creak over bumps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jantolov, May 18, 2009.
  1. May 18, 2009 at 2:24 PM
    jantolov
    jantolov [OP] Well-Known Member
    Cincinnati, OH
    09 Off-Road
    I have a 09 TRD Off-Road and I have noticed that when I go over certain bumps I get a creaking noise from the drivers side front quarter area. Almost sounds like it could be coming from the door hinge area. It seems to get worse when its colder outside. I sometimes even notice it when I get out of the truck. Last time at the dealership I couldn't recreate it because it was warm outside and they just looked at me like I was crazy. I work on a construction site and everyday driving through the gravel lot my truck creaks and drives me crazy. Any ideas?
  2. May 18, 2009 at 2:32 PM
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    Make an appointment early in the AM with your dealer & take either a tech or the service writer on a ride along to recreate the noises. Good Luck!
  3. May 18, 2009 at 2:49 PM
    AzPrerunner05
    AzPrerunner05 Desert Rat
    Tucson
    2005 V-6 SR5 PreRunner Debadged
    De Badged, Flowmaster 50 Muffler & Dual Out Exhaust. K & N High Flow Filter. SP Racing Slotted Rotors
    I've got a squeaky driver rear.
    Pretty sure it's the bushing, i've lubed it up before and that temporarily solved it. Also could be dust in the springs somewhere. I've had that problem before.
    Either way, good luck getting that taken care of.
    Mine drove me insane (it still squeaks)
  4. May 11, 2010 at 5:28 PM
    rome
    rome New Member
    09 Double Cab 4X4 TRD SR5
    Taitem-
    I am having the exact same noise as you described. Did you ever solve the problem? Any help would be appreciated.
  5. May 11, 2010 at 5:44 PM
    jlvhrse
    jlvhrse Well-Known Member
    Jen
    SoCal SGV
    2009 TRD Sport 4X4 Long Bed
    LSK front and rear LT and stuff
    I hear my truck squeak a lot when I have my windows down and I got over bumps.. I always thought it was my springs or something... I will have to take it up there because it drives me nuts!
  6. May 11, 2010 at 6:43 PM
    c0astie31
    c0astie31 TACO SUPREME
    Dennis
    Long Island ny
    2011 4Runner Trail Edition
    A LOT
    look at your coil spring and see on the top the rubber sleeve , spray some wd in there and rock the truck a little, it will go away. mine drives me nuts and i carry a can with me at al times.
  7. May 11, 2010 at 7:45 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Yes. I have it. Precisely where you described it too.
    When I get out of my truck the door will make the sound emanate from the front support pillar. I can then stand on the door sill and produce the sound. However only once. Then I must drive the truck around and park when I open the door I hear it, I can stand on the door sill again and hear it, but only once. I must repeat the cycle again to reproduce the sound.
    Mine is unresolved but I had the dealer look at it once and the tech immediately thought it was a broken pinch weld but they never really looked into it more than that. I have rock sliders welded to my frame and the tech tried to BS me saying they were the cause when I know they are not because the sound was there prior to the sliders.
    I do plan on a dealer visit soon to make them find it.
    In this video of mine if you watch and listen you can hear the creaking sound, especially towards the end of the video.
    You can also hear the brake actuator solenoids increasing brake pressure too, but that sound is a distinct mechanical and with a steady cadence.
    http://www.youtube.com/watch?v=cF1WDuLJd4Q&feature=player_embedded
  8. May 12, 2010 at 5:20 AM
    buck
    buck Don't sweat the petty - pet the sweaty
    Ontario, Canada
    15 DC V6 4x4 TRD Magnetic Gray
    High-flow coconut smiley-face air freshener.
    I've got the same issue. I drives me nuts. I haven't figured out what it is yet. Going to take it in soon to have it checked out.
  9. May 12, 2010 at 5:46 AM
    CRFan1
    CRFan1 Well-Known Member
    Northwest Indiana
    Tacoma Pre-Runner
    DNX5120, Audsion AMp, Hertz Speakers
    Yep, My 08 does the exact same thing on the drivers side...a "creak that comes from the door sill - quarter panel area and I can replicate it by pulling into my driveway (I.E. the curb) at an angle. I have tried everything from spraying the bushings to taking off my step tubes. Most days its there, some its not. Drives me kinda nuts but I have learned to live with it. :mad:
  10. May 12, 2010 at 5:48 AM
    06stex
    06stex Well-Known Member
    Alex
    Corpus Christi, Texas 361
    06' TRD 6" Fabtech..limo tint
    6 inch Fabtech, Dirt Logic 2.5 coilovers, Light Racing UCAs 17x9 XD spy, 305 65 17 Extreme ATs, Limo all around, Kicker speakers,Kicker L5 10 inch sub, 400 watt kicker mono amp In dash Pioneer with Ipod cable, Flowmaster 50, bedmat, toolbox, K N Filter, cheapo seat covers, 6000k HIDs upfront, bhlm,DDM 5000K fogs, tailgate mod, and many more to come.
    me too, drives me crazy!!!!!!!!!!!! exact same sound and multiply that on top of the front end clunk.
  11. Jun 16, 2010 at 3:00 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Enough was enough. I took my truck into the dealer for analysis. After a long process they seemed to have solved my creaking sound. After the dealer tech isolated the location of the sound which was the lower door hinge area / door sill and tried everything they could think of to fix it, they eventually opened a support call to their corporate tech support.
    Corporate tech support went through the laundry list of obvious things and after a half hour of searching tech notes they came back with a possible solution.
    Their tech support instructed them to use penetrating oil to lubricate multiple points of the pinch welds and door area. Then let it sit and dry for at least an hour and then test. So the tech did just that, he applied thorough amounts of the penetrating oil to multiple points of "A" pillar and let it sit. I was told that he was able to peel back the weather stripping by the lower door hinge area and gain access there through a small hole. He was able to spray the oil in through the hole using a straw extension. No oil was used on the inside of the cab.
    The penetrating oil dissolves the slag build up in the weld where the noise was originating from. Because it's dissolving the excess material the noise can't come back. The oil doesn't harm the welds.
    After multiple treatments a road test was performed and the sound was gone!
    When corporate tech support was again contacted for a permanent solution, the dealer tech was told that it should be a permanent fix.
    I am very impressed that they were able to make the sound go away.
    No more annoying creaking sound! :yay:
    verynearlypure likes this.
  12. Jun 17, 2010 at 5:39 AM
    CRFan1
    Northwest Indiana
    Tacoma Pre-Runner
    Interesting but I am guessing that unless they used some kind of sticky waterproof type lube, it will be a matter of time before it returns. They put a band aid on it instead of fixing it.
    I am not sure I even want to waste the time getting mine fixed cause I am not sure they will even do anything. :mad:
    I only have 18000 miles and a year and a half of ownership so I have time to decide but this stuff kind of makes me mad cause its like the 3rd creak or squeek I have had and the other two (the infamous dash rattles) I have fixed myself. :(
  13. Jun 17, 2010 at 8:22 AM
    Crom
    Nick
    San Diego, CA
    Millions
    CRFan1, I would give the dealer a chance to fix it. They did fix mine. Here are some more comments on mine:
    Actually I spoke to the tech today and he explained in detail why it would not come back. The oil they used is a penetrating oil that dissolves the slag build up where the noise was originating from. Because it's dissolving the excess slag build up at the weld, the noise can't come back. I got the distinct impression it was a slight defect in the welding process. I do feel much better after speaking to him about it.
    He had confirmed that there were only two documented cases where this had occurred before.
    If you want you can PM me and I'll give you the T.A.S. Case # that they generated for my truck it could be helpful to you.
  14. Jun 17, 2010 at 8:39 AM
    CRFan1
    Northwest Indiana
    Tacoma Pre-Runner
    Ok that would be cool!
    Hmmmm, that's interesting. I am not gonna take away from the fix but honestly I am skeptical. I am a mechanic (airplane) and I don't know of any penetrating oil that dissolves slag....rust yes :) The fact is, that if or when what ever they used dries up (and maybe it won't), it will come back but only time will tell. I would ask that you keep us posted in the short and long term and thanks for all the info.!
    Do you know WHERE they sprayed the oil? Did they take off the interior kick panel? Cause I tried spraying lube when this first occured in outside locations to no avail. I would love to try this myself. :)
  15. Jun 17, 2010 at 9:06 AM
    wilsonpj
    wilsonpj Well-Known Member
    Pete
    Charleston, South Carolina
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
  16. Jun 17, 2010 at 9:12 AM
    CRFan1
    Northwest Indiana
    Tacoma Pre-Runner
  17. Jun 17, 2010 at 9:13 AM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    I'm a certified welder and have never heard of a penetrating oil that is used for dissolving slag :confused:
    My guess is you have either a cracked weld, incomplete weld, or a misfit joint rubbing and the penetrating oil made it's way into the joint and lubed it up enough to temporarily stop the noise.
    twotwentyswift likes this.
  18. Jun 17, 2010 at 9:13 AM
    Crom
    Nick
    San Diego, CA
    Millions
    Yes. I went back and edited my first post about the fix based on the conversation I had today with the tech. Here is what he said:
    Thanks. But we in this thread are discussing solving complex sounds originating from the body of the vehicle, not the rear springs.
  19. Jun 17, 2010 at 9:18 AM
    CRFan1
    Northwest Indiana
    Tacoma Pre-Runner
    I would agree....I am guessing it's a bad spot weld causing this in the first place. :mad:
  20. Jun 17, 2010 at 9:20 AM
    dogbite
    dogbite Well-Known Member
    Utah
    '10 double cab TRD OR
    OME lift, Leer shell, Beefed sliders, Extra 12V outlets for rear bench
    If you've added D-rings under your bed bolts you can get some creaking out of that too. They loosen up over time on rough roads sometimes. I had some creaking and tightening up those bolts quited things back down.
