Creaking dash
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dogdad, Dec 7, 2014.
  1. Dec 7, 2014 at 12:16 PM
    Dogdad
    Dogdad [OP] Well-Known Member
    Metairie,Louisiana
    2015 Pyrite Mica Double Cab
    I have had my 2015 tacoma a little over a week....dash is already creaking and rattling while driving...I don't drive hard and fast...not happy...my two Tundras were much better...toyota is not what it used to be....yea I know, what is".
  2. Dec 7, 2014 at 12:28 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Damn, got the 4th gen tacoma eh?
  3. Dec 7, 2014 at 12:55 PM
    Mag16tac
    Mag16tac Well-Known Member
    2018 Ford F150 XLT 2.7 ecoboost!!!!
    I read on some other post about inserting a piece of rubber or other pliable material between the dashboard top and windshield. I have a 2014 Tacoma double cab with about 2000 miles on it now. The dash started rattling last week and after taking my radio out and climbing under the dash looking for something causing a rattle without much luck, it appeared to be coming from the dash top next to the front windshield. I owned a 2011 Tacoma before my 2014 and experienced similar issues. I choose to use a 1/2 inch gasket cut to length of the dashboard opening at the base of the front windshield. Noise problem solved, looks great and quiet. I wanted a fix that had a factory appearance and the gasket install worked for me. It's actually hard to see anyway but if you do it does look uniform. A simple solution, minimal cost and took 5 minutes. Hope this helps.:) I will also say, I did notice more insulation around the air ducts and other areas to help reduce noise in this 2014 then the 2011 Tacoma.
  4. Oct 27, 2015 at 2:25 PM
    afwxguy
    afwxguy Member
    Black 2012 DCSB OR
    3" Lift OME Springs on Bilstein 5100s, Camburg UCAs, Deaver AAL, K&N CAI
    The creaking is driving me crazy. Mica14tac what kind of gasket did you use?
  5. Oct 27, 2015 at 2:27 PM
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport
    Stock
    Happens in my truck too. Shit drives me crazy!
  6. Oct 27, 2015 at 2:30 PM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    I have a buzzing/vibration that sounds like its coming from the shifter or rubber cup holder area. I always try pushing on stuff but it never goes away. And come winter when its cold, all the noises come out.
  7. Oct 27, 2015 at 2:35 PM
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    I believe the dark gray pipe insulation from any hardware store will work. Cut it into a 1/2 or 1" strip. I had this problem for a while and it went away. No idea why. Now I'm 115k miles into the truck (and lots of those hard off-road miles) and still no creaks. In my experience, any noise in the cabin is from something that I've brought in (random cup, crap in the cup holder, etc.)
  8. Oct 27, 2015 at 2:47 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    THIS, WORKS LIKE A CHARM!
  9. Oct 27, 2015 at 3:00 PM
    omega supreme
    omega supreme Well-Known Member
    2011 TRD sport,lb
    None
    eash... not good. Paging volcom!!!
