Crazy vibrations when braking
Discussion in '1st Gen. Tacomas (1995-2004)' started by cynicalrider, Jun 20, 2013.
  1. Jun 20, 2013 at 8:53 AM
    cynicalrider
    cynicalrider [OP] #NFG
    Jersey
    Alright so I have been trying to track down the cause of this issue and i am coming up with no luck. At first I was terrified it was LBJ issues but i did the "jack each wheel up and grab at 3-9 and 6-12" thing and saw ZERO play at the 6-12 locations and a tiny tiny bit of movement at the 3-9 locations but nothing that seemed excessive.
    Generally the issues begin in the 45 mph - 65 mph range. I can feel it in the steering wheel when it's starting to feel wobbly but it goes crazy when I'm braking at these speeds. If I drive on the highway for extended periods of time in the 75-80 speed the issue goes away all together. Generally the issue is most apparent in the first 15 mins of the drive. Also another thing I noted was that my left rotor felt really hot (like burn my fingers hot) after a drive while the right felt just warm.
    Also I tested this in neutral and the issues still exist. So my theory as of this point is warped rotor? Could it cause vibes even when not braking?
    Truck is an 01 bone stock btw.
    Video of issue:
    th_4D96F4D6-907F-487E-A943-33BAC7236D03-_2daa640336c5d574f3aa765606dbdf1b1c0f6ecf.jpg
    Going to rotate the tires this weekend to rule that out hopefully.
  2. Jun 20, 2013 at 9:01 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Betting on warped rotors. Cheap and easy fix to install new rotors. Do the pads while you're at it.
  3. Jun 20, 2013 at 9:17 AM
    highcotton2003
    highcotton2003 Well-Known Member
    Britt
    Plymouth, NC
    2003 tacoma SR5 TRD
    upcomming lift,wheels & tires, air intake, and interior upgrades
    having the same problem mine feels like its in the rear tough it feels like it hops when braking hard. thinking its the drums out of round. any other ideas?
  4. Jun 20, 2013 at 9:47 AM
    Box Rocket
    Adam
    Syracuse, Utah
    Check your driveshaft Ujoints. Also take a close look at your rear leaf springs. If you're on old, stock leaf springs they might be worn out and getting a lot of axle wrap that would cause the hopping. Especially if you have a cracked or broken leaf in the pack.
  5. Jun 20, 2013 at 11:16 AM
    cynicalrider
    Jersey
