Creaking/popping noise from under bedside
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bonuscup, Oct 27, 2021.
  1. Oct 27, 2021 at 5:02 PM
    bonuscup
    bonuscup [OP] Well-Known Member
    Southern California
    2021 TRD OR DC LB XYZ
    I’ve done some digging and haven’t seen another thread describing an issue like this so just hoping someone has some insight.
    I have a ‘21 TRD OR long bed. This past weekend we did the Mojave road end to end (130ish miles) and on the last day I noticed a creaking/popping noise coming from the rear. I’m able to emulate it by rocking the truck back and forth and the noise is coming from what sounds like is inside the passenger rear wheel well. It happens going in and out of driveways mostly and I hear it accelerating from a stop sometimes.
    The truck has a SnugTop camper shell and on the roof has a waterport and Jerry can sitting on a front runner rack, but no RTT. I have Deaver stage II leafs and a full King 2.5 suspension sitting on 33s. It can’t be more than 350-400lbs, plus maybe a 50-100lbs of camping gear. The leafs alone support up to 600lbs.
    I saw some other threads talking about bed stiffeners (I don’t have them…yet) that some other folks find hairline cracks in the corners of the tailgate - I have one tiny one on the drivers side.
    I’m taking it to the dealer tomorrow to see if this is something I can get fixed under warranty (the noise and crack at the tailgate) but was hoping to have some ammo in my back pocket as to what it possibly is. Thanks
  2. Oct 27, 2021 at 5:05 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    Check thw torque of the u bolts hding the leaf springs on.
  3. Oct 27, 2021 at 5:05 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Just normal leaf spring rubbage?
    bonuscup[OP] likes this.
  4. Oct 27, 2021 at 5:33 PM
    bonuscup
    Southern California
    I thought leafs too but the noise when I climb under there while someone else jumps up and down on the tailgate sounds like it’s actually up in the wheel well
  5. Oct 27, 2021 at 6:44 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Spritz a lil panther pee around both of the bushings and see if it goes away.
    Mark77 likes this.
  6. Oct 27, 2021 at 9:32 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    I just turn the radio up….
  7. Oct 27, 2021 at 10:02 PM
    bonuscup
    Southern California
    I did that on the trail too. Now at home it’s so much louder.
    AmateurTaco1313 likes this.
  8. Oct 27, 2021 at 10:04 PM
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    Lift up on the corners of the bed. Is it loose? Thumping sound?
    Mark77 likes this.
  9. Oct 28, 2021 at 3:56 AM
    jakbakcrak
    jakbakcrak Well-Known Member
    Jack
    2020 Quicksand TRD Off Road Tacoma
    Several aesthetic
    Any creaking and popping I hear is usually my right hip....how old are you...???
    texas angler and Mark77 like this.
  10. Oct 28, 2021 at 4:24 AM
    jjglass535
    jjglass535 Well-Known Member
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    I get that same noise too. Sounds like it's coming from passenger rear. Get it backing out of my driveway and sometimes when making a u turn
  11. Oct 28, 2021 at 5:01 AM
    MidCitiesMildMan
    MidCitiesMildMan Well-Known Member
    2017 Toyota Tacoma Limited
    Stock and staying that way
    Spare tire moving?
    shakerhood likes this.
  12. Oct 28, 2021 at 5:04 AM
    jjglass535
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    Suppose I could check that. It's never been touched since new. Sounds more like the bed popping or maybe a leaf spring
  13. Oct 28, 2021 at 5:51 AM
    aStrauss
    aStrauss Well-Known Member
    Andrew
    2019 TRD OR DCSB 6MT
    Do you have something in the bed mounted cubby? Could the box that houses your 110v outlet be loose?
  14. Oct 28, 2021 at 5:56 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    I was getting the same type of noise.
    Spare tire was tight. I still lowered it and re tighten it. Noise went away.
    AmateurTaco1313 and bonuscup[OP] like this.
  15. Oct 28, 2021 at 9:13 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Eating Rice Crispy Cereal?
  16. Oct 28, 2021 at 11:24 AM
    bonuscup
    Southern California
    Problem solved. One of the bolts on the floor of the the bed that attaches it to the frame rail was like finger tight loose (the one closest to the cab). Tightened it and noise went away.
  17. Oct 28, 2021 at 1:20 PM
    shakerhood
    Southern Ohio
    That is awesome, simple fixes are always welcome!
  18. Oct 28, 2021 at 1:31 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    I initially read this as “under the bed” and figured it was very Halloween apropos.
  19. Oct 29, 2021 at 4:22 AM
    jjglass535
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    I'll have to check those, that's exactly where the sound is coming from
    bonuscup[QUOTED][OP] likes this.
  20. Oct 29, 2021 at 11:02 AM
    jjglass535
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    Ok, so after checking all of these things just for the hell of it I pulled the rear seats forward and it was my subwoofer box moving when I backed out of the driveway. It only happened then and when I made a sharp hard turn. Got it braced up nice now and the noise is gone
