creak noise at low speeds over speed bumps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by choocad, May 27, 2021.
  1. May 27, 2021 at 6:01 PM
    choocad
    choocad [OP] Member
    2019 Tacoma SR5
    OK, have 2019 taco stock suspension, noticed a noise like that of worn out 65 ford galaxie A frame bushings, has gotten worse after 8K MILES. dId NOT NOTICE IT WHEN NEW. Found that if I step on running boards and jounce them up and down at low intervals, can duplicate the creak groan noise and feel it if I place my hands on right front spring. Got my dealer to order the upper strut insulator that sits on top of coil spring, they replace it and solved the creaking type noise for those of you who may experience similar sound. Never happened at road speeds, only like when I pulled into garage where I crossed over a hump on right side of floor , or similar situation . I thank my dealer for ordering the part on my word. Not a real big deal but annoying as hell, esp considering the low miles on vehicle. It did not make sounds if driving in wet weather. They also did the reprogram for ecm and that made trans shifting issues much better as well as cruise control on highways that have some hills around here. In the for what- it -is= worth, catagories . Thank you all at Don Moore Toyota in Owensboro, KY .
    bulalo and AWD OWNZ U like this.
  2. May 27, 2021 at 7:03 PM
    cop414
    cop414 Well-Known Member
    Tim
    Central PA
    2022 Blue Crush DCSB Sport
    Good info to know, thanks. :thumbsup:
  3. May 27, 2021 at 9:38 PM
    Toyo901
    Toyo901 Well-Known Member
    Shaheen
    West Tennessee
    2019 White Tacoma TRD ORLB
    Having the same issue with my truck & found the answer here! Thank you!
  4. May 28, 2021 at 4:46 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Good info … I swear the quality of these trucks is complete crap . Toyota must be using cheap Chinese parts lol .
  5. Jun 1, 2021 at 6:26 PM
    mac2165taco
    mac2165taco Member
    Tom
    17 Tacoma TRD Offroad
    Camburg UCA/ King 2.5 coilovers w adjusters
    Ive been chasing the creak noises on my front suspension for months. I have Camburg UCA and King 2.5 shocks. I went ahead rebuild the UCA bushings and UCA ball joints. Creaks are still there. Finally, I replaced the stock LCA and solve the creaks noise. It turned out that the left LCA sleeve was rusted where the cam bolt goes through it. You can't see it unless you remove the lower arm. Im so happy to solve this annoying creaks .
    timkf1 and lynyrd3 like this.
  6. Jun 1, 2021 at 8:31 PM
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
    Good to know, thanks.
    With that said, my 2016 TRD Off Road squeaks, rattles and bangs like no other. Likely the 10K off road miles, beating the crap out of it. :)
    Plus my toolbox in the back is full and just makes a racket over every bump. I just turn the stereo up louder. Plus my first 3 4x4s couple of Fords and a Mazda, were all beaten up offroad so they made a racket too. I guess I got used to it.
  7. Apr 17, 2023 at 1:38 PM
    timkf1
    timkf1 Member
    Tim
    Cincinnati
    1996 SR5, 2000 SR5 4WD, 2007 TRD Off Road, 2018 TRD Off Road 6sp
    Several............
    I now have a 2015 DBL CAB Long Bed, and it was lifted 2.5" with factory upper and lower control arms when I bought it. UCA's and LCA's I think are both wiped out. RF is substantially worse, but get SOME noise out LF. I replaced the UCA's with a medium spectrum UCA - (Old Man Emu (I never off-road it)) - have all new quality aftermarket LCA's and all dealer purchased associated hardware. The creak I have is so loud it's quite embarrassing. It got worse once I replaced the UCA's; my thoughts are that once the factory UCA's were replaced, it allowed the suspension to actually travel, and the bolts started moving more than they have in years, hence the creaking from rust. Your noises sound like the exact same noises I'm having. Anyone else have this problem?
  8. Apr 17, 2023 at 1:43 PM
    WhiteTaco20
    WhiteTaco20 Well-Known Member
    Perkasie, PA
    SW 2020 TRD Sport DCSB
    I believe I have this noise too, it only happens when I'm turning left or weight is applied to the left side like pulling into my driveway or reversing out. I thought maybe the lca bolt was loose and I tried tightening. Still there, i've just been dealing with it. I have 6112/5160 installed for about 1.5 years now. My 2020 has 18k miles on it.
  9. Apr 17, 2023 at 3:02 PM
    rndsommer40
    rndsommer40 Well-Known Member
    Ralph
    2022 TRD OffRd DCSB
    Same noise here. I turn the radio up
  10. Apr 17, 2023 at 3:12 PM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    Mine made creaking noises last spring and just started doing it again last week (mostly when turning and reversing into my driveway over the bump) Turned out to be my aluminum skid plate. Maybe the leftover salt, brine and winter crap was causing it (???).
    I fixed it by dropping the aluminum skid and putting some grease around the bolt heads and spacers....
