crazy question about ignition key
Discussion in '1st Gen. Tacomas (1995-2004)' started by toysr5man, Oct 4, 2010.
  1. Oct 4, 2010 at 5:30 PM
    toysr5man
    toysr5man [OP] Auto thrasher
    Doug
    downtown, castile ny
    03 tundra trd. 01 taco 4x4 4cyl.
    5100 billys, add a leaf, 6.5 ' meyer plow, 265/75/16. diff drop, tundra brake upgrade, wheelers stainless stell braided brake lines, steering column mod
    hi
    i've been working on a 01 tacoma for about a month now. i bought it not running, and looking like a pig lived in it. the other day i took a key blank i had to a buddys house and cut it on his key machine. i knew it probably didnt come out great but went home to try it. well when i put it in it didnt work. it would go in but not turn. i did not try forcing it just pulled it back out. now when i put my original key in, it will turn to accessory but i cant turn it any further. so i guess my question is does anyone know what i did? does toyota ignitions know when you put the wrong key in the ignition and lock it from starting? so worse case scenario how hard is it to remove the lock assembly and have toyota get you a new one? like i said it wont start so i cant take it to them, and im an hour away from my closest dealer. any help would be appreciated. i did search the forum but i didnt see anyone else with the same problem.
    thanks again
  2. Oct 4, 2010 at 5:32 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    Is it possible you have a valet key and not an ignition key? have you tried to see if the key opperates the doors, is it maybe nto the right key at all?
    I have changed the ignition on a older s-10 and it was not bad. You just have to have the right tools.
  3. Oct 4, 2010 at 5:33 PM
    pittim
    pittim mittip backwards
    Mk7 TDI
    Permanent CEL
    wiggle the steering wheel
  4. Oct 4, 2010 at 5:34 PM
    pittim
    Mk7 TDI
    Permanent CEL
    how are valets supposed to drive your car to and from a parking spot if they cant start it....
    valet keys typically dont open up the trunks of vehicles.
  5. Oct 4, 2010 at 5:35 PM
    Jester243
    Dan
    Spokane, WA
    you tell me. I bought the truck and they gave me a "valet" ket that does not work in the ignition but opens the doors.
  6. Oct 4, 2010 at 5:36 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    x2
  7. Oct 4, 2010 at 5:36 PM
    toysr5man
    Doug
    no its not a valet key. ive started the truck and drove around the yard with the same key. as far as wiggle the steering wheel ive tried that. the key will move from lock to acc. so it does unlock the steering column and turn the radio on. i just cant get it to move to on and to start.
  8. Oct 4, 2010 at 5:38 PM
    Jester243
    Dan
    Spokane, WA
    get a hammer!!
  9. Oct 5, 2010 at 2:50 AM
    toysr5man
    Doug
    bump bump bump. any other suggestions ? or am i the only one with this problem?
  10. Oct 6, 2010 at 6:25 PM
    Air_Ops
    Air_Ops Active Member
    Peter
    N.W. VT
    01 Ltd Dbl Cab
    TRD Headers, Cat Back Exhaust, Airaid Intake Tube, LC Engineering Throttle Body Gasket, Bilstein 5100 Series Shocks, Wheeler's Add-A-Leaf, LC Engineering Tundra Brake Kit, Re-Framed
    The original key is worn out. Go to the dealer and have them cut a key using the factory code. I had a similar situation happen last year, my original key (I bought the truk new) stopped working, would not turn the ignition switch. I went to a dealer and had a key cut using the factory code, problem solved. I never knew that keys would wear out. Lesson for today.
  11. Oct 8, 2010 at 7:43 AM
    toysr5man
    Doug
    well the answer to the question is, i had bent tumblers in the lock. when i put that poorly cut key in the ignition it bent some of them up. i ended up pulling the lock out and taking it apart. i actually eliminated two of the tumblers. i put it back together and all works well now. thanks for the advice, but this one is solved.
