Creaking/cracking sound from front suspension: 2016 tacoma OR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by socalktk, Sep 18, 2017.
  1. May 29, 2020 at 8:52 AM
    #41
    sagexp
    sagexp Well-Known Member
    Back home, AZ
    2002 Tacoma DC 4X4 2017 Tacoma DC 4X4
    Oops, my bad. I didn't notice the original post was an old post from 2017 and OP already found the issue. So, no, the 6112's have bushings I believe, not spherical bearings, so doubt that would be the cause.
    Age315 and ejewels[QUOTED] like this.
  2. May 29, 2020 at 9:06 AM
    #42
    ejewels
    ejewels Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    sorry if I sound dumb, but does tightening them mess with the alignment? Is there a certain way to tighten them?
  3. May 29, 2020 at 9:10 AM
    #43
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    No, you'd have to loosen them first.
    Simply get a 22mm and torque it down. The nut, not the bolt.
  4. May 29, 2020 at 9:15 AM
    #44
    ejewels
    CT
    torque number? Or just good-n-tight? And also, both bolts on each LCA?
  5. May 29, 2020 at 9:40 AM
    #45
    Phich
    San Antonio
    Six Demon Bag
    Just gudntight and yes both bolts.
    Hope this works for you!
    Age315 and ejewels like this.
  6. May 29, 2020 at 10:53 AM
    #46
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    The 6112's don't have a spherical bushing just a rubber one. I have 6112's and I'm not using a sway bar relocation bracket. I had some noise and installed one and it didn't fix the issue so I removed it. Mine looks close but doesn't touch. From what I've found after I grease everything it will squeak a little they go away. I did have a bad squeak and it was always right after an alignment. I've found that the tightening the LCA bolts did the trick for me and I mean tight. Just remember this needs to be done with the truck on the ground. If it's not then the bushing will be twisted when at normal ride height and that will cause squeaking.
  7. May 29, 2020 at 11:10 AM
    #47
    Age315
    AJ
    Castle Rock, CO
    I've torqued them to spec and they were really squeaky. My friend works at Toyota and he cranked them down really tight when he does my alignment now because I told him they were squeaking.
  8. May 29, 2020 at 11:16 AM
    #48
    ejewels
    CT
    thanks man. If thats the case, I'll def have to try it since we have the same setup.
    Age315[QUOTED] likes this.
  9. May 29, 2020 at 12:03 PM
    #49
    ejewels
    CT
    Did you have a sound like the OP's video?
  10. May 29, 2020 at 1:45 PM
    #50
    Age315
    AJ
    Castle Rock, CO
    Mine wasn't that bad but you would hear it squeak all the time. I originally thought it was the sway bar to frame mounts but I removed the away bar and it was still there.
  11. May 29, 2020 at 2:27 PM
    #51
    ejewels
    CT
    But was it a squeak, or a click/creak like the video? I'm asking because I don't have a squeak... more a metal on metal, click/creak kind of thing like the video.
    MountainManGuy likes this.
  12. May 29, 2020 at 6:57 PM
    #52
    Age315
    AJ
    Castle Rock, CO
    I'd have to say more of a squeak. I did put painters tape on anything I thought might be touching to verify if it was.
  13. May 29, 2020 at 7:44 PM
    #53
    jcmotr
    jcmotr Well-Known Member
    I have the exact same setup (Kings + BK UCA) and the exact same noises - I greased and torqued EVERYTHING without luck. I never thought about the skid plates, I'm going outside to check that right now.
    Jobr likes this.
  14. May 30, 2020 at 5:42 AM
    #54
    ejewels
    CT
    Still trying to figure out if OP had aftermarket skids
    jcmotr[QUOTED] likes this.
  15. May 30, 2020 at 1:49 PM
    #55
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    I had a clunk when turning sharp left, regardless of bump or not, more pronounced with a bump. I just took the nuclear approach on my truck and loosened/adjusted/torqued the skids (RCI AL trilogy), torqued front and cab body mounts, and torqued the LCA bolts. Not sure which one did the trick, but my clunk is gone. Thanks for this thread and all the info in it.
  16. May 30, 2020 at 4:22 PM
    #56
    jcmotr
    I have RCI skids (Front and Trans).
    Damn, I also have that clunk. It’s good to know that you solved it. Honestly I never thought it might be the skid plates.
    BortisYeltzen[QUOTED] likes this.
  17. May 30, 2020 at 8:10 PM
    #57
    thecoloRADoinferno
    thecoloRADoinferno Well-Known Member
    2017 Tacoma Inferno TRDOR DCSB
    BeardedYinzer and IsaacTheAnimal like this.
  18. May 30, 2020 at 8:47 PM
    #58
    IsaacTheAnimal
    IsaacTheAnimal Member
    Denver, CO
    2020 TRDOR DCSB
    Toytec Boss, SPC UCAs, TRD SEMA wheels, 275/70r17 KO2s
    Update:
    Double checked Sway Bar relocation brackets - definitely on correctly with a space in the back - Didn’t fiddle too much but sway bar still knocks the coilover when the wheel’s cranked to the right. Also, still getting creaks on uneven ground, bumps etc even after blasting lube just about everywhere I could see.
    Still need to check the mounts AND tightening the LCAs. Also getting SPC UCA’s in a couple weeks so there might be something there too.
    The truth is out there!
    jmauvais likes this.
  19. Jun 1, 2020 at 11:16 AM
    #59
    ejewels
    CT
    When tightening the LCA bolts, which exactly? All of them? Doesn’t that affect the alignment?
  20. Jun 1, 2020 at 12:31 PM
    #60
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    I tightened all 4. I checked both the bolt side and the nut side. I had a hard time accessing the nut side on the forward R/L due to my T-wrench/socket hitting the CV joint. If they are tight and you are just torquing them to 130ish ft/lbs, they shouldn’t move. I marked my alignment cams with a paint pen so I could tell if they moved when I did mine. Still quiet a few days and ~100ish miles later.
    IsaacTheAnimal likes this.
