creaking leafs
Discussion in 'Suspension' started by nastyblowpop, Jan 16, 2010.
  1. Jan 16, 2010 at 3:43 PM
    nastyblowpop
    nastyblowpop [OP] Well-Known Member
    Long Beach, CA
    08 DC 4x4 rugged trail
    i have an 08 taco without the tsb. i tried to get the tsb but i have too many miles they said. but anyway when i go over speed bumps or dips or anything really my leafs creak like crazy. i sprayed white lithium grease in between them and they are slightly better but still creak. i know its not necessarily a bad thing, but its just so embarresing. and ideas?
  2. Jan 16, 2010 at 3:56 PM
    Reneg8de
    Reneg8de Member
    Tempe, AZ
    05 DC TRD OffRoad 4x4 SR5
    40 Series Exhaust, OEM Roofrack, AFE Stage 2 Si CAI (Pro Dry S), Westin Bed Extender, Heavy Duty Floor Mats, Bridgestone Dueler A/T Revos 265/70R16, USA Spec PA15-Toy iPod Adapter, waiting to install: OME 885s, shocks and LR UCAs
    I have the exact same problem and it drives me crazy. I notice that the squeaking seems most prominent after I'm done offroading, and so it seems that it probably dust/dirt. I usually just try to spray some water in the leafs and it sometimes helps it not squeak AS much.
  3. Jan 16, 2010 at 3:56 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    If your over 36k miles then yes any TSB regarding this issue will not apply to you, unfortunately. You can go to the dealer and have them install new silencer pads or take your truck to a suspension shop and they will do it. I had my Tahoe done and it cost me around $50. A grease or lubricant is a temporary fix.
  4. Jan 16, 2010 at 4:06 PM
    nastyblowpop
    Long Beach, CA
    ok, when i bought the truck i bought the platinum warranty that covers everything except body panels, so would that be covered do you think?
  5. Jan 16, 2010 at 8:45 PM
    dexterdog
    Oly WA
    2012 F150
    I have no clue.
  6. Jan 16, 2010 at 8:53 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    I'm sure it would. It would go under mechanical mantainence
  7. Jan 16, 2010 at 9:08 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    If your truck is under warranty, and I were you, I'd definitely lean on them for service work.
    Here is a link to a TSB which references the silencer pads which fixes the problem. T-SB-0274-09
    I hope it helps. :)
  8. Jan 17, 2010 at 6:24 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    IDK about the rear silencer pad TSB- but the main leaf spring TSB is only for the factory warranty (3/36) and not the extended...so that extra warranty is probably useless for that.
    Make sure you are greasing the bushings that attach the springs to the frame too...And that the ubolts are tightened/torqued down correctly.
