creaking suspension
Discussion in 'Hawaii' started by damoihunta, Sep 24, 2013.
  1. Sep 24, 2013 at 1:31 PM
    damoihunta
    damoihunta [OP] TACO's anyone???
    2012 double cab 4x4
    Procomp 3" lift 33" on XDs LED gauge swap LED map and dome lights grill craft mesh grill Rigid Industries D2s floods Rigid Industries SR6 driving lights Soon to come.
    anyone can tell me how to get rid of all the creaking in my suspension? a friend told me not to spray WD40 on rubber because petroleum products break down rubber, so silicone? what could I use...
    Mahalo
  2. Sep 24, 2013 at 2:11 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    the silicone lubricant is better than wd40. I picked some up yesterday for mine and it's water-proof.
  3. Sep 24, 2013 at 4:12 PM
    MikeyTG
    MikeyTG Oh Herro
    Oahu
    what rubber suspension component?
    creaking coming from front or rear? (my guess is rear since our leafs are notorious about that)
    Note sure if it's the right answer but I just used regular multi-purpose automotive grease on my leafs, not even sure what brand...
  4. Sep 24, 2013 at 7:42 PM
    luka
    Kailua, HI
    for me it was the leaf spring bushings
  5. Sep 25, 2013 at 1:03 AM
    3boyztaco
    3boyztaco Well-Known Member
    in the middle of the sea
    PreRunner
    My front right just started the "creaks". Mostly noticeable with making right turns and slowing down turning right. Rear springs have been creaking for months. Silicone lubricant seems to work for several days. Just wondering if the front creaks are coming from the sway bar or the anti compression strut bushings on the fabtech 6" lift.
  6. Sep 25, 2013 at 2:27 AM
    damoihunta
    2012 double cab 4x4
    I just have a 3" procomp lift. I believe it to be the rubber bushings... Idk but creaks all the time. Speedbumps ,turning, what ever. Kinda irritating
  7. Sep 25, 2013 at 10:46 AM
    luka
    Kailua, HI
    it could also be the sway bar hitting the coils, have you looked at everything to check for chaffing?
  8. Sep 25, 2013 at 10:51 AM
    3boyztaco
    PreRunner
    Might be from the sway bar bushings. do you have your sway bar on still? I'm thinking of changing my bushings as soon as I have the time.
  9. Sep 25, 2013 at 10:53 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Put some gold bond on your truck for the chaffing it really works
  10. Oct 6, 2013 at 12:26 AM
    elsenordave
    elsenordave HaoleBilt
    Dave Smith
    Blown 2013 NBM DCSB Sport
    AFE CAI TRD Exhaust TRD Supercharger 3" Cornfed Spacer 2" Toytec AAL
    I used white lithium grease on mine...no more squeak... I've an AAL so i can't do the tsb...
  11. Oct 6, 2013 at 12:32 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Personally, I'd never use any oils or greases unless its a DRY lubricant.
    Oils & greases attract dirt & dust in those areas you are spraying.
    Power wash the leafs & inspect your leaf pads (pads inbetween leafs at the ends). To further inspect, remove your leaf pak at each end, inspect bushings & lubricate / anti seize between the bolt & metal sleeve.
