skid plate covering the gas tank and under the engine up front. Both are secured.
    No bed liner. I havent yet checked the bed bolts yet. Could that be it?
    Thanks
  16. Jul 24, 2024 at 11:00 AM
    xerogs1
    xerogs1 Well-Known Member
    New Mexico
    2019 TRD OR DCSB AT Silver Sky Metallic
    Bartact Seat Covers, Cali Raised LED molle bed system, radio knobs and Subaru Tweeters, OCD interior parts, OEM Exhaust tip, dash cam, hood protector, various theft deterrent items. Still a WIP
    After watching the video a number of times it seems like something is catching during the flex and then popping loose. I'm not sure if the leaf spring is binding in some way as it flexes or maybe something isn't torqued down right (u-bolts or shock). I've heard fasteners bind and make a popping sound if they have some play in the attachment when pressure is applied but never on a truck. At first I thought it might be something to do with the spare but I don't know what would make that popping sound in that location but it might be worth checking as well.
    Did they install an AAL and not remove the spring clip that interferes with it? If you have an attachable GoPro camera it might be worth repeating the flex to get a close up look.
  17. Jul 24, 2024 at 11:13 AM
    TacoBry19
    Bryan
    2019 TRD Off Road
    All good suggestions. I am in the process of checking the torque of all the bolts in the suspension....so far nothing has been loose.
    There's no AAL.
    The popping noise turns heads at the boat ramp when I'm launching my boat, thats for sure!
    Quite a mystery
    xerogs1 likes this.
  18. Jul 24, 2024 at 2:31 PM
    girMobi
    2020 TRD OFF
    I would take the engine skid off and see if it still makes noise. There may be other suspension issues causing the actual noise but skid plates amplify and masks the source of the binding you hear.
    Could also be the slip yoke behind the carrier bearing indicating it wants some lube.
  19. Jul 24, 2024 at 5:42 PM
    Dillusion
    Kyle
    2018 TRD Sport
    It doesn't sound plastic at all.
    Sounds metal on metal.
  20. Jul 25, 2024 at 4:00 AM
    TacoBry19
    Bryan
    2019 TRD Off Road
