crazy steering wheel wobble.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jpop8807, Nov 26, 2013.
  1. Nov 26, 2013 at 8:09 AM
    jpop8807
    jpop8807 [OP] Well-Known Member
    Josh
    Fort Hood
    2011 Prerunner TRD 2wd
    so starting Friday my steering wheel started shaking like crazy. It does it when I go about 40 miles per hour and it becomes more violent the faster I go. I had the wheels rebalanced by discount. yet it still doing the same thing. I noticed that they used stick on wheel weights. They said the front lip on the stock trd sport rim wasn't sufficient to put wheel weights on. I am running guard dog retread in 255 75 17.
    So my guesses are.
    A. The wheel balance is off.
    B. I messed up something when I drove over a few curbs on Friday. (I was blocked in and slowly crawley over two or three standard parkinglot curbs)
    C. one of my sergeants was harping on me not to buy retread. He said I could be experiencing separation in a tire. But the tires look fine I see absolutely no buldges.
    I have absolutely no issues under 40 miles per hour. Over that it starts shaking a little once I had about highway speed it's shaking hard enough to make my whole truck move / vibrate. If you had to guess what could it be?
  2. Nov 26, 2013 at 8:42 AM
    jpop8807
    Josh
    Fort Hood
  3. Nov 26, 2013 at 8:49 AM
    justinfisch01
    justinfisch01 Well-Known Member
    05 DC Tacoma
    Wheel bearing maybe? I just had my front passenger side done. It was making a horrible howling noise with some wheel play as well. My other thought is a ball joint
  4. Nov 26, 2013 at 9:55 AM
    jpop8807
    Josh
    Fort Hood
    Its at discount now getting the inside outside type weight balance. I'll see if that fixes it if not I'll take it to a front end shop.
  5. Nov 26, 2013 at 10:05 AM
    BamaToy1997
    Bill
    Navarre, FL
    Stop giving beer to your steering wheel before you drive! It is drunk and can't roll a straight line!
    Seriously though, it could still be a balance issues. One thought, have you rotated the tires front-to-rear and checked to see if the vibration moves as well? Also inspect your steering gear mounting bushings. Worn bushings will cause one HECK of a wobble at highway speeds.
  6. Nov 26, 2013 at 5:12 PM
    jpop8807
    Josh
    Fort Hood
    got the truck back from discount. They use the inside outside type weight they also moved my problem tired to the right rear. Drive is better now.
  7. Mar 1, 2014 at 11:53 PM
    mattygaff
    mattygaff Beat em
    Steering gear mounting bushings? Where/what are those? I'm having a similar problem. Thanks.
  8. Mar 2, 2014 at 12:01 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Rack and pinion bushings. I think there's 2 that hold it place.
  9. Mar 2, 2014 at 7:55 AM
    ajw1986
    ajw1986 Well-Known Member
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    I had the same issue awhile back, took it in for a re-balance cause some of the weights came off and it was good as new! Your issue could be different of course
