Creaking sound with lift... HELP??
Discussion in 'Suspension' started by 09Doright8126, Nov 18, 2009.
  1. Nov 18, 2009 at 7:06 AM
    09Doright8126
    09Doright8126 [OP] Well-Known Member
    Andrew
    Greenwood, SC
    '09 DC TRD Offroad Pyrite Prerunner
    Aires chrome bullbar, Wet Okole seat covers, 6" KC offroad Slimlites w/ covers, upper Grillecraft black w/ TRD emblem, Redline hood struts, URD TCAI w/ black wrap, URD MAF Sensor, NST pulleys, NST intake manifold spacer, Bilstein 5100s, Eibach coils painted red, painted red brake calipers, SST brake lines, debadged tailgate, window tint, bed mat, extra D-rings, Rear TSB, Tranny TSB, swaybar removed, DTLT headers, URD Y-pipe, Vibrant Resonator, MagnaFlow
    I just installed my 5100s with Eibach coils myself about a week ago and now there is some "creaking" coming from the front during initial take off/turning...
    Has anyone else experienced this problem or have any suggestions as to what it might be?
  2. Nov 18, 2009 at 8:27 AM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
    Do you have stock UCA's? What are your 5100's set at?
  3. Nov 18, 2009 at 8:39 AM
    09Doright8126
    Andrew
    Greenwood, SC
    Sorry, I have the stock UCAs and the 5100s are at 0".
  4. Nov 18, 2009 at 8:54 AM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    I had the same creaking sound every time I would start moving from stopped, and it would be worse when going over uneven terrain especially when turning. I tracked it down to my UCA bushings. Just greased 'em up and she rides smooth now. I also am running the 5100's at 0, but with OME 885 coils. If you have the stock UCA's and it wasn't creaking before, I'm not sure.
    You might want to ask Chris 4x4, he's helped me out a lot and he's the suspension master.
    Kevin
