Creaking noise with lift
Discussion in '5 Lug' started by mcleod90, Mar 14, 2011.
  1. Mar 14, 2011 at 9:14 AM
    mcleod90
    mcleod90 [OP] 150,000 miles and counting
    sean
    modesto ca
    05 double cab
    Ive had my fat bobs lift on for about two weeks and I noticed there's some sqeaking/creaking noise coming from the rear. Is ghat normal? I had a shop put it on so I'm assuming it was done right.
  2. Mar 14, 2011 at 12:52 PM
    comiesutra
    comiesutra Well-Known Member
    Greenwood, IN
    '10 4X4 Silver AC SR5 Manual
    MonsterKnobs.com shift knob, Sony MEX-BT3900u
    i haven't noticed anything like that after installing mine myself.
  3. Mar 14, 2011 at 1:51 PM
    alexmxman185
    alexmxman185 Keepin' it dirty in Texas
    Alex
    Waco, Texas
    08 toyota tacoma 2.7 4 cly 5 lug
    Black grille guard with mounted kc road lights, 31x9.5x15 AT on stock rims. My future mod list: new white front bumper, Fat Bobs 2.75 spacer lift with rear AAL, american racing Flat Black Rims, 32x11.5x15 BFG A/T, satoshi grille with road lights mounted behind it, 8000k HID for all lights, 1'' Body Lift, new window tint, blacked out headlights and taillights, custom hood scoop, weather tech floor liners, LED dash cluster replacement, Front bilstein shocks, 40 series flowmaster, paint all my badges black.
    iv noticed it and i only have a small spacer lift with an add a leaf. it makes the creaking sound when ever i go over a low area of ground to a higher area and it causes the rear end to take more pressure on one side than the other. is that the same thing your experiencing?
  4. Mar 14, 2011 at 3:22 PM
    mcleod90
    sean
    modesto ca
    05 double cab
    I just hear it when I drive slow. It's kinda hard to explain.
  5. Mar 14, 2011 at 4:11 PM
    alexmxman185
    Alex
    Waco, Texas
    yea i know what your talking about. i think if you spray some sort of graphite or lubricant in there you might be able to muff the sound a little. Ill try to figure it out and let you know.
  6. Mar 14, 2011 at 4:28 PM
    MurphMan
    MurphMan Senility Rocks!
    Murph
    Maine
    '08 Tacoma TRD Sport
    * AFE Stage 2 XP CAI System * Westin Platinum Series Black Step Bars * TruXedo Lo Pro QT Soft Roll-Up Tonneau * Dee Zee Heavyweight Truck Bed Mat * WeatherTech Extreme-Duty Floor Liners * WeatherTech In-Channel Window Visors * Sony Xplod CDX-GT81UW Receiver * Sony Xplod 2-way speakers * Boss Audio BASS600 Amplified Subwoofer * Billet Grille Mod
  7. Mar 14, 2011 at 5:19 PM
    mcleod90
    sean
    modesto ca
    05 double cab
    Did that method work for you?
  8. Mar 14, 2011 at 5:32 PM
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
    Not being a dick, but thats just part of having a lifted truck man. You modified stock suspension with aftermarket parts its bound to happen.
    Take a ride in a LT truck, no matter how well greased it is there's all sorts of awesome squeaks, creaks, and rattles.
    Just turn up the stereo and youll forget all about it :D
  9. Mar 14, 2011 at 6:05 PM
    mcleod90
    sean
    modesto ca
    05 double cab
    Lol I know I didn't even notice it until m dad drove it for the first time, he must have turned the radio down :p
    But ya it doesn't bother me I was just seeing if it was normal.
  10. Mar 14, 2011 at 6:37 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    It's your AAL squeaking. On built leaf packs there are pads (teflon) that are between the leaves which keep them from squeaking. When you put on an AAL, they don't always come with pads so they sometimes squeak. Someone on here had a solution where they used gorilla glue to glue some rubber squares cut from bicycle inner tubes on the AAL.
