Creaking when turning at low speeds
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andrewtheadventurer, Oct 16, 2019.
  1. Oct 16, 2019 at 12:57 PM
    andrewtheadventurer
    andrewtheadventurer [OP] Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    when I turn at low speeds, such as in a parking lot, my truck talks to me. It is a creaking sounds from the front. My front end is basically new. I have new LCAs, new kings, SPC UCAs, new reman'd steering rack with poly bushings, UBJs are fairly new, and new CVs.
    The creaking sounds like something is moving and reverbing off the skids.
    I have made sure my cam bolts are tight, removed front diff drop, full skids are tight, and all components are tight.
    Could i have overlooked a bolt that is allowing the shift?
    I didnt grease the steering rack bushing.. could that be it?
    What about the front diff arm mount shifting a tad and reverbing off the skids?
    My steering is tight with no leaks visible in the inner rod boots. I have removed the skids and can faintly hear it so the skids are increasing the volume of the creak.
    Thoughts? it is really frustrating because i dont have anyone to turn the wheel while i checkout below..
  2. Oct 16, 2019 at 1:02 PM
    714reyesj
    714reyesj Well-Known Member
    Danny
    Orange County, CA
    2017 TRD Off-Road 4x4
    Mine used to do that after a long day of wheeling. Greasing the UCA bushings did the trick.
  3. Oct 16, 2019 at 1:35 PM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Yeah happens after wheeling
  4. Oct 16, 2019 at 2:37 PM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    I have SPC UCAs with poly bushings. How do you grease yours?
  5. Oct 16, 2019 at 2:38 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Loosen the UCA bolts, pump some grease in there, then tighten the bolts back down. Be careful and go slow so that you do not cause the Poly bushing to mushroom/bulge (this is why you must loosen the UCA bolts so the grease has somewhere to go)
    714reyesj likes this.
  6. Oct 17, 2019 at 1:24 PM
    714reyesj
    Danny
    Orange County, CA
    This. With compatible grease. I use SuperLube
    BassAckwards[QUOTED] likes this.
  7. Oct 17, 2019 at 9:32 PM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    I have retorqued all my rack bolts and front diff mount bolts. Also, I noticed my carrier bearing has alot of play. I believe the combo of loose front diff mount bolt and worn carrier bearing and most of the noise. I will report back when i install the new carrier bearing.
  8. Oct 17, 2019 at 9:39 PM
    marinetaco
    marinetaco Well-Known Member
    Bobby
    2005 Tacoma TRD
    Spray down your balls. Uni-balls that is. Go get yourself a can of Tri-flo. Become friends with it.
  9. Oct 17, 2019 at 9:45 PM
    06yotota
    06yotota Member
    Andrew
    2006 Toyota Tacoma
    Fabtech 6" lift
    off topic but where did you get your steering rack??
  10. Oct 17, 2019 at 10:59 PM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Summit Racing. They have great customer service and are willing to warranty this one if the carrier bearing doesnt fix the issue. I am trying to do everything i can to confirm it is the rack before submitting a warranty claim.
