Creaking/Squeaking Sound- not the leaf springs?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by an_drew03, Jul 22, 2022.
  1. Jul 22, 2022 at 9:52 AM
    an_drew03
    an_drew03 [OP] Active Member
    Andrew
    https://imgur.com/a/WB7gm5a
    Hey guys, just wondering if anyone has any advice for this creaking sound I’m getting on my 2019 Tacoma. It only happens at low speeds, like parking lot or residential streets, and it can happen forward, reverse or turning. It doesn’t happen over bumps/rough roads.
    I attached a video, not the best but the creaking sound is like halfway in.
    I’ve tried lubing everything I could in the front suspension area, the front body mounts, and the leafs again but no luck. I looked at the front body mounts and they look ok but i ordered some replacements just in case.
    Any ideas?
  2. Jul 22, 2022 at 10:04 AM
    RockSpongeTaco
    RockSpongeTaco Active Member
    Jon
    South Puget Sound
    2019 SR5 DCLB Super White
    Ironman 4x4 Medium leaf pack and Foam-cell Pro rear shocks Full frontal Xpel, stealth hood ARE Z-Series bed cap Spiker Engineering High-lift Hood Struts ~5 inches extra clearance
    I thought I had creaky springs for a few months after I got new AT tires. Turned out the tire place didn't fully tighten the chain hoist for the spare. The spare moved slightly at times causing a squeak I couldn't find otherwise. Drove me up the wall. Not sure about yours, but something easy to try.
    an_drew03[OP] likes this.
  3. Jul 22, 2022 at 6:02 PM
    an_drew03
    Andrew
    Thanks man, I’ve heard about the spare making a lot of noise too, thankfully I had to remove it because of a flat so it’s not coming from there. Here’s a better video of the sound
    https://imgur.com/a/wk4krdv
  4. Jul 22, 2022 at 7:27 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    My UCAs make a similar noise, but it’s from the uniball. What UCAs do you have?
  5. Jul 22, 2022 at 8:24 PM
    an_drew03
    Andrew
    I have stock UCA’s with Falcon Terraflex shocks front and rear, should I just keep throwing lube at it until it stops haha
  6. Jul 22, 2022 at 8:32 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Check carrier bearing, ujoints
  7. Jul 22, 2022 at 8:56 PM
    an_drew03
    Andrew
    I will check that, thanks.
  8. Jul 23, 2022 at 9:22 AM
    cosmic_3000
    cosmic_3000 Well-Known Member
    '17 OR DCLB w/ JBL
    Are you sure it's not the leaf packs? That sounds similar to mine when they were all dried out.
    What I did is lift the truck to unload your suspension until the rear tires are hanging, then use a crowbar to spread the leafs apart and lube the pads between each leaf with white moly grease. Quiet ever since.
    an_drew03[OP] and Tacos4ever15 like this.
  9. Jul 23, 2022 at 10:27 AM
    an_drew03
    Andrew
    I will check out the leafs again, I did the zip tie trick about a year ago and haven’t had any issues with them but they may be back with the squeaking once again. I had two zerk fittings in the driveshaft ujoints that I greased today too, I’ll drive tomorrow and see if that helped
